Old 03-09-2016, 11:56 AM   #76
LC4CARL
Aero challenged
LC4CARL's Avatar
Originally Posted by quillc View Post
Front main seal is leaking. Easy fix, but you have to take the timing belt off to do so. May as well replace the timing belt while you are in there.
If you are really wanting to save some weight, get the smaller Denso alternator. Smaller and weighs less. Makes changing the filter easier as well.
Great idea.
This thing makes the Exxon Valdez look clean. Should have degreased it before I put it on stands. Got grease in every pore now. Yuck.
On a positive note, I haven't found any real "game changers" like hidden collision damage or extensive rust through. Looking forward to my first road trip in it.
@PDXvolvo on IG
Old 03-09-2016, 08:53 PM   #77
LC4CARL
Aero challenged
LC4CARL's Avatar
Nice rack.
Old 03-09-2016, 08:55 PM   #78
LC4CARL
Aero challenged
LC4CARL's Avatar
Cleaned the PCV thing with a drill and some brake clean.
Is a hose supposed to connect to the large nipple?
I found this, but don't seem to have #6. Does it connect to manifold vacuum?
Old 03-09-2016, 11:24 PM   #79
quillc
yv1a.com
quillc's Avatar
Yes, the hose goes to the large intake hose that connects to the throttle body. There are two hoses that connect there, one for the IAC, the other for the PCV. Its a moulded hose. If its not connected there, I would be surprised if it ran very well as you would have a massive leak bypassing the AMM.
Chris
www.yv1a.com
quillc is online now   Reply With Quote
Old 03-10-2016, 12:13 AM   #80
LC4CARL
Aero challenged
LC4CARL's Avatar
Cool. I'll take a look. This would be on the plastic tube between the throttle body and the air filter? Not a super high vacuum, but a little I suppose.
What's "AMM?"
Old 03-10-2016, 02:33 AM   #81
brendon_ak
Air Mass Meter, it's the first thing after your airbox, has a connector to your wiring harness
Buy the IPD relocate kit for flame trap. If you want to get fancy contact Yoshifab and get their crank case catch tank breather setup. That's the hot setup.
Keep at it dude, check those boxes off and you'll have a bitchin ride!!
Any other questions?
Old 03-10-2016, 02:37 AM   #82
brendon_ak
Also, get rid of AC, it's a pain in the ass an you don't need it in dry heat like you have in PDX. Roll the window down in August, less stuff to go wrong. Get an A or B cam in there and you'll enjoy the smooth rev to 5k now and then. Makes the car pretty fun without having to redline it.
Also if you aren't keen on wiring too much you can convert to Breakerless ignition from a 75-80 model, simple and bombproof. If you can find a 1989 model you can pull the EZK computer ignition system. It's the best for these cars.
Old 03-10-2016, 02:43 AM   #83
LC4CARL
Aero challenged
LC4CARL's Avatar
Great stuff. Thanks!
You guys are going to die when I show you the home made cold air intake on this sled. It has a flat filter zip tied at the end of the snorkel. First class!
Hoping to put it back on the ground this weekend. Maybe tires next week.
Old 03-10-2016, 03:06 AM   #84
brendon_ak
The stock intake works perfectly, I'd leave the stock airbox on there, you won't gain any power and only lose torque
Old 03-10-2016, 11:48 AM   #85
LC4CARL
Aero challenged
LC4CARL's Avatar
It seems to have fallen off a while back. LOL. May have to find a used one.
Saw this on FB. Guys were going crazy about it. What's it from?
Old 03-10-2016, 11:51 AM   #86
That's a GT cluster for a 75-80 240.
Old 03-10-2016, 12:06 PM   #87
brendon_ak
Volvo made two different dash styles in the 240's. Early cars didn't get the extra guage spots like yours did. RWC listed the years for the early dash. That cluster added other guages that weren't available otherwise. The other spot to install guages in the early dash was to drill out holes in the actual dash and install there.
Old 03-10-2016, 01:11 PM   #88
LC4CARL
Aero challenged
LC4CARL's Avatar
Good looking unit. Love the way the tach and speedo needles swings.
What's the deal with the IPD temp gauge fix? Stock, the temp gauge is a bit "vague?"
Old 03-10-2016, 08:49 PM   #89
http://cleanflametrap.com/tempFaker.html
Old 03-11-2016, 01:45 AM   #90
LC4CARL
Aero challenged
LC4CARL's Avatar
The board functions to reduce warranty (ha!) service by classifying varying temperatures, as sensed by the thermistor in the head, into three ranges of the gauge. It turns the gauge into an idiot light with roughly four states: cold, cool, normal, and hot.
Interesting.
Old 03-11-2016, 01:51 AM   #91
LC4CARL
Aero challenged
LC4CARL's Avatar
Spent $60 on lubrication goodness!
Snowman.
Having trouble getting the top nut off the trans mount. I can barely get a wrench on it between the brackets.
Old 03-11-2016, 01:58 AM   #92
LC4CARL
Aero challenged
LC4CARL's Avatar
Prototype cold air system that, evidently, escaped the factory accidentally.
I think I found where my PCV hose is supposed to go.
Old 03-11-2016, 03:09 AM   #93
sbabbs
sbabbs's Avatar
What's the gear oil for? What transmission do you have?
Old 03-11-2016, 02:20 PM   #94
LC4CARL
Aero challenged
LC4CARL's Avatar
Gear oil in the diff. '87 would have the M47 trans? Non-planetary OD? So no ATF, right?
Old 03-11-2016, 10:02 PM   #95
LC4CARL
Aero challenged
LC4CARL's Avatar
Well now I'm worried.
Old 03-11-2016, 10:12 PM   #96
Old 03-11-2016, 11:23 PM   #97
PDX240
Back from the DEAD
PDX240's Avatar
That hose nipple on the airbox is a dead-end
Nothing goes on it.
M47 uses ATF I think, maybe 10w-30 oil I think some folks use.
My Blue 1986 245DL
Pdx240 feedback http://forums.turbobricks.com/showth...ghlight=Pdx240
PDX240 is offline   Reply With Quote
Old 03-12-2016, 06:05 PM   #98
sbabbs
sbabbs's Avatar
M47 is susposed to use the Type F ATF but you can put anything in it, some people put the redline in it or other thicker oil, it just takes a wee bit longer to warm up and the shifts can be a little slower to do before warmed up with thicker oil. Main thing is make sure it's in a gear or the next right gear before you stomp on it.
Third gear is the weak gear. I replaced 4 manual m46's in one year once in a turbo 740 wagon. One time downshifting into third on Cornholiness pass back when they still let you pass on that road, shifted into third, stomped on it, zing, nothing. Gears stripped, slapped it back into 4th, kept going.
Old 03-13-2016, 12:51 AM   #99
LC4CARL
Aero challenged
LC4CARL's Avatar
Thanks boss. Good to know.
Old 03-13-2016, 12:55 AM   #100
LC4CARL
Aero challenged
LC4CARL's Avatar
Thanks for the goodies Taylor.
Some progress with the intake. Now I can hook up the PCV.
