Old 06-04-2018, 01:44 PM   #1
NONHOG
equal opportunity car guy
NONHOG's Avatar
Default B20 fuel ine routing (pump to carb)
Looking at the fuel pump the line runs very close to the block then up near the valve cover over to carb. (Webber 32/36)
Thinking about keeping fuel as cool as possible. Does have hot soak issues.
I have a heat shield under carb already.
Love to see others routings or suggestions.
Thanks in advance!
Old 06-07-2018, 02:51 AM   #2
Jack
Banned
Jack's Avatar
Picture please
Old 06-07-2018, 06:47 AM   #3
AndrewNance
Amateur hour!
AndrewNance's Avatar
140s (or mine at least) had a little bracket that bolts to the thermostat housing so the fuel line is held behind the fan. But I wouldn’t guess heat soak in the line would cause any real issue.
'71 142
'80 245
Feedback
Old 06-09-2018, 04:15 PM   #4
NONHOG
NONHOG's Avatar
As it sits
Old 06-09-2018, 08:02 PM   #5
Jack
Banned
Jack's Avatar
http://turbobricks.com/forums/showpo...7&postcount=89
Old 06-10-2018, 02:21 PM   #6
NONHOG
NONHOG's Avatar
Thanks Jack! Pretty close to what I had. I just had more hard line. Wasn't as clean as I would have liked. Switching the fuel inlet 180. Shorter route and cleaner maybe? Time will tell.
