Old 05-24-2018, 10:45 PM   #76
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
Originally Posted by bmdubya1198 View Post
The ECU not being fastened to its bracket wouldn't cause any problems, right? The body of the unit isn't used as a ground?
Nope, itís grounded through manifold I think. I thought the same thing but for testing purposes Iíve left them hanging on the floor with no issue at all.
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
PromiseRing is online now   Reply With Quote
Old 05-24-2018, 10:46 PM   #77
bmdubya1198
Awesome, just making sure I wasnít overlooking anything on that end.
1998 V70 GLT Black/Beige
2000 V70R Venetian Red/Black M56 swapped
1988 744 TI M46 "Goldilocks" Gone but not forgotten
bmdubya1198 is offline   Reply With Quote
Old 05-25-2018, 05:02 PM   #78
bmdubya1198
Got some new info...
I tested the ECU terminals one by one per the typical values document from volvowiringdiagrams.com. I noticed some issues...
At pin 9 while cranking, my meter shows 7-8 volts. It's supposed to be between 11-14V. Pin 17 is supposed to be between 0-1V while cranking, it was 5 volts. Pin 21 should be 11-14V key on, it was 1.6V.
Those are the values with my spare ECU. My original one had even more values that were incorrect (like 12V on pin 19, a ground wire) but those 3 above are the only ones that concern me.
My original ECU showed the same reading on pin 9 while cranking, 0.05V while cranking on pin 17, and 0.51V on pin 21 with key on.
Interestingly, all of those pins are related to the fuel relay. Probably related to the lack of ground on pin 13.
I tested once again for injector pulse with this ECU and sure enough, nothing. The readings I got could have been low because of the battery, but the other things that were supposed to be 11-14V were within range. The battery was still over 12 volts.
The throttle switch signal on pin 12 seemed off too, but that may be a bad switch for the WOT signal. It showed 0.31V both with the throttle closed and and fully open. It's supposed to be 0 fully open and 5V closed. I'm leaning more towards the fuel relay pins being the main issue.
Is this still the ECU, or is it a wiring issue? Or a problem with the fuel relay itself? The relay looks to be working just fine, so maybe I just have two ECUs that failed in different ways, or I just have an issue with the wiring at the fuel relay.
Old 05-25-2018, 05:04 PM   #79
bmdubya1198
I'll go ahead and add what those pins show on my LH diagram/pinout...
Pin 9 is the ECU power supply from the relay (low voltage, could be an issue)
Pin 17 is control signal to fuel relay
Pin 21 is control signal to main reay
Old 05-25-2018, 07:31 PM   #80
PromiseRing
I’m not saying your ECUs are for sure good, but the odds of 2 very reliable ECUs both being bad is very slim. Unless of course they were thrown in a pool or something?
Also, the fuel pump relay is easy enough to swap out, have another laying around? Takes about 30 seconds. Try a couple different ones.
But also if it for sure doesn’t start on starting fluid then you have issues. Are you 100% sure the engine is timed correctly?
Old 05-25-2018, 08:22 PM   #81
bmdubya1198
Iím not saying your ECUs are for sure good, but the odds of 2 very reliable ECUs both being bad is very slim. Unless of course they were thrown in a pool or something?
But also if it for sure doesnít start on starting fluid then you have issues. Are you 100% sure the engine is timed correctly?
I am not. I havenít messed with the ignition timing since putting back the distributor after replacing the hall sensor. As for the cam and crank, they are aligned.
I have one somewhere, but I donít think itís good. Iíll have to grab another fuel system relay to have as a spare. I have 3 for my P80s.
I had the same thoughts about my ECUs, but the discrepancies between the readings lead me to believe it may be an issue. But the fuel relay-related issues are probably not ECU-related.
Old 05-25-2018, 09:27 PM   #82
PromiseRing
Hm maybe try putting the distributor right in the middle and see if it starts off of starting fluid. I’ve never messed with 2.2 but I’m pretty sure you can just adjust ignition timing like normal right? Not so much the case with 2.4.
Old 05-25-2018, 09:42 PM   #83
bmdubya1198
As far as I know you can do that. I’ve been meaning to adjust it.
Old 05-25-2018, 09:46 PM   #84
PromiseRing
If it’s timed correctl, getting spark, has compression, no reason it shouldn’t start off of fluid. You should disconnect the AMM when starting off of fluid, and spray directly into the TB
Old 05-26-2018, 08:58 AM   #85
bmdubya1198
I'll mess with the timing today between these Florida style pop-up storms we've had non stop. I should be able to get it running on starting fluid.
