Old 06-11-2018, 11:25 AM   #1
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Default Who's using "Dust-Off" as Air Conditioner refrigerant?
Ie compressed "air" cans.
Seems to be made of the stuff that's replacing R134a.
Thoughts? Experiences? Appears to work as well as R12 and is "safer" for the air we breathe.
Specifically the dust blowers with "Difluoroethane".
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 06-11-2018, 12:07 PM   #2
JohnLane
Propane works well too.
Old 06-11-2018, 01:12 PM   #3
Ursan
Ursan's Avatar
It's been covered. In a couple different threads.
Old 06-11-2018, 01:27 PM   #4
XxJenoxX
Skin Suit
XxJenoxX's Avatar
Josh Hamilton is, if you track him down on FB. I dunno if he's in this part of the forum much, so I dunno if he'll see this. He was giving me some crash course in it, and he's very happy with it. Blows ice cold, I think towards a year later.
AND THEN THERE WERE TWO (and a half)
2008 XC70 3.2: Stubborn sensor on wheels
1992 M47 240 Wagon: Why did anyone let me have anything this nice?
1990 240 DL: Parts car
1983 242 TIC +M46: Ticket to the 242 Crush Club
I have no idea what's going on, but I think I can fit more 8====D in my mouth than 240240
Originally Posted by Wilford Brimley View Post
Mmmmmm curvy girls and cock excess
XxJenoxX is offline   Reply With Quote
Old 06-11-2018, 03:02 PM   #5
MikeSr.
What, me worry?
MikeSr.'s Avatar
Here we go.
I coulda had a V8!
Old 06-11-2018, 03:39 PM   #6
niquemarshall
Originally Posted by MikeSr. View Post
Here we go.
I really want to use propane but I keep hearing it makes the ac TOO COLD and car freeze the canister solid or something
niquemarshall is offline   Reply With Quote
Old 06-11-2018, 04:39 PM   #7
90volvo
I tried it (air duster), dont waste your time. Few yrs ago it worked but now they have changed the chemicals in it and has alot of junk in it. I tried it 2 yrs. ago out of curiusity. Coldest I could get was 48 degrees. I dumped the system started over with propane and got 42 but it will freeze up on you. Now have duracool and works great 38 degrees with 95 outside. You can get duracool cheap from there website.
Old 06-11-2018, 05:18 PM   #8
MikeSr.
What, me worry?
MikeSr.'s Avatar
R134 is $4.50 a can.
Old 06-11-2018, 05:22 PM   #9
iHateVolvoPeople
that's cus it kinda sucks, especially in an r12 car.
...at least in comparison to the r12 and older freon stuff.
Feedback Thread
Current:
93' 244T m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245T m47
92' 940 turbo AW71
94' 945T AW71(L?)
Old 06-11-2018, 10:15 PM   #10
Lando
Arthur Digby Sellers
Lando's Avatar
R134a works as good as R12 if you get the right orifice tube (or adjust expansion valve) and get an R134a compressor.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is online now   Reply With Quote
Old 06-11-2018, 11:01 PM   #11
iHateVolvoPeople
Yes, but a simple refill with r134 in an r12 car kinda isn’t that good.
Old 06-11-2018, 11:12 PM   #12
90volvo
yes, 134a works great in my 2012 honda. But in an R12 car its worthless in a hot climate with high humidity. Some people will argue that but they dont live in Misery Mo. Now if you change condenser, expansinon valve, drier, evaporator and expansion valve. It will work great but I would still put my money on duracool will be better with just some maintenance parts (drier, EXP valve,). Im going to get a bigger condenser and see if I can get mine down to 32 degrees with duracool. I believe it can be done. With my orginal compressor.
Old 06-12-2018, 08:47 AM   #13
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
I have run both in my 90 245.. The lowest outlet temps I've seen out of the center vent is about 50 degrees on both air duster and R134a.. The pre 91 240 AC just sucks there is no way around that..
-Sam
90 245GL Build thread 2JZ coming soon...
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar
93 245GL Street Beater
Old 06-12-2018, 08:57 AM   #14
jjona5
I installed an upgraded universal parallel condenser and 54 was still as good as I could get. Thats in 100 degree heat though.
jjona5 is offline   Reply With Quote
Old 06-12-2018, 10:33 AM   #15
Wren
Porkchop Sandwiches
Wren's Avatar
-Sam
The only way I've found to get acceptable performance with R-134a in a pre-'90 car is to install a parallel-flow condenser. The OE condenser doesn't cut it.
Old 06-13-2018, 02:11 AM   #16
90volvo
So your 54 degree was with duacool or 134a? Just curious
Old 06-13-2018, 02:15 AM   #17
Jack
Banned
Jack's Avatar
And bigger evaporator
There’s a compromise when going from r12 to r134. Sure dolphins don’t get a sunburn but r12 is more efficient
Old 06-13-2018, 02:28 AM   #18
Owsley
Owsley's Avatar
I made the switch to R-134a in my 1982 Toyota Supra last year. It blows plenty cold. I think Toyota oversized the a/c in that car, it came with a little fan that cools the condenser, which really helps when you are idling. The first thing I did when I got it was have the compressor replaced, that was about 10 or 11 years ago, so it was probably rebuilt to R134a standards. Maybe. A freon system was just too much of a hassle to get serviced and at the time I didn't know how to charge it myself. With the R134a the gauge that came with my first can seems to work well enough, I keep it on the low side of the "charged" range.
Originally Posted by jack8745 View Post
I know it's hard to believe that someone wants (on turbobricks) to make things work the right way. My extensive search shows this hasn't happened since 2005 when there was a ziptie shortage and Tbrickers were forced to buy and use the correct parts
Originally Posted by Lord_Athlon View Post
This is the only forum in existence where people get mad that their cars are worth more than 500
Originally Posted by Johnnysalt View Post
I don't know how to do anything, help! Whats the quickest easiest dumbass proof way to fix this besides taking it to someone who knows how?
Owsley is offline   Reply With Quote
