Old 03-13-2018, 09:25 AM   #26
intothelabyrinth
intothelabyrinth's Avatar
I wouldn't think so...
1986 245 Auto (RIP)
1986 245 Auto (RIP)
1988 245, M47 (My Daily)
1989 245 Auto California Car
1999 V70 T5 Auto (Girlfriend's Daily)
brokedownbrick.wordpress.com
intothelabyrinth is offline   Reply With Quote
Old 03-13-2018, 01:24 PM   #27
rporzio
rporzio's Avatar
PM sent to you centason, question about the airtex. Thanks.
Ralph
1984 242 DL (Phase 7 maintenance and upgrades underway)
http://242vision.clearascent.com
2007 S80 V8
rporzio is offline   Reply With Quote
Old 03-13-2018, 01:31 PM   #28
Originally Posted by rporzio View Post
I'm also wondering about my sending unit. Purchased and installed back in 2010 during the original resto we never heard of reversed wiring from the vendor. Would the fuel system have worked so long before starting to fail if the wiring was reversed? R.
Going by the price you paid for the replacement sending unit, you probably got a VDO which were wired correctly. The aftermarket senders were usually under $100.
image courtesy of cleanflametrap.com
Old 03-13-2018, 01:37 PM   #29
rporzio
rporzio's Avatar
thanks hiper, I did see that pic. Just went out and started the car with the wires to the in tank pump reversed with clips but it didn't make any difference. Tomorrow I'll start looking at the grounds in different locations. R.
Old 03-13-2018, 02:45 PM   #30
oldschoolvolvo
oldschoolvolvo's Avatar
I’d pull the hose off of the input to the main pump, jumper the fuses to turn on the tank pump and see if the tank pump moves any fuel. If you hear it running but no fuel is coming out of the hose, then try switching the + and - wires to the pump and redo the test.
Edit: never mind, I see you’ve already tested for actual fuel flow
-Mike
1998 V70 T5
|Feedback|
Old 03-13-2018, 03:32 PM   #31
centason
Knipex=welfare queen
centason's Avatar
Got nothing from you.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Old 03-13-2018, 03:34 PM   #32
Clean the ground and make sure all connections are good. Poor connections could burn stuff out. At the fuel pump relay and power wiring too.
Old 03-13-2018, 04:16 PM   #33
rporzio
rporzio's Avatar
Thanks Zvolv, do you know off hand exactly where the ground for the fuel pump relay is and what terminal it connects to? Left of the shifter on the driveshaft tunnel? Ralph
Old 03-13-2018, 04:49 PM   #34
It's under the back seat. You can do a voltage drop test on it to test it.
I thought it was in this pic, but nope. Here is one way to check current draw of the pump with a scope and amp clamp. Without one, you could just put a meter in line with the circuit and see whatcha get.
Old 03-13-2018, 05:13 PM   #35
rporzio
rporzio's Avatar
Wow, way back there? I figured it would be up front under the dash somewhere near to the relay itself. Tomorrow, I'll start looking at these connections. I really appreciate your help! R.
Old 03-13-2018, 05:19 PM   #36
He's talking about the main fuel pump ground. The ground for the relay is on the tunnel.
Old 03-13-2018, 05:23 PM   #37
Resistance test the ground wire is a good idea too. Inspect for chafing or bad wiring under the car too.
Old 03-14-2018, 06:36 AM   #38
rporzio
rporzio's Avatar
before I dig in and start my troubleshooting I want to let everyone know that every time we change out the pumps the car runs fine for a few days before the external pump starts making noise and eventually the car fails. Right now the car is running and driving fine except for the main pump whining and the relay slightly vibrating so wouldn't that lead us to believe that it would be something wrong inside the tank like the rust mentioned before or the sending unit power reversal issue? Why run fine for awhile and then die consistently and after changing out the pumps the cycle repeats? Things that make you pause and say hmmmm... Ralph
Old 03-14-2018, 09:33 AM   #39
RacerX
Did you replace any hoses during the process? A kinked hose will starve, then kill the Main Fuel Pump.
A replacement fuel sender had a different angle and eventually kinked on me.
