340GLT
- Dec 25, 2005
- Swansea/Shropshire UK
Did you by any chance keep the headlining?
Adam
Adam
When i was running classiswede springs i had to clamp them in.
Get yourself some steel strip 25mm wide 3mm thick.
Drill an 8mm hole in a short piece of it to bolt to the spring cups, if you look at top and bottom cups there is a factory hole.
Make the strips bolt in here over 1coil of the spring so they just go past the edge of the spring cup. Ran mine like that for 2 years with no problems.
Adam
