Old 06-13-2018, 11:54 AM   #1
chronicrhythm
Default M46 bearing identification help
I have an m46 that when I bought it, it didn't have a bellhousing on it and it was missing the bearing that sat behind the bellhousing. It is the one that sits below the main input shaft. Looking on rockauto it looks like the countershaft bearing is what I need but I haven't been able to find anything online about it and my haynes manuals don't mention the countershaft bearing from what I've read. The bearing sits on the circle cutout of the right bellhousing in the picture. There is also a rear and center countershaft bearing. Would the one I need be the center?
chronicrhythm is offline   Reply With Quote
Old 06-13-2018, 01:13 PM   #2
Set 4 (A4) is the one you want.
Make sure you put the shim for the input shaft bearing back in.
Old 06-13-2018, 01:38 PM   #3
petiww
petiww's Avatar
There is no more than two bearings supporting the countershaft in an M45/M46. If its not an early type, both front and rear countershaft bearings are standard size 44649-610 ones. Dont forget to properly setup the clearances/preload down there, it differs between the iron and alu housings.
1980 Brown 244 GL
Old 06-13-2018, 10:26 PM   #4
chronicrhythm
Is there any where to get the shims? I don’t think it was there since the bell housing wasn’t on the transmission. I was reading about shimming in the Haynes guide. There is a local Volvo shop to me that I could probably check to see if he has them. And the National A4 is the one I want for the bearing?
Old 06-13-2018, 11:03 PM   #5
I like Timken and I believe that's what they came with but either will work.
You need to measure the depth of the recess in the bell housing and the amount the bearing protrudes from the case. Add the gasket thickness to the depth of the recess, then subtract bearing protrusion to determine the shim needed. All 4 shims sizes are still available from the dealer.
.6 mm = 948008
.75 mm = 948009
.9 mm = 948010
1.0 mm = 948011
Old 06-14-2018, 12:08 AM   #6
chronicrhythm
.6 mm = 948008
.75 mm = 948009
.9 mm = 948010
1.0 mm = 948011
Awesome info! Thanks so much
Old 06-14-2018, 12:30 AM   #7
planetman
planetman's Avatar
Do you have the correct front gasket? I had to wait months to get the front gasket for an early M45/M46 from Volvo, the only source for them, later M45/M46 use a different gasket.
And I have both in stock in case Volvo is on back order again or if you don't want to make your own gasket.
Eric
Torrance, CA 90502
Old 06-14-2018, 01:34 AM   #8
Whoops, SKF is the original bearing manufacturer, not Timken.
Old 06-14-2018, 10:20 PM   #9
chronicrhythm
I am going to try the gasket kit from eeuroparts. Actually looking at the vehicle fitment guide it says it isn't for a 240 so maybe the bellhousing gasket won't be correct and I'll have to contact you. I guess I could call them and see what the thickness is. Do you know off hand how thick it should be?
https://www.eeuroparts.com/Parts/406...-M46-41431574/
Old 06-15-2018, 12:22 AM   #10
planetman
planetman's Avatar
Before you buy that set, make sure you have the later M46.
You can tell by the splines on the input shaft, coarse, 10 splines or fine, 22 splines
Old 06-28-2018, 04:09 PM   #11
chronicrhythm
So I bought the new bearing. From reading the haynes manual it looks like I need to take everything out to get to the layshaft and then replace the bearing. The old bearing is there but is missing the race. It rolls fine but seems to be aged. Could I put the new race I have on there or would it be asking for trouble? Is there a way to replace the bearing without tearing into the entire thing? I think I would rather find another one that works if I have to tear the whole thing down since it seems like it would take a lot of time. Picture is of the current countershaft bearing.
