Old 10-21-2011, 10:50 AM   #1
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Default Official LH2.4 EZK Wasted Spark Conversion - Installation Instructions
Ok guys, here's a set of instructions for the installation of the wasted spark boards. We're focusing pretty heavily on the installation of the board itself. There are far too many combinations of ignition modules and coils to provide comprehensive instructions on that part of the project. The disclaimer is basically this: Some brain power required, some assembly required, batteries not included. It would be much appreciated if people could post some instructions and impressions relating to the specific parts they used for their installs.
Read this entire post thoroughly and completely before posting any questions.
Your shipment should include the following items:
  • 1x Wasted spark conversion PCB
  • 1x Mounting screw
  • 1x Plastic mounting washer
1. Directions for installation
The conversion board has been designed to be mounted inside the EZK box. On 240's the EZK box is mounted on the front right corner of the firewall, right above the foot well. On 740's and 940's it is mounted under the dash, above the throttle pedal.
Remove the EZK box from the car, and using a torx screwdriver, remove the four screws on the end of the case and the three screws around the connector. This should allow you to open the housing of the EZK box and gain access to the circuit board itself.
The conversion board has 8 labeled solder pads. The four pads labeled "5v", "GND", "Out", and "VR" need to be tied to the four labeled points on the EZK board [fig 1]. "VR" goes to pin 7 of the LM2903 IC. If you tin the leg of the IC you can easily attach a wire to it. The "Out" pin is actually intended for pin 16 of the main connector, but we find soldering it to the indicated resistor leg makes for a cleaner installation. If you want to solder your wire directly onto pin 16, feel free to do so. The 5v and GND supply points should be self explanatory. Make sure you don't reverse them. That would be bad. We recommend potting all the wire-to-PCB connections with hot glue to secure the wires from vibration.
The two pins labeled 1-4 and 2-3 are the new logic-level spark outputs. They need to come out of the box and go to the proper pins on your power stage/coil. If your car is not equipped with EGR you can piggyback on those pins, or you can just drill a hole in the box to pass the wires through.
Using the supplied screw and mounting washer, attach the board to the body of the main EZK connector [fig 1]. Depending on clearance to the housing, it may be necessary to mount the board in an inverted fashion.
We recommend the use Bosch Motorsport 2x2 wasted spark ignition coil (part #: 0 221 503 407). This is the only ignition coil we have found with documented dwell characteristics that match the built-in EZK dwell. The stock ignition module has one output stage, but since the wasted spark system requires two outputs you can either install an additional stock ignition module or replace it with a multi-channel equivalent (eg. Bosch 0 227 100 203, Volvo 960).
A sample wiring diagram is shown in [fig 2].
It is important to note that these parts are simply suggestions. You are free to use any suitable combination of ignition modules and coils.
2. Adjustable hard-cut rev limit (experimental)
NOTE: This feature is considered experimental. This means we don't guarantee it will work well, or even at all. It means use at your own risk and we are not liable for any damage caused by its operation. Basically don't be an idiot.
Your wasted spark conversion also comes with an experimental hard-cut rev limit/launch control/flat shift feature. In essence it allows you to hold the engine at any rpm, even whilst applying full throttle. This should enable more consistent launches from a standing start. It is important to note that this is not an "anti-lag" function since ignition timing is not being retarded.
Recommended wiring diagrams for the arm and set features are shown in [fig 3]. The dash-mounted set switch should ideally be momentary and the clutch switch must close to ground as the clutch is depressed.
It is important to note that the launch control feature will be completely disabled by simply not connecting anything to the set and arm pads.
3. Tachometer options
Depending on how you have the system wired, there are a couple of different ways to drive the tachometer.
The first (and arguably easier) method works if you have left the stock power stage and wiring intact. Simply move any wires currently connected to the stock coil's two spade terminals to the "85" and "86" terminals of an automotive relay. To keep the relay from clicking you should open the body of the relay and remove the contactor assembly.
If you have chosen to remove or modify the stock wiring, then driving the tachometer can most easily be done by building a circuit similar to the one listed in the MS-Extra manual under "Option for High Voltage tacho" (http://msextra.com/doc/ms1extra/MS_E...l.htm#tachoout). The base of the transistor should be connected to the stock EZK spark output pin. Note that this solution uses the same modified automotive relay as mentioned earlier.
Figure 1: Preferred connection points inside the EZK box. Note the multiple 5v and Ground suggestions.
Figure 2: Suggested ignition module wiring.
Figure 3: Suggested launch control wiring.
Fake Race Car
Karl Buchka is offline   Reply With Quote
Old 10-21-2011, 03:16 PM   #2
Texas240
Prius Owner
Texas240's Avatar
Since Im going to use Toyota Cops with built in Ignitors is there going to be issue with dwell there?
