Old 06-05-2018, 05:44 PM   #1
283SD
Default Cranks no spark, no fuel pump
Drove my wife's 1990 245 into the shop with a check engine light. clearer the code , now it won't start,cranks but will not start. Check engine light does not come on with key in on position. changed the usual parts still no luck
Old 06-05-2018, 06:34 PM   #2
Can play the blues
I start at the fuse in the engine compartment. On the inner left fender. It is the main power fuse for the injection and ignition. A bad fuel pump relay can also do this. If the system side of the relay doesn't work you have a no spark no fuel symptom. My 93 recently had a bad fuel pump relay that caused a no spark no fuel. Also fuse twelve is involved in the power up process.
Old 06-05-2018, 08:38 PM   #3
283SD
Did that, also changed the fuel pump relay and checked all the fuses. the check engine light does not come on with the key on?
Old 06-06-2018, 07:21 AM   #4
283SD
Found the problem,one of the ground wires for the fuel injectors was loose. The bolt that I thought was tight was binding before it got tight.
Old 06-06-2018, 08:35 AM   #5
Damn fuel injector grounds!!!
Old 06-06-2018, 04:18 PM   #6
I found it very informative that the check engine light wouldn't illuminate. A certain member here calls those grounds "injector grounds." They are the grounds for the ECU, hence no CEL because your ECU has lost its' ground.
Old 06-06-2018, 06:13 PM   #7
283SD
Drove me crazy for 5 days, it started with a head gasket change, the bolt in question seemed tight but was .010 of contacting the fuel rail, didn't want to break it with more torque on the little bolt. That one ground was the cause of all the problems.
Old 06-06-2018, 07:26 PM   #8
Can play the blues
Good one. Sneaky little ground connections.
Old 06-09-2018, 09:47 PM   #9
Mbeas96
Mbeas96's Avatar
I found mine stripped when it popped out during a pull, made the car mis like crazy, afrs were all over the place. Retapped and used bigger bolts
Old 06-10-2018, 02:16 AM   #10
283SD
Car runs great so far, since fix, amazing what one wire will do to the elect system.
