Old 06-04-2018, 09:48 AM   #1
apico500
apico500's Avatar
Default Best oil for B20 engine
I have heard that synthetic oil is not good for the old engines, Just trying to figure out best oil for my B20 engine. Thanks
Volvo 1980 GT Project SOLD
http://forums.turbobricks.com/showth...12#post3961912
apico500 is offline   Reply With Quote
Old 06-04-2018, 12:45 PM   #2
Valvoline VR-1 racing oil has more ZDDP (zinc) than most engine oils as its designed for older flat tappet engines like the B20. Volvo recommends a multi viscosity oil, either 10W-30, 20W-40 or 20W-50 for summer driving but I prefer to use straight 30W.
Old 06-04-2018, 12:52 PM   #3
122power
dude
122power's Avatar
15w-40 works for me. Depends on your cam and what spring pressures you are running. The diesel oils still have some zddp in them.
122power is online now   Reply With Quote
Old 06-04-2018, 12:59 PM   #4
NONHOG
equal opportunity car guy
NONHOG's Avatar
Curious if Volvo says multi weight why do you prefer straight 30W?
Just about to help the boy with his tired B20 oil change.
Thanks
Old 06-04-2018, 01:04 PM   #5
John V, outside agitator
Fresh
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 06-04-2018, 01:08 PM   #6
Straight 30W is actually recommended for temperatures above 90°F.
It's my opinion (and mine alone) that 30W clings to the camshaft better than multi viscosity oils and provides better protection until oil begins to circulate.
Old 06-04-2018, 01:24 PM   #7
JohnMc
JohnMc's Avatar
Nothing wrong with synthetic at all, but it's somewhat wasted on an engine like the B20 which doesn't really have any unusual features that synthetic would work well for (i.e. a turbo that tries to coke the oil on hot shutoff).
As already mentioned, though, those lifters and cam lobes really need more ZDDP than modern car engine oil provides, because a little oil burning could otherwise foul a catalytic converter. So you could either add a little bit to whatever oil you do use (like a good synthetic) or buy oil that has more ZDDP in it already, like the VR-1, or some diesel engine oils (since diesels don't have the same sort of cat).
I just get a bottle of Lucas engine break-in additive, which is mostly ZDDP, and add part of the bottle in with each oil change:
Keep those cam lobes happy!
PS: Another odd thing about the B18/20 - is that the cam lobes really aren't directly oiled in any good way. Oil is pumped up into the head to the rockers under pressure, and then it drips down back into the sump via the lifter gallery, where it oils the lifters (which do not get any pressure oil feeds), and then presumably down past them and sort of onto the cam lobes?
I really think that the bulk of the oiling the cam lobes get is from crank windage - all the oil droplets flying around down in the bottom of the crankcase after being flung off of the rod bearings.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-04-2018, 03:03 PM   #8
c1800
Love these motor oil discussions.
A few comments.
As I understand it, racing oils have higher zinc and phosphorus that these older engines need but lack many other additives that extend the life of oil, since racing oils are intended to be changed after a few hundred miles, or less.
Indiscriminately adding ZDDP can result in too high a level which is actually disastrous for lifters and cams.
Zinc and phosphorus levels in the 1100-1300 ppm range are what’s needed. For conventional oil I use Napa All Fleet 15W-40, and synthetic, Mobil 1 15W-50, which both have the appropriate levels of Zinc and Phosphorous.
Synthetic oil can also do a good job of cleaning up internal deposits, but you may experience some increased drips and leaks.
Old 06-05-2018, 09:25 AM   #9
Brandonium
I use Swepco 306 in my International Scout and that engine reminds me of the B20. I'll probably use it in my rebuilt B20 but for now it leaks and burns it at a rate where I am not putting that type of gold in there.
2016 Toyota 4Runner Trail Premium
1971 Volvo 142e
1977 International Scout II
Wish List
Saab Sonnet III
1979 Toyota Landcruiser (FJ60)
Whatever else tickles my fancy.
Brandonium is offline   Reply With Quote
Old 06-05-2018, 10:15 AM   #10
Pillow
Sleazebag 7-9 Owner
Pillow's Avatar
Mobil1 for modern engines or anything with a Turbo.
15W-40 Diesel of older or air-cooled. Usually Shell Rotella.
Swepco products are wonderful, but hard to get and expensive here. Best trans fluid for manuals period. Blue gold!
#79WDP
Old 06-05-2018, 10:16 AM   #11
AndrewNance
Amateur hour!
AndrewNance's Avatar
Anything more viscous than water will be fine in a b20
'71 142
'80 245
Feedback
Old 06-07-2018, 10:37 PM   #12
c1800
Apico 500. What did you decide to use?
Old 06-08-2018, 03:57 AM   #13
hessam69
c1800 has got it right. There are lots of people who believe modern oils have low levels of zinc. Not true, there is enough zinc content to keep almost any engine happy in most available oils, flat tappet or not.
90 240
90 240
90 240 wagon
91 240 wagon
90 240 parts car (parts for sale)
86 240 parts car (parts for sale)
84 240 parts car (parts for sale)
92 940 parts car (parts for sale)
91 940 parts car (parts for sale)
79 244
74 164E
Old 06-08-2018, 12:46 PM   #14
apico500
apico500's Avatar
I'm going to go with either Valvoline 30W or Mobil 1. Going to read the labels and decide.
Old 06-08-2018, 02:24 PM   #15
c1800
[QUOTE=hiperfauto;5807009]Straight 30W is actually recommended for temperatures above 90°F.
From the 1973 140 owners manual.
Above 10deg F, 20w40, or 20w50.
https://volvo.custhelp.com/app/manua...ual/om_id/1905
Old 06-17-2018, 06:31 PM   #16
sjulier
A few comments.
Agree. Sufficient Zinc and Phos in a CJ-4/SM 15W40 for this engine..
1993 Classic Wagon Teal Green #1446/1600 140k
1993 Classic Sedan Teal Green #140/1600 153k
sjulier is offline   Reply With Quote
Old 06-17-2018, 06:37 PM   #17
MSGGrunt
I second Shell Rotella for the higher zinc content. I run it in my 240s as well as my E30 BMWs.
1969 Triumph TR6
1986 BMW E30 325E, Auto, 2-door coupe.
1989 BMW E30 325iX 5-speed
1990 Volvo DL 240 Auto
1991 Volvo 240 Auto
1992 Volvo 240 GL Auto
1993 Volvo 245 5-speed.
2015 Volvo XC60 Platinum
MSGGrunt is offline   Reply With Quote
