Old 06-07-2018, 02:18 PM   #176
bmdubya1198
Originally Posted by PromiseRing View Post
Okay makes more sense. So youíre getting a pulse, but no fuel is coming from the injectors? My guess is either insufficient fuel pressure or dead injectors
Yup. I checked the plugs too, bone dry, no fuel smell. I take it the injectors are dead. Went ahead and bought a set for cheap, those should be here in the next few days.
Mmmmm.....light shouldn't illuminate key off. Just blink while cranking. That sounds like your wiring is shorted to ground on that injector ground circuit. Remember that converstion???? I recall you saying you found bare wiring. Whatever happened with that!?
Replacing components when the circuit is no good is a bad move.
Current takes the path of least resistance. If you have a short to ground before the computer, most of the current will go thru the short instead of the ecu.
The joint where all of the ground wires from the injectors come together was peeled away, but I already taped it all up and made sure it was not making any contact with anything else. The rest of that wire was good.
What could cause the terminal to ground out with the key off?
1998 V70 GLT Black/Beige
2000 V70R Venetian Red/Black M56 swapped
1988 744 TI M46 "Goldilocks" Gone but not forgotten
bmdubya1198 is offline   Reply With Quote
Old 06-07-2018, 04:30 PM   #177
A short to ground in the wiring or the ECU. Unplug the ECU and see if it goes away.
Measure restsiamce between njector ground terminal and a good ground. It should be in the kilo ohms range. If its 0 ohms or anything lowish you have a short.
Old 06-07-2018, 05:34 PM   #178
bmdubya1198
It's about 453 ohms.
Old 06-07-2018, 05:54 PM   #179
Unplug the ecu and repeat.
Old 06-07-2018, 07:15 PM   #180
bmdubya1198
Open circuit. What's that about now? Dead ECU?
I guess that's a good thing actually, it means the wiring for the injector ground isn't grounding elsewhere.
Old 06-07-2018, 07:17 PM   #181
Can play the blues
She's a witch! She is made of wood and therefore will float proving she is a witch!
Old 06-08-2018, 12:32 AM   #182
Nah that's good. If you unplugged and still had continuity to grond i would be concerned..
Old 06-08-2018, 10:01 AM   #183
bmdubya1198
Okay, that's what I thought.
Old 06-09-2018, 07:21 PM   #184
bmdubya1198
She RUNS!!! Got the injectors today, and after cranking for a while (had to build up some fuel pressure) it finally fired up! I adjusted the timing a little bit and got it idling fairly smoothly. I still need to do a lot of work on the car overall, but I'm so glad to be past this huge hurdle.
Thank you to everybody who has contributed, PromiseRing and ZVOLV in particular who have been especially helpful recently. Any other issues I can't figure out will be in separate threads... 180+ posts is plenty!
Old 06-09-2018, 07:25 PM   #185
Can play the blues
Well done! Glad to see you got it running.
Old 06-09-2018, 09:17 PM   #186
bmdubya1198
Thanks, me too! Tomorrow I need to get the timing dialed in and figure out my shifter issue. Iím hoping itís just related to seized up linkages from the car sitting so long.
Old 06-10-2018, 12:11 AM   #187
iLoveTurdPeople
Awesome man!!
So it was really just bad injectors? All 4? How does that happen lol
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
iLoveTurdPeople is online now   Reply With Quote
Old 06-10-2018, 12:16 AM   #188
Mbeas96
Mbeas96's Avatar
Just when I started to think this thread was to long...haha congrats!! That is crazy though..
Old 06-10-2018, 09:54 AM   #189
bmdubya1198
Yeah, it it strange, but that's what finally got it running! It definitely needed a lot of the other things I changed, though, like the old ECU that wasn't allowing injector pulse. This car had to be sitting at least 7 or 8 years before I bought it. I don't believe for a second that the car was only sitting for a year, especially with how nasty the entire fuel system was.
This is one of the old injectors... they could have been pretty clogged, which may have been part or all of the problem there. But I don't think these were even firing. Maybe because of the PO's poor wiring of the ballast resistor.
Old 06-10-2018, 10:29 AM   #190
Awesome! Glad I could help. The $20 check is in the mail.
Old 06-10-2018, 12:01 PM   #191
bmdubya1198
Hahaha I was going to say...
