#1 |
![]() I am converting my '84 245 from LH2.1 to LH2.2 with EZK117, eventually buying the full harness conversion from Dave Barton. I have a question about two AMMs I found at my local junkyard. Both are Bosch P/N 0 280 212 007 required for the conversion, however, when looking at the 6-pin terminals, one has 3 adjoining terminals at one height, while the other three terminals are lower (not seen in the image of the AMM on the left). You can see the one on the right's terminals are all even. Has anyone run into this, especially with the conversion harness from Dave Barton: http://www.240turbo.com/volvoharness...versionharness
Any help would be of great help! ![]() |
#2 |
#3 |
Honda CRV DD WTF
![]() I suppose if the pigtail makes good contact with the pins it should be fine. I would remove that cap off the adjustment screw in case the base AMM mix needs to be adjusted.
1. 86 244DL- 1st car & owned for 16 years, 25mm sways, back to stock springs w/ KYB shocks, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC 2. 87 244DL - Sister-in-law's DD 3. 93 244DL - Step daughters DD 4. 84 242DL - Next project car My feedback thread |
#4 |
![]() Thanks for the reply, holtzboy. And yeah, the cap I am sure will be coming off when I get the new harness installed and finally get it resurrected.
#5 |
![]() I'd guess that it's a manufacturing defect. Staggered pins on connectors are only used when the connectors will be hot-swapped -- the longer pins are usually ground so that ground is connected before anything else when inserting, and ground stays connected after everything else when disconnecting.
You might try very gently pulling up on the lower pins to see if they move and snap into place. |
#6 |
![]() Join Date: Dec 2006
![]() They just look bent down a little to me, not shorter. Maybe it's the angle.
1988 245 White slicktop M47 Wagon! 2.5L NA 8v going in. 1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 548K MILES 1991 740SE B230FT NPR Strut braces IPD bar A cam 550cc EV14's. 3.73 G80 M90 to put in. ![]() |
#7 |
forced instruction
![]() Exactly.
Jetronic is romantic. - '94 965 - D̶2̶4̶T̶I̶C̶, then M̶5̶0̶B̶2̶5̶ now OM606.962. - '90 744 turbo 16 valve LPG - B204GT/M90 - trophy w̶i̶f̶e̶ car. - '89 764 B280F - Daily barge. - Various 740's, 940's, 960's and a couple of 760's. |
#8 |
![]() Need a picture showing the pins facing the camera.
Trying to understand stupid people is like trying to pick up a turd by the clean end. |
#9 |
![]() Again, thank you all for the replies. At bobxyz, I did try to pull gently on the pins to no avail. Here is the image with the pins facing the camera:
[IMG] ![]() I found a good distributor needed for the swap, so now only need the harness. I really want to buy the harness from Dave Barton's site, but will not be able to afford it. Has anyone had any luck piecing together a harness for the conversion. I suppose you would need harnesses from a 240 with LH2.2 and a 740 with the EZK117 ICU? Here is an image of the pieces I have for the conversion. My LH2.1 has just been too much of a headache: [IMG] ![]() |
#10 | |
![]() Quote:
I recommend separating the power stage from the heatsink (2 screws) and cleaning both sides and reapplying some thermal paste between the two. The powerstage does generate a bit of heat under normal operation and it is important to have a good connection to the heatsink. The one that I took apart essentially fell off the heat sink when the screws were removed. The thermal paste was very deteriorated. I used this thermal paste with good results: https://www.amazon.com/Arctic-Silver.../dp/B0087X728K Last edited by oldschoolvolvo; 06-11-2018 at 01:25 PM.. |
#11 | |
![]() Quote:
#12 |
![]() The EZK harness and the LH harness are essentially two separate harnesses except for a few wires.
Here is some info: http://www.turbobricks.org/forums/sh...d.php?t=329863 ![]() |
#13 |
![]() Here's one thread - I don't know how accurate it is, or if enough pictures are still left:
LH 2.2 to EZK117 - My article addendum |
#14 |
![]() This is perfect, everyone... just what I was hoping for. Most appreciated.
Thread Tools | |
Display Modes | |
