Old 12-02-2018, 11:49 PM   #1
ktm450
Default 240 wiper motor struggling
I have put 3 used wiper motors on my 1991 240 over the years, and all have eventually gotten slower to the point of being too slow for a heavy rain. I also have another 240 and the wipers work way better on that car, almost as fast as on my 1993 940 T. I am beginning to wonder if it could be wiper linkage? I have not tried to lube the linkage up. The motor sounds like it is struggling, laboring, and moaning. This last motor I put on worked great for a couple months and then got slower, and louder. Any suggestions would be appreciated. Thanks.
KTM450
1993 940 8 valve turbo 70000 miles
1991, NA 244DL 111000.
ktm450 is offline   Reply With Quote
Old 12-03-2018, 12:46 AM   #2
iHateVolvoPeople
Lord_Athlons daddy
You can add an additional ground to the wiper motor and it may help a lot. I know earlier cars did not get a dedicated ground but later ones did (not sure what year that started). You could also possibly lube the internals of the motor carefully with the appropriate lube.
http://forums.turbobricks.com/showthread.php?t=309689
Feedback Thread
Current:
93' 244T M47
93' 245 M47
90' 744 AW70
90' 745 AW70
94' M-Edition Miata 5 speed, 93k
95' Camry A140E, 246k
91' 745 Regina AW701, maybe future turbo project
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745T AW71 (Donor car for the 91)
Old 12-03-2018, 06:51 AM   #3
Janspeed
lubing up all linkages will help. The geardrive inside the wiper motor housing also needs to be lubed, it's probably a worm drive. In old wiper motors the grease has often dried out resulting in gunk that does no lubrication at all.
Old 12-03-2018, 08:14 AM   #4
2turbotoys
Salaminizer
2turbotoys's Avatar
Adding a ground to the top motor mounting screw fixed my slow wipers.
1978 242, getting prepped for LS
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 12-03-2018, 10:45 AM   #5
JW240
All idiot, no savant
JW240's Avatar
No loose magnets in the motors? Many of the newer 240 wiper motors have that.
Extra ground won't hurt, same with some grease. With the motor decoupled from the linkage, how hard is is to move the wipers?
Old 12-03-2018, 11:20 AM   #6
283SD
Magnets come loose causing the motor to bind, I have re glued them with JB weld with good results.
Old 12-03-2018, 12:12 PM   #7
Mr. V
Mr. V's Avatar
How good are the aftermarket wiper motors we see advertised by the various online retailers?
Old 12-03-2018, 12:24 PM   #8
intothelabyrinth
intothelabyrinth's Avatar
Take it apart, my money is on one of the magnets has come unglued. Epoxy it back and go on with life!
1986 245 Auto (RIP)
1986 245 Auto (RIP)
1988 245, M47 (My Daily)
1989 245 Auto California Car
1993 245 Classic (Bro's Daily)
1999 V70 T5 Auto (Girlfriend's Daily)
1988 245 ('93 B230FT project)
Instagram
intothelabyrinth is offline   Reply With Quote
Old 12-03-2018, 10:04 PM   #9
quillc
yv1a.com
quillc's Avatar
1. Your wiper linkage is likely binding causing the motor to overload. Heat kills motors.
2. Loose magnet.
3. Worn carbon brushes.
Chris
www.yv1a.com
Old 12-03-2018, 10:06 PM   #10
2turbotoys
Salaminizer
2turbotoys's Avatar
The ground wire is by far the easiest thing to try first. Mine went from undrivable in the rain to working normally. I also bought a new wiper motor to fix it but the ground helped so much I haven't bothered installing it yet.
Old 12-03-2018, 10:56 PM   #11
ktm450
Ok thanks guys! I'll check the ground first and then the magnets and brushes. The car is a 1991 240 sedan that has the slow wipers. My 1992 is the one that works great. I wonder if 1992 is the year they grounded it better? Also, I did pull the cover and put fresh grease on the plastic gears.
Also, I have a slight clunk on the drivers side under the dash when the wipers are running. And, I haven't tried to move the wipers with the linkage disconnected, the weather here is crap and I don't have a garage. I will also get up under the dash, and spray the linkage with motorkote spray. Thanks again!
Old 12-03-2018, 11:08 PM   #12
iHateVolvoPeople
Lord_Athlons daddy
240 wiper cables scare me. When mine breaks I’m just scrapping the car and buying another Toyota.
Old 12-04-2018, 06:27 AM   #13
cleanflametrap
cleanflametrap's Avatar
Default Diagnosis
Originally Posted by ktm450 View Post
I have put 3 used wiper motors on my 1991 240 over the years, and all have eventually gotten slower to the point of being too slow for a heavy rain....
Having done this job three times before, you know what quick, dry, and easy work it is to disconnect the motor's crank behind the glove box. Fact is, you don't even need to pull the glove box to reach it with one shorty 10mm wrench. If you're still at all limber, you can do it with the doors closed from inside, even.
So like JW240 already posted, just disconnect and see where the trouble is. Sure, we all have had loose magnets and corroded grounds, but if you've changed the motor 3 times, I'm betting on that left side drive having lost its lube. Not the cables, but the spindle. That's the job you want dry weather for.
http://cleanflametrap.com/wiper.html
-Art
Old 12-04-2018, 09:05 AM   #14
zapata
I would recommend a good used one over an aftermarket motor. I bought an aftermarket one from either FCP/IPD (I can't remember which) and the intermittent feature would only work sporadically. When it did work, the delay between activating was way too long.
I'm still annoyed that when I was trying to fix the original one (separated magnet) that I dropped the magnet.
zapata is offline   Reply With Quote
Old 12-04-2018, 10:43 AM   #15
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Originally Posted by PromiseRing View Post
240 wiper cables scare me. When mine breaks Iím just scrapping the car and buying another Toyota.
Everyone has hit the mark.
1. Add second ground
2. Pull and disassemble, inspect/repair/lubricate, reassemble and reinstall
3. While the motor is out, inspect the linkage. If it moves freely, it's most likely the motor. If not it is probably both. Might as well pull the assembly apart and relube.
-Stephen
#mclovethesenuts
-My car: White 1991 244, 330k miles. B230F LH2.4, AW70, R134a retro
-Wife's car: White 1990 244DL, T cam, 200k miles.B230F LH2.4, AW70 w/aux cooler, Virgos, tow hitch
-PSM 2002 Subaru WRX wagon: EJ205, 5MT, 120k miles, Perrin TBE
-1997 Subaru Legacy Brighton: EJ22, 5MT, 236k miles
Old 12-04-2018, 01:08 PM   #16
Mr. V
Mr. V's Avatar
Nah, that is unnecessary.
Mine broke on my 244 Turbo, and the fix was not as bad as I thought it would be.
I removed the dashboard to get access to the wiper mechanism, and with the dash removed everything was accessible.
How to: http://cleanflametrap.com/dash.html
