WagenSport
- Feb 25, 2008
- Westminster, MD
1990 760T --I was excited this morning i finally got the boost to what seemed like a good tune. Leaving the bank heading for my job interview however i gave it a good amount of throttle and POP! Sounded like a diaphram popped and then no power at boost. Will drive semi-fine until it gets right a 0psi then it just dies like a dog. My first though is maybe the CBV diaphram broke. It seems like its dumping off all the boost. When i hit "0" psi there is alot of air rushing. I checked all the hosing they all seem to be intact, at least what i could check on the side of the road. What would you guys think is the suspect, iam hoping to hit the junk yard today and get her back on the road. CBV diaphram, Wastegate diaphram, or do you think i destryoed the head gasket. Or is there something else that might destroy itself under 14 psi. I dont hear any bad engine noises, just sounds like the boost is all being dumped off. Every now and then too i seem to catch a whiff of fuel as if the engine is trying to add fuel as if the car was boosting. Let me know what you guys think. This is a crappy situation. Thanks in advance guys!
