Mylesofsmyles
A Member
- Jan 18, 2010
I know, I know, the T5 swap parts won't fit the T56, but how impossible is this swap?
I thought about it for a minute....there are a couple style units, one from the firebirds and one from the mustangs. the mustang one should put the shifter in about the same position as the t5, no? use the driveshaft and I'd assume one might be able to use the yoshifab driveshaft adapter. all you'd have to do is bend over hard and pay someone to make you a custom bellhousing and tranny bracket, the latter i can probably do myself.
just pontificating...kinda a hot idea if you ask me.
was looking at the gear charts tho...only the 93 firebird had a t56 with a gear set i like....it's got the 3.36 first gear. so i dunno how hard it'd be to transplant that gear set to a mustang t56 case
