Old 06-01-2018, 05:35 PM   #1
Mbeas96
Mbeas96's Avatar
Default I'm not sure what to look for.. 1990 745 TIC
Car is a 1990 745 lh2.4 sbabbs chips fuel and ezk, 391cc @ 3.8bar t5 injectors, resistor pack bypassed. 16t 15psi
I'm just gonna say, I drove the cap outta this car all morning. From 10am to about 3 pm, in 100 degree
Charleston stop and go traffic. When I cut it off, I went to eat with the family. Come back out, go to start the car, no crank. No click. All lights are one, fp primes, but nothing happens. I jump the starter and it starts right up. Okay.
I start driving, it idles trying to keep 14.7 on my aem wideband, but I hit the gas, it pegs to 10.0. It'll climb back up slowly to 14.7, then it doesn't richen up till 8+ psi. Its supposed to go full lean when the car is engine braking, but it will go 16 - 17 when I hit the gas again after coming off the brake. It seems like the injectors aren't keeping up with what the throttle is doing? I rechecked my resistor pack bypass, which i dont feel like is easy to mess up...but it looks good.
I got a 2-3-2 code with no CEL light. Too rich or too lean? But where to start looking?
Old 06-01-2018, 06:11 PM   #2
Mbeas96
Mbeas96's Avatar
Startimg problem didnt happen again, at least not yet. Ive checked all connections by hand..wiggle test, and id say a quick check of air connections for boost/vac leaks. But it was fine all day till after lunch
Old 06-02-2018, 07:52 AM   #3
Mbeas96
Mbeas96's Avatar
So after the car sat for a while, cooled down, it had no issues on the drive home. This morning I decided to drive it work 60 miles, no issues at all. The afrs are back to normal and they ricjened up in boost like they should. The car has power again.
Is it possible it was extremely heat soaked/hot? Ny gauge didn't move, but I havent removed the "temp faker" plus my "overheat fan" that's connected to the switch in the radiator was on right after I had to jump the starter. It stayed on till i let the car sit.
Old 06-02-2018, 10:09 AM   #4
iHateVolvoPeople
Warm weather (or any extreme weather hot or cold) can make old cars act funny IME. If the problem went away, I’d forget about it for now
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 06-02-2018, 05:45 PM   #5
Mbeas96
Mbeas96's Avatar
Lol that's awesome....I think the goal now is to improve my cooling system to take the beating. it seemed to drove fine otw home as well. (No traffic cause its Saturday) I didnt get into full boost, but AFRs were good, and I didnt hear any pinging
Old 06-02-2018, 06:17 PM   #6
122power
dude
122power's Avatar
The starting might be your ignition switch or you might have a bad spot in your starter solenoid
Old 06-02-2018, 08:43 PM   #7
Mbeas96
Mbeas96's Avatar
Ill have to do some reading and see what happens in the next few days. It hasn't happened since, but electrical things, ive learned tend to be very intermittent and annoying.
Old 06-11-2018, 06:27 PM   #8
mark244turbo
mark244turbo's Avatar
Bad VR-sensor causes no starts when the engine is hot.
It can take a several hours before an engine cools down.
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings
mark244turbo is offline   Reply With Quote
Old 06-11-2018, 07:01 PM   #9
PCH
No crank after heat soak is usually because of the starter.