RacerX is offline   Reply With Quote
Old 03-14-2018, 09:40 AM   #40
rporzio
rporzio's Avatar
thanks racer, yes at one point we did have a problem with the hose on the in tank pump. I just jumper tested both pumps and heard them both start so next I tink id like to try and find the ground to the pump relay and after that try to take the sender unit out myself to see what I can see, especially since you mentioned a hose issue... Ralph
Old 03-14-2018, 10:04 AM   #41
rporzio
rporzio's Avatar
Before I go much further will you all correct me if I'm wrong? Didn't I just test the grounds for both pumps by jumping power at the fuse panel to each one and make them spin? If ground wasn't present at either site they wouldn't have turned on right? R.
Old 03-14-2018, 10:45 AM   #42
TestPoint
TestPoint's Avatar
A corroded ground will reduce the voltage and current to the motor.
Ford V8 Conversion Manual -
Old 03-14-2018, 11:00 AM   #43
intothelabyrinth
Ground may be present, but is it a GOOD ground? That is the question you answer with the resistance tests... Sometimes you could have a marginal ground, you can test and find 12 volts, but then find out later that it wasn't quite good enough to carry the amps needed. Think of it like a water pipe... it could be blocked by 80% and you would still see some flow out the other side. If you don't measure the volume and just check that there is some flow you aren't really seeing the whole picture.
Old 03-14-2018, 11:09 AM   #44
intothelabyrinth
A quick and dirty way to see that you do indeed have enough real current able to flow is to use a brake light or similar incandescent bulb wired up as a test light. They pull a good amount of amps, so if it lights up as bright as it should you can be pretty sure you are getting not only voltage, but also enough current...
Old 03-14-2018, 11:11 AM   #45
intothelabyrinth
That relay clicking on and off has got to be the root of the problem. It is either the relay itself, or the wiring.... have you re-flowed the solder on all the connections inside the relay yet?
Old 03-14-2018, 11:21 AM   #46
JohnMc
JohnMc's Avatar
/\ /\ /\ I'm not quite sure what the clicking relay is doing to the current flow to the pump, but it can't be good.
I know sometimes people run a varying duty cycle to a fuel pump so it's not pumping LOADS OF FUEL when it doesn't need to, but that's usually at a much higher frequency. If the relay clicking is at a much lower frequency where the pump mechanically speeds up and slows down constantly it could be overstressing it.
Clicking relay would seem to be an issue with the circuit that powers the relay, not as much to do with what the relay itself is turning on and off (the fuel pumps).
Last page of this PDF: http://www.volvowiringdiagrams.com/v...240%201984.pdf
Shows the relay getting switched 12V+ on one side of the relay (terminal 86) from the ignition switch, and the ECU grounding the other side to turn on the relay (terminal 85 on the relay, goes to terminal 17on the ECU). That is the circuit that turns the relay on and off, if it's buzzing, it's either issues with the switched 12V coming to #86, or the ground to the ECU from #85, or an internal fault in the relay itself.
As a quick and dirty test, I'd use a jumper wire and ground #85 when the car is running, and the relay is buzzing. See if the buzzing stops. If so, there's some sort of issue either in the ECU, or in the wire between relay terminal 85 and ecu 17.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-14-2018, 11:26 AM   #47
rporzio
rporzio's Avatar
That's excellent advice (and exactly what I was looking for with the ground), thank you. I'll try that this afternoon. The relay is not buzzing so loud as to make a noise but I can feel it vibrating with a touch. R. We're talking about the ECU in the passenger foot well correct?
Old 03-14-2018, 11:27 AM   #48
intothelabyrinth
As far as I know this relay just runs the pumps constantly when the car is running. Any excess fuel is just recirculated back to the tank... If the relay is clicking it is turning the power on and off to the pumps...
Old 03-14-2018, 11:30 AM   #49
JohnMc
JohnMc's Avatar
I wasn't trying to say that Volvo is using a duty cycle to reduce the pump output, just that sometimes on high-performance cars with huge pumps they run the pump on a reduced duty cycle without harming the pump. But in this case, the problem with the relay may be doing it at a low enough frequency to damage the pump. It was a pointless sidebar.
Old 03-14-2018, 11:50 AM   #50
intothelabyrinth
Got ya.
