Okay quick update and some more details.
I went and replaced the cold start injector with another one that the previous owner had provided just in case since it seemed like a good place to start. Tried to start the car initially with little success, I could tell the engine was starting to turn over but seemed like it wasn't combustion just wasn't happening.
After a couple tries it was getting worse so I went and took a look at the leak location, seems like the leak is actually coming from the Airflow Sensor from what I understood from the diagrams.
I took apart distributor cap and made sure it and the wires were maintained, there was some corrosion under the distributor cap connections so I hit them with a wire brush to clean them up and the ignition rotor to be safe too.
I was halfway trying to take the Airflow Sensor off to replace it with another extra that came with the car when I decided to try another run and see if anything changed before I tried multiple things at once. Once I had the cap and wires back on correctly I made another attempt of getting the car to turn over.
This attempt I was able to get the car to turn over for a couple seconds before there was a pop that sounded like a vacuum tube popping off. I was able to record this part if you think I heard wrong please let me know
https://youtu.be/kkEjXpE6vgg
Here is a picture of where the fuel is dripping out of as well in case I am wrong with my assessment.
http://i.imgur.com/X9dxC2r.jpg
My plan tomorrow is replace all vacuum tubing and re-secure everything that is secured with zip-ties with hose clamps instead, unless anyone thinks I am missing the mark.
Sorry if past descriptions weren't great I was going off of other peoples experiences.
