Old 06-09-2018, 10:22 AM   #1
MSGGrunt
Default Seat Base and Seat Heater Element Questions
The easy, I think, first. Where I have an extra driver's side seat base is there any reason I can't swap the base over to the passenger's side? The added benefit would be the easier adjustability of the driver's base.
Second question. Having stripped several driver's seats to find they had deteriorated foam bottoms and side bolsters I removed the heating elements before trashing the foams. This got me to thinking.
Can I use the extra heating elements to provide more area on the seat that is heated? Being from New England and the fact that the leather seat upholstery I will be installing is much thicker than the cloth OEM covers I thought extra heating would be nice. I know anything that "heats" draws a good amount of power/amps. Would wiring the two elements as one in the back and the same with the bottom over-load wiring and or fuses or both?
1969 Triumph TR6
1986 BMW E30 325E, Auto, 2-door coupe.
1989 BMW E30 325iX 5-speed
1990 Volvo DL 240 Auto
1991 Volvo 240 Auto
1992 Volvo 240 GL Auto
1993 Volvo 245 5-speed.
2015 Volvo XC60 Platinum
MSGGrunt is offline   Reply With Quote
Old 06-09-2018, 10:37 AM   #2
nel621
The seat base should work. I like the idea that you can also raise and lower the seat height. I'm not sure about doubling up on the seat heaters, others will chime in. You have 2 240s. Take a drivers' seat out and install it on the passenger side. See if works the way you want, only 4 nuts on each seat.
Old 06-09-2018, 10:56 AM   #3
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
I like how you have increased the heating area. However, yes you will stress the wiring and fuses that are finicky at best. It would be pretty simple though to add a relay to handle the power needs, and use the existing switch/wiring/fuse to trigger the relay. It would be just like the headlight relay upgrade.
2013 Audi Q5
Sold- 2006 V70R
PeaceEngineered is offline   Reply With Quote
Old 06-09-2018, 11:34 AM   #4
nel621
Small reward with risk of fire. Just my
Old 06-09-2018, 02:19 PM   #5
PeaceEngineered
Sarcastic Optimist
How would there be a fire? If all the components are in good condition, there should be no risk. Now if they where stacked, I would be worried. Could add a potentiometer to make temperature adjustable?
It's and experiment, but nothing new...
http://www.heatedseatkits.com/heatedseatkits/index.html
Old 06-09-2018, 06:01 PM   #6
nel621
I don't know. Something about the sketchy thermostats, thin wires and 4 25 year old heating pads. It may be nothing.
Old 06-09-2018, 08:25 PM   #7
apachechef
Burnt Sierra Madre
"If"
Dammit, Lummert.
