Old 05-18-2018, 01:07 PM   #126
oldschoolvolvo
oldschoolvolvo's Avatar
I don't see why not...something like a DW100 should work great.
-Mike
1998 V70 T5
|Feedback|
Old 05-19-2018, 06:56 AM   #127
rporzio
rporzio's Avatar
This is the pump you're talking about? Are there any install issue or mods for compatibility?
Ralph
1984 242 DL (Phase 7 maintenance and upgrades underway)
http://242vision.clearascent.com
2007 S80 V8
rporzio is offline   Reply With Quote
Old 05-19-2018, 08:46 AM   #128
M.H. Yount
M.H. Yount's Avatar
That's it Ralph. Your mechanic will have to navigate the plumbing associated with removing the under-car/in-line pump and replacing it with hi-pressure efi rated hose from the outlet of the pump/sender assembly to the hardline exiting the pump you'd get rid of. Also may want to look at wire size for that circuit. The single in-tank will pull more current than the current in-tank pump. I just pulled the hot wire from the in-line pump into the passenger compartment and extended it into the trunk - tied it in with the other hot wire for the in-tank pump. Plenty of current carrying capacity in those two circuits to support the single pump in the tank.
If you think you might ever re-power the 242 --- then now would be the time to go ahead and put a bigger pump in the tank. I use the DW300 on mine.
Old 05-19-2018, 01:47 PM   #129
rporzio
rporzio's Avatar
Thanks Mike. Does the DW100 mount to the sender unit without any mods?
Old 05-19-2018, 02:34 PM   #130
M.H. Yount
M.H. Yount's Avatar
I had to slightly enlarge the plastic clamp that the OEM unit uses. I don’t know if the 100 and the 300 are the same diameter or not. And, of course, make up the wiring connections. Remember - the current hose from the pump output/tank to the suction side of the inline pump is not rated for the higher pressure you’ll see if you go with just the intank replacement pump.
Old 05-21-2018, 08:54 AM   #131
rporzio
rporzio's Avatar
Thanks Mike, I now have this pump on my Amazon Wishlist should it come to that. Haven't been able to get him out with all the rain and this week looks to be the same. R.
Old 05-22-2018, 10:58 AM   #132
rporzio
rporzio's Avatar
I just bought and installed a new gas cap, something I didn't think of earlier... Who knows. Next I'm going to replace all the vacuum hoses entering and leaving the charcoal filter/cannister and see if i can tell whether the valve on top is operable. If not, I'm also looking at an updated version to replace it with...
Old 05-22-2018, 12:12 PM   #133
M.H. Yount
M.H. Yount's Avatar
You don’t have the canister hooked to the intake, right? Had them put that back to disconnected?
Old 05-22-2018, 12:19 PM   #134
rporzio
rporzio's Avatar
It's been reconnected for awhile. Are you thinking I should try my test drives (weather permitting) with both vacuum hoses disconnected?
Old 05-22-2018, 12:29 PM   #135
M.H. Yount
M.H. Yount's Avatar
No! If it’s not building pressure or creating vacuum in the fuel tank - don’t start changing another variable.
Old 06-09-2018, 07:13 AM   #136
rporzio
rporzio's Avatar
Rain finally let up enough to get him out for a longer drive, 100 miles round trip. Ran really good but the pump was whining pretty good at the end of it with no failure. I finished changing out all the rubber vacuum lines for the charcoal cannister and even replaced it as well as the purge valve. The next step I guess is to install the Bosch unit I have on hand and see if it too makes noise then decide whether to go to the single in tank pump. One of my stops netted me a really nice parking spot in the shade and naturally out comes the Android camera; here's one...
Old 06-09-2018, 09:49 AM   #137
M.H. Yount
M.H. Yount's Avatar
Purdy!
