Crew... So I'm well aware that the T5 is the defacto manual swap with the Getrag as a distant second for those in the US at least.
Since the T5 requires essentially the same amount of custom work, I was wondering if anyone had considered or looked into alternatives to the T5? I know that the T5 is touted for being cheaply available and reliable, but even yanking a box out of the yard for ~$200, I'm going to need to open the stupid thing up to get a look at it. I'm going to need a clutch, an adapter, the proper shaft, and a driveshaft made or adapted. All this for gearing that is... not bad, but I'm going out on a limb to suggest that it isn't really ideal.
Anyhow... I didn't know if anyone significantly more in the know had alternatives worth considering? What about 6 speeds (yes I know we're talking hydraulic clutches at this point)...
Is the T5 STILL the most obvious swap? Are there other transmissions that are similarly sized that might be worth a look in the yard/ebay?
The AW71 with the accumulator mod is nice, but I'm going to die with this tragimatic crap.
Line for face punching starts here ---->
