Old 02-04-2013, 06:46 PM   #51
Jush
Jush's Avatar
OK, Yes, the picture did all the justice, I am a complete idiot -_-
sorry...
I just quite forgot that the transmission was a different part, I had a total brain shut down I guess...
1987 Hilux 2wd
1981 Rx7
Jush is offline   Reply With Quote
Old 02-04-2013, 11:29 PM   #52
Lord_Athlon
Just damn
Originally Posted by Mueller View Post
What?
I wasnt serious mueller.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 02-21-2013, 02:13 AM   #53
dieselboy
Whooty patrol
dieselboy's Avatar
Originally Posted by Karl Buchka View Post
With the help of a couple of other tbrickers I'm making slow progress on my own version of a coil on plug conversion board. I'll update this thread as soon as I have something to report on.
Here's a picture of the prototype I made a few weeks ago:
What happened to this?
'82 242t hy35 @28psi, ebay header, big intercooler, microsquirt ecm, rsi stg2 cam, arp headstuds, tremec tko600, 3" exhaust, 13" brembos, coilovers, saabspoiler, 245/40r17s, lots of yoshifab stuff.
'12 flex ecoboost "kats" car
'93 940 turbo lifted #trophyvo
'08 f350 4x4 v10 cclb
'97 f-350 4x4 offroad toy
'94 4700 dt466 International toterhome build
dieselboy is offline   Reply With Quote
Old 06-06-2013, 07:50 AM   #54
Ex850R
Ex850R's Avatar
Default Bump
Inded , what has happened to this? I think i want one!
Ex850R is offline   Reply With Quote
Old 06-06-2013, 09:17 AM   #55
jnderr
jnderr's Avatar
A little update from the Buchka Engineering facebook page.
https://www.facebook.com/photo.php?f...6383890&type=1
07' XC90, 00' V70' - Dailies
67' Amazon Wagon
jnderr is offline   Reply With Quote
Old 06-08-2013, 05:26 AM   #56
Beachee
Beachee's Avatar
This I like, Karl!! Count me in for a few of these, when you get it right. :-)
Beachee is offline   Reply With Quote
Old 09-05-2014, 07:48 PM   #57
slovo240
slovo240's Avatar
Originally Posted by Alex Buchka View Post
Mounting it straight up with a 960 oil pan, power steering rack, and unmodified fire wall is questionable. It's absolutely possible and doesn't present any issues except for the fact that the motor ends up very far forward. Far enough to where your fist would easily fit between the back of the head and the fire wall. Now that I think about it, the distro might actually still fit if you go this route. Personally it's way too far forward for my taste.
I say either keep it tilted and bolt on the 960 stuff or hack up the firewall and make everything from scratch like karl and I are doing.
hacking the fire wall is going to be the best look I think.
the areo dynamics of a brick .. i get it ,hahaha
1980 Volvo 244 b230ft k-jet
1989 Volvo 740 turbo just the body. hmm body lift?
old beat up short bed truck. good frame.
slovo240 is offline   Reply With Quote
Old 11-17-2014, 10:59 PM   #58
Ghettobird
Ghettobird's Avatar
Regarding ignition and keys, How have people tackled starting and imobilisers?
My first assumption was to keep the 240's keys and all, but im not sure if its that simple
The parts car I have (1998 C70) only came with 1 key and 1 FOB which is hardly Ideal
Ghettobird is offline   Reply With Quote
Old 11-18-2014, 12:44 PM   #59
BrianB
BrianB's Avatar
There's a tone ring that sits on the circumference of the ignition tumbler.
Translation:
There's a ring that sits on the ignition tumbler that reads a code from the ignition key. You can't adapt this to a 240, unfortunately.
So 1998 and newer you'll need to use a custom EMS.
Brian Bradford
Tri-Cities, WA
Present Cars:
A 1997 Volvo 965
"Dan'l Webster"
BrianB is offline   Reply With Quote
Old 11-18-2014, 01:01 PM   #60
justlie
In the US that starts with 99. 98 does not have a chiped key.
1993 Volvo 940 Turbo - B230FT + 16V - M90 - MS3x - HE351CW - Methanol injection - Ford 8.8
1980 Volvo 242 GT - B5254T - M90 - MS3x - HE351CW - 17Z - E85
justlie is offline   Reply With Quote
Old 11-25-2014, 09:21 PM   #61
Ghettobird
Ghettobird's Avatar
On closer inspection, it is indeed a chipped key -_-
I dont see how I wouldnt be able to adapt it though, I could almost rip a chip out, permanently mount it in the coil somewhere in the dash and keep the standard 240 key electronics mated to the c70 loom?
[IMG][/IMG]
Old 11-26-2014, 03:06 AM   #62
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Not sure the benefits outweigh the pain of using a stock ECU in your application. I think it's way easier to use an aftermarket system rather than getting eyeballs deep into stock immobilizer crap.
Old 11-28-2014, 11:34 PM   #63
Ghettobird
Ghettobird's Avatar
Thats true, IIRC this should be the only issue? Or am I missing something else big?
