Old 06-08-2018, 08:49 AM   #1
swedish-rocket
Default Transmission fitting leak.
I have a leaking transmission fitting. The 90 degree bend one that goes into the 5an opening in the transmission. Just seeing if you guys have an idea on what to use to fix it. It may need a new o-ring. Is there a specific o ring that you know of that fits correctly?
swedish-rocket is offline   Reply With Quote
Old 06-08-2018, 02:10 PM   #2
I doubt the threads are leaking, but maybe.
The flare on the fitting gets worn. Especially if it's been overtightened. Replace the fitting and may be the pipe too. Take a close look for distortion on both.
Old 06-08-2018, 02:15 PM   #3
https://www.tascaparts.com/oem-parts...o-ring-1233071
Old 06-08-2018, 06:23 PM   #4
300+hp on the shelf club
I also suggest using a thread sealant so you don't have to tighten the fittings so tight. Something like loctite 592 works well.
Old 06-08-2018, 10:45 PM   #5
swedish-rocket
I put in a new Oring and permatex thread sealant. I'm crossing my fingers. Thank you btw.