93 245 LS Engine Swap Project
Old 10-21-2011, 04:53 PM   #3
Karl Buchka
I'll provide an (un)educated guess and say no, it won't.
Old 10-21-2011, 05:29 PM   #4
Texas240
Prius Owner
Texas240's Avatar
cool beans
Old 10-22-2011, 07:53 AM   #5
surre_sprett
So for the tachometer you suggest we do this?:
surre_sprett is offline   Reply With Quote
Old 10-22-2011, 09:22 AM   #6
Karl Buchka
Yes, that's the one. The stock spark output goes in place of the "MS PCB" in that diagram.
Old 10-22-2011, 09:40 AM   #7
malloy1
malloy1's Avatar
Here is the pinout on the 0 221 503 407 unit:
and the 0 227 100 203 unit is pinned out as (the unit is used to run 3 sets of wasted spark cylinders):
Pin 1-#1 negative coil
Pin 2-#1 Input
Pin 3-#2 negative coil
Pin 4-ground
Pin 5-#2 Input
Pin 6-#3 negative coil
Pin 7-#3 Input
This should be the setup using these two parts:
Out From EZK: -> Into 203:____ Out From 203: -> Into 407:
1-4 output -------> Pin 2 _________ Pin 1 -------> Pin 3
2-3 output -------> Pin 7 _________ Pin 6 -------> Pin 1
Pretty picture:
Photobucket
I'm assuming pin 3 & 5 of the 203 unit won't be used to run any cylinders. Also, "Switched 12+", I mean 12+ when cranking too.
Karl looked it over, and thinks it looks right, but if somebody sees something wrong with it, please point it out.
Paul
Paul
malloy1 is offline   Reply With Quote
Old 10-22-2011, 01:24 PM   #8
fidel
knox motorsports
fidel's Avatar
if you leave the stock power stage and wiring all in place this circuit isn't necessary.
i have been running a dummy coil in place of the stock coil for my tach signal since the installation of the beta buchka motorsports electronic engineering super happy fun time luxury A+++ wasted spark conversion board.
so that is over 3 months (over 4000miles) no glitches what so ever
fidel is offline   Reply With Quote
Old 10-22-2011, 03:07 PM   #9
Texas240
Prius Owner
Texas240's Avatar
Thats bad ass.. Now to hide the coil some where
Old 10-28-2011, 05:26 PM   #10
Karl Buchka
Thanks for posting that Lawrence. I just added a section on tachometer driving.
Old 10-28-2011, 06:17 PM   #11
ZVOLVO240
ZVOLVO240's Avatar
any info on where to source that dummy coil substitute?
- Will Z
1989 244 DL - - - Beige N/A
1988 245 DL - - - Original owners/Dad's Car
1991 244 Turbo - DEAD
ZVOLVO240 is offline   Reply With Quote
Old 10-28-2011, 06:37 PM   #12
Karl Buchka
Read the section I just added.
Old 10-28-2011, 11:07 PM   #13
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Excellent article, Excellent product.
I've been on board with the second test board in operation. I'd like to add my installation notes.
Another option for an ignition module (with built in 12v 4 cyl tachometer output):
Mitsubishi J702T Ignition module, coming off 90-98? mazda miatas (1.6l being the most common). This module works great, and just solder up 1 wire for a full functioning volvo tach.
Also the coil packs off same said car work perfectly, I made 300whp on them, 500dollarmatt made 360whp.
Old 11-02-2011, 03:46 PM   #14
WindowsBreakerG4
ALDORF THE DESTROYER OF WHITE SHIRTS
WindowsBreakerG4's Avatar
No there won't be, the miata guys have been using them in a wasted spark config for like 4 years now
I understand though that LS coils WILL NOT work as they require longer dwell than a wasted spark config can provide. (for those who are thinking about that)
ovlover: Its an auto. Problem found, Manual swap. Problem solved
Originally Posted by cosbySweater View Post
She was pretty damn hot. And she folded my clothes and made me breakfast in bed
Towery wants to get me drunk but doug already is. Don't trust a drunk Towery he will slip you the old stiff one eye
I AM ALDORF THE DESTROYER
1985 744ti M46 -3rd, 15g, 3" exhaust, Ported Head, 333,333 miles
91 945 Turbo 3 pedal auto, DD
83 242 Turbo Flathood
15 Golf TDI 6 Speed
Doug <3 me. Not scottyd. doug was here again
WindowsBreakerG4 is offline   Reply With Quote
Old 11-02-2011, 06:27 PM   #15
Karl Buchka
I've been led to believe that LS1 coils will work perfectly fine. What dwell do they require?
