#26 |
dude
![]() Damn dude
Post pics in Orhpan Thread or YOU will be banned. |
#27 |
![]() Very nice result.
#28 | ||||
Turbo, what?
![]() Thanks guys! Here's a massively long post in true Kyle fashion.
First off, the varying idle speed and AFR was fixed by installing a 850 non-turbo throttle body with new seals(a/c o-ring on the TPS and a valve stem husher on the throttle return spring side) on the engine. We smoke tested the intake and found a little bit of leakage out of the throttle shaft of the 960 throttle body. The 850 throttle body required re-using the 960's throttle shaft to have the notch for the throttle position switch be in the right place. We replaced the seals as mentioned above when taken apart. The idle is now stable and the AFRs at idle are now stable. The wedge on one side of the NA 850's throttle plate made it so we can actually hold 1200-1300rpm with just barely cracking the throttle instead of it instantly wanting to be over 2500rpm! That made a HUGE improvement in the ability to drive this thing around at low throttle openings(parking, pits, etc.). WAY BETTER! Who knows how much of that improvement was due to the wedge instead of the fixed vacuum leaks. I'm not going to bother finding out any time soon. Here's what we did on the dyno: 1. We started the dyno time by playing with Injector Constants 1(IC1) and 4 to try and make sure the car is using all of the load map. I ended up settling on a mixture of both being adjusted, instead of one or the other being adjusted. It's not perfect and could be dialed in more, but it's better than before and the trace is in at least the second from the top or top load cell most/all of the time at WOT from 2500rpm up. We called that good and moved on. 2. Started dialing in the fuel mixture by leaning out(lowering) IC1 then fine tuning on the main fuel map from there. We ended up running values of 105 for IC1 and 3400 for IC4. I had to take a "ton" of fuel out of the main fuel map above 5500rpm and tweaking a few other areas to try and smooth out the curve. 3. The car had a significant lean spot around 5200rpm(as seen in the "2nd" run below on the dyno graph picture), so I started changing the RPM Scale for the main map to give me a column there that would allow be to fine tune it better. I got more resolution at higher rpm and less resolution at lower rpm, especially around low rpm/idle where the car doesn't really need much adjustment. I think I want to go back and give it even more resolution in our 2500-7000rpm range that we normally race in so I can get it even closer dialed in. NOTE: At this point I had forgotten that I had some WOT fuel add turned on still and I did not go back to zero it all out. I don't know if it actually works, but once we get the wideband working again(or replaced) I'd like to turn it off and fine tune the main fuel map more. If I am not satisfied with that, then I'll try adding the WOT fuel again. 4. Once we were satisfied enough with the fuel side of things, we moved onto the ignition. We first verified that the proper load cells were being pulled from and they were(top 2 mostly). Step two was take the top three load rows and drop them all 2° to see how the power changed. It didn't change! That suggested that we had more timing than we needed and there were no losses by retarding the ignition timing. We then took out another 2° and found the power drop everywhere so we added that last 2° back in and verified we were back where we started. We did not get around to trying smaller amounts than that or going into adjusting any of the lower load areas of the map. Maybe another day, or maybe another day with different, modern engine management system... 5. Next up, camshaft timing! We started with the gear set at 3° advanced which is where RSI had it in the past and ran the last race with no complaints about the power curve at all. At this setting, the timing mark for the cam was basically straight at the stock TDC mark on the timing cover. We tried retarding the cam 3° first and lost torque everywhere except at high rpm. It lost 7/8wlb-ft from 2500-4500rpm and the losses started shrinking gradually to where there were no losses at 6200rpm and above that it climbed up to the retarded setting having barely 1wlb-ft more at 6500-fuel cut around 6900rpm. We then instead tried advancing the cam 3°(6° advanced from previous setting) and our torque went up 1-3wlb-ft from the initial numbers below 4500rpm but matched torque until 5200rpm where it crossed and started dropping. At 5600rpm it was down 2wlb-ft, at 5900 it was down 3, at 6300 it was down 4 and at 6500 it was down 6 and at 6700 it was down 7. Not huge differences, but there! We're in the ballpark for sure with our initial setting and did a final pull with it set back to "zero" at 3° advanced on the gear. That was our final run for the day and the 3rd run on the posted graph. Lengthy cam timing side note: I never paid much attention to people saying you need to adjust the cam timing by X amount for each Y amount the cam is brought closer to the crank. On my street car and every iteration of the General Leif's 8V engines, I just set the cam gear as close to the stock timing mark as I could and ran it. When the cam gear was adjustable, I would play with it to see where I liked the power curve best(or to meet my needs at the time; track/street). Usually that would be somewhere around "straight up" to 4° advanced(my street car had .040" off the head with a .040" headgasket at one point which is about .047" closer cam/crank relationship). With this 405 head shaved around .080" on a 2.6L B23 and ENEM C2 copy camshaft, 3° advanced made the best power with RSI's setup at the time(running E85 and a fancy header). They made somewhere around 178whp if I remember correctly. We ran that on pump gas with the same setup and it was really quick, but we never got really good testing on it as the motor was having some issues from the get go and blew up in the qualifying session for the first race with it in the car. Our current setup which has another .040" shaved off(.123"/3mm total) so I didn't think it would necessarily be optimal but obviously would work to start with. I think people have said something like it's 1° retarded for each .010" closer the cam is to the crank, so if you take .080"/2mm off the head, just set the camshaft to the stock timing marks and you'll actually have advanced it a tooth from where it was previously and all will be happy. Us having another .040" off the head and needing about 3° advance on the cam gear is pretty close to that suggestion. RESULT: ![]() From our Facebook Page: Quote:
![]() In response to Billy seeing our AFR jump at 5200rpm for the 2nd run: Quote:
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 Endurance Racecar - The General's FB page - Oregon Volvo Tuners - Died ![]() Last edited by klr142; 07-03-2019 at 03:56 PM.. |
#29 |
![]() Great result!
