90volvo
- May 27, 2017
- Eldorado Springs Mo.
93 volvo 240 automatice sedan. Car wont start, turn over, click or anything. Battery good Ive tried 2 good batterys that start my other volvo. Plus they have been load tested. So for testing reason is there a way to go around the nuetral safety switch. They shifter is awlful loose. I know I should check and see if starter getting a signal from the key switch. But when you dont have anybody that willing to drive to your place its hard to accomplish that.
The car has been fine. Came out this morning and nothing. All other acc. work. Lights, windows, gauges, can hear fuel pump kick on for a second. I did check grounds, starter bolts, the 4 fuses on the battery. thanks