Old 11-02-2011, 08:07 PM   #16
WindowsBreakerG4
Ok I see people doing it so I guess the miata people () are full of crap I see people running wasted spark with LS coils.
LS1 Coils seem to be 5.6-8MS depending on who you ask :P supposedly factory is around 6 though. It also seems that the dwell varries based on which LS coil it is (IE LS1 has diffnerent dwell than LS2 Coils)
http://www.msextra.com/doc/ms3/ignition.html
A dwell figure of 5.5-6.0ms is advised for LS1 coils.
A dwell figure of 5.0-5.5ms is advised for LS2 coils.
Sorry I didn't mean to drag this off topic, YMMV.
Old 11-02-2011, 08:24 PM   #17
malloy1
malloy1's Avatar
Is there enough dead output pins on the ECU to run the waste spark through the plug instead drilling a hole in the case?
Paul
Old 11-02-2011, 08:43 PM   #18
Texas240
Prius Owner
Texas240's Avatar
Paul
I think there is actually
Old 11-02-2011, 08:44 PM   #19
Karl Buchka
As I mentioned in the original post, a non EGR EZK will have enough free pins. Beyond that, I'm not sure.
Old 11-02-2011, 08:52 PM   #20
DNAsEqUeNcE
†John3:16
yah, the 2 EGR pins. they shouldnt have the hardware, so solder the outputs to the legs (but dont lift them, they break)
I see no reason to not be able to parallel up the LS1 coils to a mitsu igniter.. split the 12v out each way and have enough to trigger all 4, unless i'm incorrect in my assumption. correct me if I am wrong.
Old 11-02-2011, 10:19 PM   #21
boosted12a
weapon of mass detonation
boosted12a's Avatar
bret, wahat wire did you solder the tach output to? did you leave the stock ignighter in place? what post numbers are the egr pins?
91 940 SE, 119K, GOLD
05 S80 2.5T, RED
09 XC70 3.2L wifes gas sucking DD, BLUE
04 GTI VR6 (6 gears of fun) Silver
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
07 Suzuki SV1000S, BLACK, but turing white slowly
boosted12a is offline   Reply With Quote
Old 11-02-2011, 10:39 PM   #22
malloy1
malloy1's Avatar
From this post: http://forums.turbobricks.com/showth...t=75838&page=2
EZ116K:
1: OBD diagnostic socket (in some markets: serial interface)
2: Coolant temp sensor
3: Check Engine Light output, shared with ECU pin 22. Signals: 12-off, 1-on
4: PRE-IGNition, output to ECU pin 28. Signals: 0-Preign, 6.5-stable, 12-knock
5: 12v supply, constant
6: 12v supply, switched
7: Throttle idle switch
8: Load Signal Tq, from ECU pin 25
9:
10: Engine speed sensor
11: Engine speed sensor (shield)
12: Knock sensor (shield)
13: Knock sensor
14: EGR, Ground connector on engine (power ground)
15: EGR, converter, control
16: Igntion amplifier drive, trigger
17: Engine speed signal output. Signals: 6.5-cranking, >8-idle
18: Selector wire. Signals: 5v-disabled, grounded-enabled
19: Selector wire. Signals: 5v-disabled, grounded-enabled
20: Ground connector on engine (signal ground)
21:
22: EGR, temperature sensor
23: Engine speed sensor
24:
25:
Looks like 18, 19, 21 and 25 has something to do with timing advance/retard, so those should be not used. That leaves 9 and 24 as empty, but who knows if they don't go anywhere inside the EZK box (the post shows them as grounds)? Three pins are EGR pins (14, 15 and 22), so looks like those three can be used as wasted spark output for non EGR boxes.
Paul
Old 11-02-2011, 10:51 PM   #23
boosted12a
boosted12a's Avatar
thanks paul!
Old 11-02-2011, 11:44 PM   #24
DNAsEqUeNcE
†John3:16
I used a mitsubishi (mazda 1.6l miata) J702T ignitor, and the tacho output pin off of that wired directly to the volvo tach.
Old 11-03-2011, 12:11 AM   #25
malloy1
malloy1's Avatar
Probably best to post this over here too on the J702T ignitor:
OC1 Output coil bank 1 (to 1-4 side of your coils)
IB1 Ignition bank 1 (from buchka spark 1-4
VB Voltage Battery 12+ switched
TAC Tacho output straight to your 240 tach if miata unit, IF dsm unit, wire in a 12+ pullup wire with 1k ohm resistor tied into tach line)
IGR 12+ passthrough (unused)
GND Self explanitory
IB2 Ignition input 2 (to 2-3 side of your coils)
OC2 Output coil 2 (from buchka spark 2-3)
How are you powering your coils? What kind of gauge wire should work?
Paul
