$te4dyBrickin'
- Mar 6, 2018
- Where you are
So what do ya think? I did a compression test recently on my 245 and came out with some iteresting numbers. First off though, the gauge is brand new and never dropped. It read accurately on my s13 when I had it. Here's the gauge. I had actually got my gauge from Autozone. https://www.amazon.com/INNOVA-3615-Compression-Tester-Plus/dp/B001QJ9JRY
Greenbook factory cylinder compression numbers : 128-156psi
I got; cyl. #1) 182psi, 2) 195, 3)190, 4)190
Now that's definitely within the 10% margin of variation per cylinder, but incredibly high over green book recommendations.
My motor honestly runs alright (to me) throughout all stages of operation with no smoke coming out the exhaust at any throttle input, including up steep hills where load is evident. Along with that, written on the hood of my car is the fact that the head was rebuilt in 2011 with new valves and what not. The internals should be awesome. I checked out he cam and valve springs, buckets and shims, too, when I was checking clearance and the were beautiful. Better looking then the dual cams of my '96 s14 (ka24de). I cant really imagine carbon build up being that epic. No seals are flying anywhere, no leaks from front gaskets. Hell, parked it on my well slopped driveway last night and drove away this morning without any signs of leaking on the ground..... for now.
Im also totally not sure how one could up the compression (not in the terms of compression ratio!!!) on the engine with the comp rings around the piston or maybe some form of head manipulation in order to up cylinder comp. I don't know.
The motor runs fine, even have a vid on youi tube(skip to 1:15):<iframe width="560" height="315" src="https://www.youtube.com/embed/ufK1p6eyYXw" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
So I dont get whats going on? Any ideas? Oh and the specs on my valves. Factory states 0.30- 0.40mm (.012 - .015) during "just a check" (adjustment) procedures.
cyl#1) Intake 0.33mm/Exhaust 0.33mm
2) Int 0.41/Exh 0.33 3) Int 0.41/Exh 0.36 4) In 0.36/Exh 0.30
I figure although there's a couple .01 over and one riding low on the line that it wouldn't just cause outlandish results. The valves actually still run fairly quieter than when I first got her (and before first oil change and timing belt job).
There it is.
There it is.
