Patdon10
- Oct 29, 2007
- Fairfax, Virginia
This isn't a problem, more of a curiosity.
I dread changing the air filter on my 240, because it is such a pita to open the box up, stuff the filter in, then find a way to shut it. The last time I did it, I had to remove the plastic hose that leads from the air box to the amm, close the air filter then try to stuff that hose back in, cracking the sides in the process and putting a little hole in the screening to the AMM. There has to be an easier way to do it without struggling. What do you guys do? Do you remove the xylophone hose from the AMM to the Throttle body? I feel like that might give some more wiggle room.
