Old 06-08-2018, 12:58 PM   #1
105Charlie
Default 940 engine swap idle running high?
Hi guys,
So I've swapped in a B200FT into my 343 and I'm experiencing a very high idle, no exact number as I've got no rev counter but i'd say it's probably 500 over.
I know as standard they run a speedo sensor so I should expect high rev after coming off the throttle but it's even at idle after 20 mins and warm.
It has on occasion dropped down a lot and almost sounded like it was stalling but it was simply because it was actually idling correctly.
Any ideas?
105Charlie is offline   Reply With Quote
Old 06-08-2018, 02:08 PM   #2
Maybe air leaks or TPS misadjusted.
Old 06-08-2018, 02:16 PM   #3
105Charlie
I thought TPS but that wouldn't explain it dropping to a low idle would it?
Any particular area there could be a leak? Can't see any currently