#30 |
Turbo, what?
![]() Hey Dan, I just edited the crap out of that post. Take another read when you have time.
#31 |
Vintage anti-ricer
![]() Join Date: Oct 2004
![]() On the cam timing, I actually did the math on mine when I built it up. I forget the numbers taken off the block and head now, been years, but between headgasket choice and the amount trimmed from block and head, it came out to .030" shorter than stock. I timed the came, found out I did in fact need 3* advanced to get the cam straight up, so the .010"/1* did come out spot on for mine.
Awesome writeup for sure! I did find pulling timing from about 10* advanced back to stock on the top 3 rows made virtually no difference in how it drove or in mileage. Spool is better, lost power when it spools though so I need to add some back in. I did also note a LOT of fuel in the high load bins, even on the stock map. I had to trim mine by 30-40% in the 5k+ ranges. Explains why it was pig rich. lol
RIP Doug Williams "Mr. Doug" 4/15/2009 Pete Fluitman "fivehundred" 7/14/2013 Mick Starkey "TrickMick" 1/10/14 Mark Baldwin "blue850t5" 7/19/18 Nick Fengler "fengler" 8/6/18 Thomas Fritz "stealthfti" 10/11/18 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
#32 |
dude
![]() Damn kyle when are you writing an lh book? Good info.
#33 |
![]() Yup, good writeup. Our experiences mimic yours in that cam timing is best when it's 0 or as close as is reasonable. I really like how this hangs on past peak power. Would make the gear spacing on a stock gearbox so much easier to live with.
I see that the kink at 4600 is still there, at least a little. I thought it might go away because of the B21 intake you have, but no. WHAT IS IT???!!! Our combos are different enough that we should be able to figure it out through process of elimination. Must be some kind of exhaust tuning effect... |
#34 |
Turbo, what?
![]() Haha, Luke, I'm not that good! Just learning more every day about what you can do with LH on the tuning side. Mr. Jaybee and the Jetronic.info guys are doing the most with getting us awesome XDF files to use on TunerPro and permit getting things dialed in more.
Thanks Dan. On my street car I've seen more benefit at low rpm than what this dyno experience showed(when advanced 6° instead of 2 or 4 at times), so I think it depends on the rest of the setup/camshaft. Some camshafts seem to have larger differences when you move it around than others. None seem to like retarding too much from my experience, except the T cam...... Hahaha I am also happy with how the power hangs on at higher rpm! Even with it running richer at the last race, it definitely was a benefit to let it rev way out if you're trying to accelerate as fast as possible. That's even with the really close gearing! (T5 transmission with the 2.95 first gear, 0.80 fifth gear and 4.56 rear end) Regarding the torque curve dip... Yeah, I don't know what to say there! This setup has the stock downpipe sort of thing, but it does have the K-Jet manifold and a 405 head... Funky buisiness! It's there on all of my dyno runs with the K(around 4400 with the cam advanced 4°), H and K13. The H and K13 are between 4500-4600rpm. |
#35 |
![]() Want to share the rough shape of your ignition timing map? My car is slightly more compression and slightly larger cam, but otherwise pretty similar.
(I mostly want to steal your timing map so you can still beat at Lucky Dog later when my car finally runs) |
#36 | |
Turbo, what?
![]() Quote:
By the way, I can't remember if your engine is together yet? Does it run? Do you know the cranking compression just out of curiosity? You're running Mega or Microsquirt, right? What throttle body and intake are you using? |
#37 | ||
![]() Quote:
It's 90% together. I have to mount some stuff and clean up some wire routing, but it's mostly together. It runs! Though I haven't done anything more exciting than puttering around the neighborhood. https://www.youtube.com/watch?v=TcfO0hk3x4Q I don't. I suppose I should check that. Quote:
I'm (unfortunately) running the stock LH2.4/3.1 intake and throttle body for now, but I'll switch at some point first to an 70mm-ish Ford electronic throttle body, and a better intake. |
#38 | |
Turbo, what?