Old 11-29-2014, 03:25 AM   #64
LloydDobler
LloydDobler's Avatar
I'd ask the ME4.4 tuning guys over on Volvospeed if they can kill the immobilizer on ME4.4 cars, those guys have figured out a ton of stuff on that engine management system. The '98 came with and without the immobilizer so it might actually be as simple as jumpering some wires as well.
If it was an ME7 car I'd say kill yourself before trying to bypass the immobilizer, as it was done over the CANBUS.
Aaron (tightmopedman9) over there has also figured out how to adapt the S90 coil on plug system into the 5 cylinder application, so it's all factory.
'66 122 - Collectible project
Old 12-02-2014, 07:20 AM   #65
Ghettobird
Ghettobird's Avatar
The immobiliser can be easily disabled via flashing of a modified .bin
Converting to COP is also quite easily done by converting to the later M4.4 ecu, aquiring ME7 coils, asking Tightmopedman9 nicely and working a bit of his magic
How much of the loom can I remove and still be able to run the engine off stock management?
The 240's are pretty basic, so there isnt too much that would need to be rigged up, Would the car run perfectly fine without the c70's dash, climate control and extra bits hooked up?
The plan is also to have functional AC, from the diagrams that ive seen, I should be able to get away with tapping the AC clutch relay to the original 240 AC switch and that should be that... obviously no climate control, but it would work
Old 12-02-2014, 02:12 PM   #66
hdBattousai
sweet i was considering pulling my t6 from my 960 and tossing it in a 240, subbed
hdBattousai is offline   Reply With Quote
Old 12-03-2014, 01:31 PM   #67
LloydDobler
Because of your questions, and because I'm planning the same thing soon, I've been digging in to the wiring diagrams. It looks pretty straight forward to me, in terms of just disconnecting what you don't want and cutting it out of the harness. Get the right power to the right places and you should be golden.
Like on the 98 there is no CANBUS so out of the ecu there's a tach signal, temp signal, CEL signal, oil light, stuff like that. I haven't figured it all out yet but I haven't seen anything that throws any big red flags. I think making the tach work will probably be the hardest thing. Assuming you want the tach to look stock.
Old 12-04-2014, 07:42 AM   #68
Ghettobird
Ghettobird's Avatar
Welcome aboard Lloyd!
Thats very comforting to hear, I just pulled part of the Coil loom out of a 2000 car for my COP conversion, which sparked me to really start thinking about the wiring and how it daunted me
From what ive seen, people tend to leave the engines temp signal alone and tap the thermostat housing to fit the 240's temp sensor... more stock components means less guesswork, or so im told
Knowing I can get info like oil, coolant and CEL signals is awesome too
Tach signal to stock dial would be great too, but how
Old 04-10-2015, 12:20 AM   #69
Ghettobird
Ghettobird's Avatar
What are people using for clutches?
Im hoping to go down the T5 route, Volvo Pressure plate and possibly the Ford clutch disk in the middle?
Karl​, Buddy READ MY MESSAGES
Ive been waiting over 6 MONTHS for my parts and you no longer respond to my messages?
Ive had to message people all over the forum to find out what the hell is happening.
Id like my parts Karl, Ive paid a LOT of money for this stuff and id like it SOON
Old 04-10-2015, 12:55 PM   #70
Mueller
Mueller's Avatar
I'm going to see his brother for sure on Sunday, it would be nice to ship all those parts AND an adapter plate at the same time!
I'll ask him if I remember...
Old 04-10-2015, 07:25 PM   #71
Ghettobird
Ghettobird's Avatar
@Muller
I feel like a complete asshat having to resort to this
I just got off the phone with SpecClutches and they say they've been doing Volvo pressure plates with ford disks for ages now!
Is there anything available as a kit?
Or atleast with info on what bolts to get?
If so I rekon Ill have to get one of your plates!
Old 05-31-2015, 03:22 AM   #72
Ghettobird
Ghettobird's Avatar
Anyone had any luck sourcing a T5 adapter plate?
Old 08-09-2016, 05:10 PM   #73
Leon_pp
Anyone try a Ford Focus ST inlet Manifold instead of modding a Volvo one?
http://www.ebay.co.uk/itm/Ford-Focus...wAAOSwSHZWcVF5
File Type: jpg d88c766134a025c6b563c51e837d1bad966c080a.jpg (26.6 KB, 344 views)
Leon_pp is offline   Reply With Quote
Old 08-12-2016, 02:35 AM   #74
LloydDobler
Interesting idea, if the bolt pattern is the same then it'd be a possibly good option. It's so close to the head though that I worry it'd hit something. Also it might interfere with the thermostat housing as that's moved on the compact T5 motor as well.
If I can get my hands on one I'll try it. I hang out at a local Volvo shop sometimes and they sometimes have junk engines lying around that they let me scavenge parts from.
And that's not a Focus manifold, that's the Volvo manifold from any turbo P1 Volvo.
Old 08-13-2016, 07:34 AM   #75
740atl
educator monkey
740atl's Avatar
well.... does the ford unit bolt up to the volvo head?
