Old 09-28-2016, 11:28 AM   #1
mikep
The MP
mikep's Avatar
Default Spring Rate Data
Starting the spring thread that was requested.
I will edit it as we go, adding numbers and deleting extraneous comments.
Please comment, and please offer to loan sets of springs if you remove KNOWN OE springs to change anything. I would also test any lowering or overload springs you can loan me.
I'm at the south end of Delaware, and can meet somewhere else if we can work it out.
Quotes from another thread:
I did all the springs a long time ago and found varying results. The first numbers posted above were probably from measuring the wire plus paint. I do remember a wagon rear spring being around that number. Then I lost that notebook.
Since I couldn't find any numbers, I started over.
I just measured the springs from a mid-80s CT 244 that went to the crusher.
Front Springs 80 lb/inch.
Rear Springs 91 lb/inch.
Scraped off the paint and undercoating, measured, did the math. Pretty close.
Maybe that wagon with 117# had overloads, but 117 and 107 aren't that far apart. Plus the 117 might have been measuring and using a calculator.
And maybe the 120# fronts that were mentioned were GT or Diesel springs. I really wish I had the diesel springs I got rid of.
*edit
I measured how much pressure it took to compress each spring, and retested each run. Then I increased the pre-load, so I got numbers starting at 40, 50, 60, 70, 80lbs. That's TEN tests per spring.
I will have turbo wagon (US) from the junkyard as soon as I have the money to pay for the front suspension. Until then, nobody has offered to let me test any springs at all. I do what I can.
I'll test another mid-80s sedan soon, and also a non-turbo 940 wagon.
(I paid for the suspension, haven't seen it yet in the several months, even when I told him to drag it here and let me remove it.
Mike, sticky somewhere?
Done. At least, it's a start.
Yesterday I tested 1992 wagon rears. They were a little off side to side.
One was 97 pound/inch, one was 107. Looking for another set.
I have another 240 sedan that I will test soon, and I will try to get these fronts tested. Had some issues with a brake line, and it's changeover day for the exploratory class.
wouldn't MikeP need a girlfriend to qualify to be a cuck?
Old 09-28-2016, 11:34 AM   #2
mikep
The MP
mikep's Avatar
Default so, just measured numbers:
1988 Hartford CT 244
Front springs 80 lb/in
449mm (17-5/8") free length
166mm overall Diameter
13.2mm (.520") wire diameter
5.5 free coils
11.5" installed height hanging
8.5" installed height sitting
Rear 91 lb/in
415mm (16-3/8") free length
129mm overall Diameter
11.85mm (.466") wire diameter
7.5 free coils
15.25" installed height hanging
12.25" installed height sitting
Old 09-29-2016, 08:30 PM   #3
mikep
The MP
mikep's Avatar
Front springs 79 and 80 lb/in
445mm (17-1/2") free length
167mm overall Diameter
13.6mm (.540") wire diameter
5.5 free coils
___ installed height
Rear 97/107#
449mm (16-5/8") free length (will recheck)
13mm (.510") wire diameter
8 free coils
Old 10-05-2016, 03:43 PM   #4
mikep
The MP
mikep's Avatar
added numbers, separated into posts.
If there's an inch with fractions, it was a tape measure. If a decimal, it was a dial caliper.
I scraped off the paint with a knife for the wire dia.
I did not use math to get the rates. I used a scale and a dial indicator on a compressing fixture.
When I have time, I will go to NASCAR-land with some springs to see how close my rig was.
Old 11-01-2018, 11:47 PM   #5
towerymt
the real Towery
towerymt's Avatar
5.5 free coils
Rear 91 lb/in
7.5 free coils
Measured the springs that came off my '92 240 sedan.
Front:
17-1/4" free length
0.540" wire
Rear:
16-1/4" free length
0.475" wire
Rear springs had some blue on one coil. Fronts are still covered in undercoating.
Old 12-22-2018, 03:13 PM   #6
jwernerny
jwernerny's Avatar
I've got rear springs from a '94 964 (Mk I IRS), and a '92 944T if you want to measure them. PM me.
John Werner
* 1992 944T * 1988 764 GLE V6 * 2002 WRX Wagon (needs motor) * 2006 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 12-28-2018, 12:04 PM   #7
mikep
The MP
mikep's Avatar
Cool. I would like to measure towery's springs, too.
Old 12-31-2018, 12:43 PM   #8
towerymt
the real Towery
towerymt's Avatar
Old 02-06-2019, 05:44 PM   #9
towerymt
the real Towery
towerymt's Avatar
Sold. They soft anyway.
Old 11-16-2016, 11:21 AM   #10
mikep
The MP
mikep's Avatar
Added installed data for the sedan. The guinea pig was a 1983 Canadian 244 with no carpet.
Old 08-29-2017, 08:12 PM   #11
lummert
lummert's Avatar
http://www.kilensprings.com/springs-...ecatalogue.asp
Old 02-09-2018, 04:48 PM   #12
mikep
The MP
mikep's Avatar
old IPD sport black springs from Mike Rausch.
I will add pics later.
Only measured one each.
Front spring 137 lb/in
330mm (13") free length
6.5" overall Diameter
14.27mm (.562") wire diameter (paint rubbed through)
4-1/8 free coils
Rear 148#
343mm (13.5"") free length
5" overall Diameter
12.7-12.8mm (.500-.505") wire diameter (varies, did not clean off paint)
6 free coils
Should ride like **** with the 1.5:1 motion ratio squared in back.