Old 05-26-2018, 08:56 PM   #86
bmdubya1198
Tested once again for injector pulse while using a Y-jumper on the fuel relay, and I now have pulse!
Next problem... I do not have fuel at the rail. I pulled the return line from the fuel pressure regulator and there was nothing. I went ahead and changed the coupler line between the pump and filter (it was kinked, had a new one on the shelf), and there was no fuel at all there either.
I don't think my in-tank pump is running. Wouldn't the in-line main pump have enough power to pull the fuel? I checked and there is voltage at the connector for the in-tank pump, so I'm pretty sure it's dead.
Old 05-26-2018, 10:52 PM   #87
PromiseRing
Yes you can run a car with just the main pump. If you get a pulse using the y jumper, shouldn’t you have a pulse using just the regular fuel pump relay? Possible bunk relay?
Make sure fuel is in the car. Also, Idk if you should forsure have fuel on the other side of the regulator. It’ll only ‘open up’ if there’s enough pressure. How about busting the feed line loose at the rail and seeing if there’s fuel. Also, it should really be starting off of fluid lol
Old 05-26-2018, 11:16 PM   #88
Do you know how I get a full sized truck with a dead fuel system into the work bay? A wheel man and a guy under the hood spraying brake cleaner into the throttle body.
Old 05-26-2018, 11:20 PM   #89
Ether:
https://youtu.be/vzQxpwOHb0c
Old 05-27-2018, 09:14 AM   #90
bmdubya1198
Something's probably up with the relay. I don't know, maybe it's because I swapped to my newer ECU again and I hadn't checked for pulse with the relay.
I get it, starting fluid... I just adjusted the timing, I'll see if it starts today.
Like I said, there is no fuel getting through the lines to the rail. When I changed the fuel line between the pump and filter, it was bone dry.
Old 05-27-2018, 01:35 PM   #91
PromiseRing
Is there gas in the car?
Old 05-27-2018, 01:41 PM   #92
bmdubya1198
Turns out the in tank pump is running. The problem was my “assistants” being deaf...
According to the gauge, there is gas. I put a couple gallons in a while back, and they have not leaked out. Maybe there just isn’t enough gas? Which seems odd being that there’s probably 3-4 gallons in there.
Old 05-27-2018, 01:43 PM   #93
PromiseRing
If the hose in there is rotted or fell off it will starve.
Did it start off of starting fluid?
Old 05-27-2018, 01:53 PM   #94
bmdubya1198
I need to check that out. Havenít tried yet, will do that today.
Old 05-27-2018, 02:06 PM   #95
PromiseRing
Only takes 30 seconds dude just go do it
Old 05-27-2018, 03:24 PM   #96
bmdubya1198
Freaking fuel pump assembly looks like crap. Everything’s rusted and the fuel level sender portion seems to come apart into two pieces. I had the impression it would be a float on an arm, but I’ve seen differences before with this stuff.
Now I’m debating tracking down a full fuel pump/sender assembly, but I’ve got no clue where I’m going to find one for a reasonable price.
Old 05-27-2018, 07:30 PM   #97
bmdubya1198
Found a LOT of junk in the pump itself and the outlet line from the pump. I ended up just putting in the new Pepboys pump I grabbed this morning and cleaning up the lines on the fuel sender assembly. I probably could have reused the old pump, but with how much dirt and nasty stuff was in there, it made more sense to just replace it.
I had to use a straight fuel line instead of the accordion style hose that was there (it broke, and had a cut in it already) for now, but I plan to upgrade the fuel pump relatively soon after it's running so I'll change to the proper hose then. This car won't be a daily, so I'm not too worried about the fuel gauge not working temporarily.
Also, for some reason, there was no sock on the bottom of the old fuel pump. Maybe it fell in the tank? Or maybe someone
replaced the fuel pump previously and never put a sock on.
Old 05-27-2018, 08:02 PM   #98
PromiseRing
My cars sock fell off in the tank and was rusty as ****
Old 05-27-2018, 08:34 PM   #99
bmdubya1198
I'm going to go fishing for it tomorrow. I need to remove the gas first though, it's a nice rust color and smells like turpentine.
If it doesn't start after all this, it's going to find itself at the bottom of a cliff.
Old 05-27-2018, 08:38 PM   #100
Can play the blues
The small fuel line in the tank won't last more than a year or so if you didn't use submersible fuel line. I've done that but nowadays regular fuel line should be avoided if you can. Or just know that it is temporary. It's even more important these days since we have alcohol in the gas which eats up the rubber faster than just gas would.
