Old 06-04-2018, 05:31 PM   #1
Fred Gwynne
Fred Gwynne's Avatar
Default Will a 240 hitch fit a 780?
Does anyone know if the factory hitch on my 240 will fit a 780? Please let me know and I apologize if there is already a thread about this. I did search for the topic here and through google with no luck. Thanks very much.
Fred Gwynne is offline   Reply With Quote
Old 06-04-2018, 06:35 PM   #2
2manyturbos
No, not even close to fitting. If you want a hitch for your 780, I have a draw tight hitch that came off my 780 that I will sell.
Old 06-04-2018, 07:50 PM   #3
Fred Gwynne
Thanks I will keep that in mind. Right now I'm just giving some thought to a 780 for sale nearby to me. Does it happen to be a class III?
Old 06-05-2018, 02:53 AM   #4
2manyturbos
I can't remember. I'll check tomorrow.
Old 06-05-2018, 10:14 AM   #5
Fred Gwynne
Thanks
Old 06-06-2018, 12:45 PM   #6
benski
Post
You won't even want to come close to the capabilities a class 3 hitch has for your 780. Not even.
Old 06-06-2018, 05:57 PM   #7
2manyturbos
^^^ What he said. Class 3 is 1000 lb tongue weight, 10,000 gross weight towing capacity. The hitch I have is rated at 300 lb tongue weight, 3,500 lb gross weight. That is what a 7 series is supposedly rate at, according to Volvo.
Old 06-06-2018, 06:08 PM   #8
PCH
^^^And what is 200 series factory accessory hitch rating?
Old 06-06-2018, 10:17 PM   #9
Still class II.
[IMG][/IMG]
Old 06-11-2018, 05:26 PM   #10
PCH
Thank you. Wonder why 700/900 never have 2in sized receiver while 200 series are almost always 2in.
Old 06-13-2018, 06:13 PM   #11
benski
Post
Most class 3 stuff is at 500 lb. tongue weight, with a 5000 lb. trailer. Load-distributing hitches can typically go up to a 600 lb. tongue and 6000 lb. trailer. Not to try to make too fine a point of it, but you still don't want to be in a 780 with 5000 or 6000 lbs. hitched up behind you.
Old 06-13-2018, 10:13 PM   #12
DET17
Reformed SAABaholic
Anybody know if the 780 hitch / mounts are a unique animal? I've got the OEM 7/9 hitch setup that I'll be selling soon; just removed from my 92 745T where it was a true bolt on. This style with the rectangular receiver..... I'll have to read the serial plate to see what the hitch is rated at.
Old 06-13-2018, 10:28 PM   #13
2manyturbos
Yes, the 780 hitch is unique to a 780 because of the IRS. A straight axle 7/9 hitch will not fit a 780 and vise-versa.
