Old 06-09-2018, 05:10 PM   #1
mossicon
Default AMM Question Regarding LH2.2 to EZK117 Swap
I am converting my '84 245 from LH2.1 to LH2.2 with EZK117, eventually buying the full harness conversion from Dave Barton. I have a question about two AMMs I found at my local junkyard. Both are Bosch P/N 0 280 212 007 required for the conversion, however, when looking at the 6-pin terminals, one has 3 adjoining terminals at one height, while the other three terminals are lower (not seen in the image of the AMM on the left). You can see the one on the right's terminals are all even. Has anyone run into this, especially with the conversion harness from Dave Barton: http://www.240turbo.com/volvoharness...versionharness
Any help would be of great help!
mossicon is offline   Reply With Quote
Old 06-10-2018, 07:58 PM   #2
mossicon
Dave Barton said he had never seen this. The picture does not show the pins that are there with the AMM on the left; they are just shorter in length. Here is a better image:
[IMG][/IMG]
Anyone have any ideas? It's more a curiosity at this point.
Old 06-10-2018, 08:03 PM   #3
holtzboy
Honda CRV DD WTF
holtzboy's Avatar
I suppose if the pigtail makes good contact with the pins it should be fine. I would remove that cap off the adjustment screw in case the base AMM mix needs to be adjusted.
1. 86 244DL- 1st car & owned for 16 years, 25mm sways, back to stock springs w/ KYB shocks, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC
2. 87 244DL - Sister-in-law's DD
3. 93 244DL - Step daughters DD
4. 84 242DL - Next project car
My feedback thread
holtzboy is offline   Reply With Quote
Old 06-10-2018, 08:21 PM   #4
mossicon
Thanks for the reply, holtzboy. And yeah, the cap I am sure will be coming off when I get the new harness installed and finally get it resurrected.
Old 06-10-2018, 11:52 PM   #5
bobxyz
bobxyz's Avatar
I'd guess that it's a manufacturing defect. Staggered pins on connectors are only used when the connectors will be hot-swapped -- the longer pins are usually ground so that ground is connected before anything else when inserting, and ground stays connected after everything else when disconnecting.
You might try very gently pulling up on the lower pins to see if they move and snap into place.
Old 06-11-2018, 12:31 AM   #6
sbabbs
sbabbs's Avatar
They just look bent down a little to me, not shorter. Maybe it's the angle.
Old 06-11-2018, 10:25 AM   #7
nordmaschine
forced instruction
nordmaschine's Avatar
Exactly.
Jetronic is romantic.
Whiteblocks
Old 06-11-2018, 12:00 PM   #8
lummert
lummert's Avatar
Need a picture showing the pins facing the camera.
Old 06-11-2018, 12:58 PM   #9
mossicon
Again, thank you all for the replies. At bobxyz, I did try to pull gently on the pins to no avail. Here is the image with the pins facing the camera:
[IMG][/IMG]
I found a good distributor needed for the swap, so now only need the harness. I really want to buy the harness from Dave Barton's site, but will not be able to afford it. Has anyone had any luck piecing together a harness for the conversion. I suppose you would need harnesses from a 240 with LH2.2 and a 740 with the EZK117 ICU? Here is an image of the pieces I have for the conversion. My LH2.1 has just been too much of a headache:
[IMG][/IMG]
Old 06-11-2018, 01:07 PM   #10
oldschoolvolvo
oldschoolvolvo's Avatar
Yes, I did essentially what you listed there. If you are not afraid of some splicing/soldering/crimping, it isn't too bad.
I recommend separating the power stage from the heatsink (2 screws) and cleaning both sides and reapplying some thermal paste between the two. The powerstage does generate a bit of heat under normal operation and it is important to have a good connection to the heatsink. The one that I took apart essentially fell off the heat sink when the screws were removed. The thermal paste was very deteriorated.
I used this thermal paste with good results: https://www.amazon.com/Arctic-Silver.../dp/B0087X728K
-Mike
1998 V70 T5
|Feedback|
Old 06-11-2018, 07:58 PM   #11
mossicon
Thank you for the suggestion, oldschoolvolvo. I actually really like soldering and crimping, etc... I just was a little hesitant to make too many splices considering all of the difficulty I had with my LH2.1. I have had a lot of success using the Delphi weather packs, although I no longer have access to the nice crimpers and endless supply of terminals and connectors that I had at my old job. I believe I have seen threads on how to combine the 240 LH2.2 harness to the 740 EZK117 ICU connector, but I am drawing a blank at this time. Any good threads you could recommend on creating one's own harness? That would be swell.
Old 06-11-2018, 10:23 PM   #12
oldschoolvolvo
The EZK harness and the LH harness are essentially two separate harnesses except for a few wires.
Here is some info:
http://www.turbobricks.org/forums/sh...d.php?t=329863
Old 06-11-2018, 10:24 PM   #13
bobxyz
bobxyz's Avatar
Here's one thread - I don't know how accurate it is, or if enough pictures are still left:
LH 2.2 to EZK117 - My article addendum
Old 06-13-2018, 06:23 PM   #14
mossicon
This is perfect, everyone... just what I was hoping for. Most appreciated.
