brickunderpressure
- Mar 11, 2010
- MelbourneFL/AtwaterCA
So, obviously I need to replace the rubber fuel lines. Question is I dont have any manuals or diagrams for fuel system. Replaced the soft hose that connects from hard line on driverside firewall to fuel rail near FPR. Is that line the "return" line?
Next question, I need to replace the soft line that runs from the fuel rail down the frame of car to the fuel filter(fuel feed line to engine?). That hose needs to be completely replaced (or does it). The line has a rubber outer cover and a hard plastic inner hose. should I just splice some new hose to some fresh original hose or replace all of it. The hose I am refering to is the one that has these isolaters that keep the line off of the car. I am concerned about having to thread a new line threw these isolator grommet things that are probably as fragile as the hose.
any advice or suggestions would be greatly appriciated