Rear vert rate would be 222lb/inch.
Front you lose a little, so 130-ish.
If I had that much rate out back I'd want at least 250 in front to keep it from pitching.
Old 05-12-2018, 08:46 AM   #13
petebee
[QUOTE=
If I had that much rate out back I'd want at least 250 in front to keep it from pitching.[/QUOTE]
So I understand, it sounds like a car with old black IPD springs is undersprung at the front? Where are you testing these springs? I live in Mooresville right in the thick of Nascar
I have a 1990 240 Wagon with black IPDs and Bilstein HDs and the ride is not great.
petebee is offline   Reply With Quote
Old 05-12-2018, 11:04 PM   #14
Mueller
Mueller's Avatar
One of the coolest race shops I've ever had the pleasure of getting a private one-on-one tour of.
(Went to N.C. for a Fanuc class)
Mike, it would be nice to have a link in this thread or maybe a sticky of your other spring information for our cars.
Old 01-02-2019, 12:23 AM   #15
Marvelous3
Who engineered this?
Marvelous3's Avatar
What is considered a "good" ratio for us? Grey car is 300 front and 200 rear and seems to ride super predictable. I sort of guessed when I bought springs at those rates but maybe I got lucky? I'd always read you wanted more spring up front than in the rear.
Old 01-02-2019, 03:10 PM   #16
mikep
The MP
mikep's Avatar
Good question.
Most cars have more weight up front, so you need more rate in front for a similar frequency as the rear.
Even with a 50:50 balance, most o.e. engineers go a little higher in front so it doesn't "pitch" over expansion joints or small bumps in smooth roads.
For performance, it really depends on the suspension type, your driving style, surfaces, etc.
A solid rear axle has an odd motion ratio in roll, so to avoid a huge rear bar, some people go higher in rear. Some anti-roll bars (like ours) have a huge motion ratio as well. In front, it's half as effective on the control arms, compared to on the strut. The rear is even worse, since the effective arm length is the length of the control arm it is bolted to.
300 front and 200 rear gets you roughly equal, which is a good starting point. The wagon with 350 front and 275 rear handled great with mild sways, but was bad to ride in on a bridge. The sedan we put together with 350 front and 225 read was very good. I think it had a 25mm ipd front, 19mm rear.
Old 02-15-2018, 10:12 PM   #17
mikep
The MP
mikep's Avatar
Taking the IPD springs and the wagon springs to NASCAR-land for checking on Sunday. That way I will know how far off my rig is. I may also purchase a load cell to replace my freight scale.
Old 02-16-2018, 02:43 PM   #18
shoestring
shoestring's Avatar
Thumbs up
Old 02-21-2018, 04:38 PM   #19
bent-grill
as a guy at the "selecting a spring rate for coil overs" point I await your results with baited breath. (the grossest type of breath.)
bent-grill is offline   Reply With Quote
Old 02-28-2018, 12:11 PM   #20
mikep
The MP
mikep's Avatar
hit "post" too soon. hang on a minute..
I took 2 sets of springs to Drew for testing. Both have been tested on my home-made rig.
1992 245 springs, one of the rears was lower than the other, possible changed to a sedan spring. I took the higher of the two.
Early (244?) IPD Sport Springs, borrowed from Mike Rausch.
IPD rear, waiting to be molested.
Waiting for the computer to get its head together.
Stuff to make things stiffer on the fly. Everything gets tested, and springs stick around the longest of any NASCAR team part.
IPD front on the right, fancy coilover stop spring on the left. That's what it rides on at high speed.
Gross adjustment slider clamp bolts
Talking smack to the program, telling it what it needs to do for us.
You have to put in measuring blocks to let the machine measure the height of the retainer/spacer the spring will sit on.
Like SO.
But IF you forget, (and it seems someone did) and hit it with a load instead of clicking the right "test", this might happen:
Test complete. But what does it mean? 150 lb/in for the rear, but wait. There's more!
Avg. pressure, including harmonics and cell noise and ****.
Next up, IPD front.
Test #2 complete, with Test #1 graph behind it. 146 lb/in. Might as well call that another 150.
Test #2 graph.
Front 245 time.
Poncy little 95 pounder.
The low start is due to the imperfect tail in the seat.
You could call this a 100 lb/in spring.
Rear 245 time.
117#
Front and rear 245 overlaid.
IPD rear and stock wagon rear compared.
IPD front and 245 front compared.
Old 02-28-2018, 12:31 PM   #21
mikep
The MP
mikep's Avatar
My first round of tests, I used wood to spread the load on my scale (an old shipping scale with springs inside, sheet steel housing, dial indicator).
Follow-up tests to compare my methods with Drews, I used a steel plate (old rail/tie connector) but with wood on top.
Where I was off 10-15# before, this time I was much closer.
I plan to buy a load cell to see if I can improve more.
I will take 240 sedan springs and 740 wagon springs down next time, and any other springs I can get my hands on.
Old 03-02-2018, 04:56 PM   #22
bent-grill
wow, actual data, this is great! thanks so much for all the schlepping.
Old 03-02-2018, 05:17 PM   #23
Im surprised they are so even front to rear in rate.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 03-02-2018, 10:40 PM   #24
mikep
The MP
mikep's Avatar
The old ipds? Me too. They were probably unaware of motion ratio. Most of us were then.
Old 03-08-2018, 11:09 AM   #25
IPD has never been known for their engineering prowess