![]() Quote:
![]() I'll see if I can smooth out my timing map now and post it up soon. I haven't had any time and right now I'm supposed to be researching a new washer as ours stopped working... Doh! But basically, peak timing of between 27-30° is apparently normal for high HP NA redblocks on the swedish forums and we had been running a max of 31 and are now settled at 29. I'll get a picture later! |
#39 | |
![]() Quote:
edit: and that timing sounds right, 27-30 is about what I though it should be. I think my map currently has 25 across the board in the top row, which might leave a few hp on the table, but also won't blow anything up. |
#40 |
Turbo, what?
![]() Do it, do it! Or come to the track and hang out with us when we race!
Regarding ignition timing, start closer to 10 at low rpm and ramp your way up. I think I’m still only around 18-19 at 2000rpm as it can’t take more than that. Likely around 22-24 at peak torque for us which is between 3500-4700 or so? I still need to get a screenshot of my timing map as I started smoothing the fuel side yesterday and that’s as far as I got. |
#41 |
![]() Finally did some actual tuning on the car! Got a few hours of driving in today with the computer connected, and the VE table is now close enough.
Conclusions:
Track day tomorrow at Pacific! |
#42 |
![]() I would love one of the 59mm throttle bodies from Timos Motor but they seem unwilling to help a brother out...trying to see if I can find a source for just throttle blades, I'll do my own oversize. Maybe if we had a bunch of people that wanted to do this, it would be worth their while.
#43 |
![]() Some TB sizing math may be in order, I think. The stock casting certainly has a little more to give.
#44 |
#45 |
![]() It is! However, bigger can mean controllability problems at the bottom end where a small change in angle causes a very large change in area, which makes it hard to putter around (but will make power at the top). I'll eventually (maybe this moves it up the priority list) mill an adapter so I can switch to a Ford electronic throttle body that's ~75mm. Since it's electronic, you can keep really fine movements down at the closed-end so it doesn't hurt drivability (and also do other magic like automatic rev matching...).
I now have data from running the car on track, so I have a log with lots and lots of 3-6.5k RPM pulls. Here's something pretty awesome: ![]() Y axis is MAP, and X axis is RPM. Color is VE, but you can mostly ignore that for now. The whacky dip-then-bump in the 4800-5200 range indicates that the cam really loves 4800 rpm, then doesn't like 5200 as much, then starts to like things again back above 5600. However, since it's losing a full 7kpa between the peak at 3500 RPM down to the trough at 4800, the throttle needs to be bigger. And the shape of peak VE agrees: ![]() This suggests the sweet spot is around 4200-5000 on this cam, which feels about right driving it. The resonance in the intake manifold is certainly a contributor here - that peak in VE is too flat to be from a well-matched cam and intake (which is a feature - it flattens out the torque peak). tl;dr I (probably) need an intake that isn't the LH2.4 intake, and I need a bigger throttle. |
#46 |
![]() Sorry dude, I was just messing with Cam here. The Timos throttle body upsizes are from the stock 55mm to 59mm, which ends up being something like an 11% increase in area.
75mm is frikkin huge, but being that you're looking at going electronic you're probably smarter than I and can make it work. I am enjoying the science above. Testing+data+documentation>butt dyno. |
#47 | ||
Turbo, what?
![]() Yay!
Those graphs and logs are definitely the benefit of running programmable EFI unlike shoestring/redblockpowered and I here... |
#48 |
Turbo, what?
![]() Oh, by the way, I turned Lambda feedback on for our race at PIR because the car was running too rich in the lighter load areas(13:1) and I wanted to try and make sure we had no fuel capacity issues again. Because of that, it ended up learning and leaning out the WOT stuff a little more than wanted but I sort of expected it. It was between 13.2-13.8:1 with it mostly being around 13.5:1 during the race. I want a little more fat than that to keep the engine cooler, but I don’t know if that had anything to do with why we were having some warmer engine temperatures. I don’t think the radiator leak was helping.... hah
#49 |
Having too much fun
![]() Yea I've always found that once you get the map the way you want it, if you turn on lambda feedback, LH will lean it out. I guess you just have to go richer than you want up top to log the result down to where you want it once it's leaned out?
Feedback: http://forums.turbobricks.com/showthread.php?p=5433066 For Sale: B230F and 240 Goodies! 240 Corner light & Alternator Transmission Squad |
#50 | |
![]() Quote:
Out of curiosity, why do you recommend using 3-5 instead of 2-4? With a 4.11, the T5 I have (3.35 1st, 0.68 5th) should put 2-3-4 in a pretty nice spot (61-91-121 mph respectively at 6500 rpm). Agree - probably not worth putting it on a dyno until I have an intake sorted out. The exhaust is already sorted, it's a KL 4-2-1 header to 2.5". We'll see if intake gets done before October. There's a good chance, as there isn't too much else left to do on the car. |
Thread Tools | |
Display Modes | |
