Old 06-08-2018, 11:35 PM   #1
impolvo
Is always busy
impolvo's Avatar
Default Wheel bearing play
So I had to adjust one front wheel bearing 1980 262
It had 1/4 inch play
Fixed easy peasy
Other side has 1/16 inch play
Should i waste my time tightening it a hair
my feedback: http://forums.turbobricks.com/showthread.php?t=221335
Originally Posted by Stephen View Post
Thats why you get a mans car... A 740
Originally Posted by rancidponymilk View Post
You people keep crushing them, you're going to run out eventually.
impolvo is online now   Reply With Quote
Old 06-08-2018, 11:50 PM   #2
It's a roller bearing so it needs to have a tiny bit of play or it'll burn up if too tight or wear out if too loose.
Old 06-08-2018, 11:52 PM   #3
Jack
Banned
Jack's Avatar
You should repack them not just tighten and both sides
Old 06-08-2018, 11:55 PM   #4
impolvo
Is always busy
impolvo's Avatar
Yes I repacked the drivers side when resetting it
I just wonder if the 1/16 is acceptable or should go ahead and tighten and regrease pass side too
Old 06-09-2018, 12:01 AM   #5
Jack
Banned
Jack's Avatar
Old 06-09-2018, 01:30 AM   #6
MasterBlaster
Where are you measuring the "play"?
467,000 km so far...
Old 06-09-2018, 09:52 AM   #7
impolvo
Is always busy
impolvo's Avatar
To the top of the tire
Old 06-09-2018, 03:42 PM   #8
lummert
lummert's Avatar
http://www.popularmechanics.com/cars...a1139/4205243/
Old 06-09-2018, 07:38 PM   #9
impolvo
Is always busy
impolvo's Avatar
Yes I know replace in pairs
I did not replace the other side as it was in fine shape just tightened the castle nut a 1/4 turn
I guess Iíll do this side too assuming it looks fine
By the others condition it appeared they had been replaced recently
And just not fine tuned as I. The mechanic didnít want too tight
And they were left a little too loose
A
Old 06-10-2018, 10:27 PM   #10
impolvo
Is always busy
impolvo's Avatar
There tightened 1/16 a turn
