Old 08-29-2019, 09:57 AM   #26
They're boxy but good!
Location: See my real-time location on Maps: https://maps.app.goo.gl/xiryhjZzwpSvTtnn6
You will be giving up squish, which is actually worse...
I've already been down this road with the B21, it worked very well. If the wire hadn't pulled out of the old ass Volvo EV1 connector and burned a pencil eraser sized hole through the cometic and the head I'd probably still be running that setup.
"Over the hump of Truth and through the flaming hoop!"
-S.B. Squarepants
Old 08-29-2019, 12:04 PM   #27
Originally Posted by iHateVolvoPeople View Post
What did they do?
7.5:1 CR and mechanical fuel injection.
Old 08-29-2019, 02:10 PM   #28
mikep
The MP
mikep's Avatar
Originally Posted by VB242 View Post
I cc'd the head and it appears to be 49.7cc's. my thinnest feeler gauge .008" was a little tight, so I'm assuming John V is correct at the pistons being in .007" , this gives 10.94-1 on the summit calculator. I'm going to get the head skimmed and check it again. I'll probably order up a cometic thick enough to reduce the CR below 9-1. The pistons appear to be forged, but I'm no expert, I'll have the machinist look at one when I drop off the head.
Did you include the stock head gasket thickness in the calculation?
ass-thrush.
Originally Posted by kyle242gt View Post
TBOT is like Google, run by Underpants Gnomes.
Old 08-29-2019, 02:42 PM   #29
iHateVolvoPeople
Eh, no point in today’s era. Better fuel, tuning, etc. 7.5:1 is kinda useless unless you just wanna throw boost at it
Feedback Thread
Current:
93' 244T M47
90' 744 AW70
95' Camry A140E, 254k
99' Camry A140E. 256k
Past (Volvos):
80' 242gt M46
88' 245T M47
92' 945T AW71
94' 945T AW71
90' 745 NA sold
93' 945T in burgundy
91' 745 Regina AW701 turbo (traded for 96 Camry wagon)
93' 245 M47
Old 08-29-2019, 02:56 PM   #30
I used .040"
Old 08-29-2019, 03:00 PM   #31
Stiggy Pop
Stiggy Pop's Avatar
I used .040"
b230 gaskets are 1.2mm/.047" compressed. Would guess b21 is probably the same.
'79 242
943 pickup
Old 08-29-2019, 04:24 PM   #32
I thought it was .047 new and .040 compressed? The extra .007" gives 10.72-1
Old 08-30-2019, 12:05 AM   #33
Stiggy Pop
Stiggy Pop's Avatar
Post
I called Elring a few years back and they told me .047” compressed, idk
Old 08-30-2019, 09:19 PM   #34
Broke4speed
Broke4speed's Avatar
Sometimes math gets in the way of work, IMO.
Assemble the way you want, and drive. The internet will always have reasons why something shouldn't be done.
1984 244/ B6304S+T / AW30-40 w/Poi-Shift.
Old 08-31-2019, 08:06 PM   #35
mikep
The MP
mikep's Avatar
Math is important if you don’t want to keep trying to make it work. Math lets you do it once.
I asked about the gasket because the CR return on the calculator surprised me. It ran good, but we never got it tuned.
that’s what we are trying to do, numb-nuts. The more you pressurise it, the longer it gives a good push on the down stroke. And we have a big open chamber with hardly a quench pad in sight.
You can get away with a lot if you keep the octane up and the tune conservative (and fat). But that’s not how you make big power.
Old 08-31-2019, 08:49 PM   #36
New rings showed up today, ITM from Rock Auto, not chromed like machinist said I would get. He said hit the bores with 320 grit and assemble the pistons/cylinders with ATF . Should I do something different with the rings not being chromed? I will try to assemble the bottom end tomorrow with new big end rod bearings and turbo drain welded in oil pan. Machinist recommended .024"-.025" ring gap, this is ok per Haynes manual specs as well.
Old 08-31-2019, 11:06 PM   #37
John V, outside agitator
Dang, I guess I better pack up that thing and get a mailing address and get it sent, huh?
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 09-01-2019, 01:26 AM   #38
Vincent Gagnon
Vincent Gagnon's Avatar
Hey! Ship me my manual ASAP, I need to leave in a week!
Member of TBCCS
Old 09-01-2019, 09:12 AM   #39
iHateVolvoPeople
Yeah numb-nuts, and mordern fuels and tuning allow you to run higher compression with higher boost, making a much better daily driver.
Of course your error margin goes way down with higher compression, but something tells me OP isn’t making lots of power anyway.
Old 09-01-2019, 11:32 AM   #40
Except for the fact that 'modern' gas is crap.
Old 09-01-2019, 12:10 PM   #41
Dynod 257hp to the wheels at 18psi, did not Dyno at 24psi. Something tells me you're a whiny little know nothing Dunning-Kruger incel hater. And gas is pretty inconsistent. Go ask your fiancee, whoops I mean girlfriend what she thinks about it.
Old 09-01-2019, 01:08 PM   #42
mikep
The MP
mikep's Avatar
He knows he is, but what are we?
I feel like I'm back in class already "he said it so i said, it, and if I get in trouble I'll tell the principal"
And that always does what they expect.
And now, back to actual theory and building and blowing **** up.
Old 09-01-2019, 06:27 PM   #43
iHateVolvoPeople
Except for it’s not. And we have ways of knowing exactly what the content is and exactly what is happening inside the engine in each gas (except I guess OP doesn’t know)
Nice, a stock 2.0 turbo Chevy equinox produces similar power and runs on 87 octane. Learn how to tune your car and it won’t blow up. Sub 300whp b21 with M rods and aftermarket pistons, and you *still* blew it up. Find another hobby or pay a real tuner.
Old 09-01-2019, 07:38 PM   #44
And you are checking the content and exactly what is happening each fill-up..
Right...
Well for once you're on to something..The GM Ecotec 2,0 turbo is exactly the same 86mm bore and 86mm stroke with the exact same cylinder head design and configuration as the Redblock: Just look at the similarities!
Brilliant put down! I bet he's field-stripping and cleaning his AK..
But wait...why does the simplest routine maintenance jobs you undertake need 150-200 posts here in order for you do ruin things???
Isn't there a forum somewhere where you can get the help you need?
Old 09-01-2019, 07:51 PM   #45
Not to mention the centrally located spark plug and better feel injection and ignition systems. Other than that, they are almost identical in that they both have four cylinders.
Old 09-01-2019, 08:03 PM   #46
Your version of this hobby involves viral rocks and pennies in the valve train videos and posting unwanted and poorly informed opinions. Go polish your gun, it will keep you warm and abate some of your tiny penis insecurity complex.
There's plenty of G80 swap information available, why are you wasting bandwidth with your feeble post? Search noob.
Old 09-01-2019, 08:54 PM   #47
iHateVolvoPeople
My version of this hobby includes not having rods hanging out of the block.
(yet)
Old 09-01-2019, 08:58 PM   #48
Tell the to the old timers that pulled up to the 'white pump' at the Standard station with their hot rods back in the day for some 110 to fill up on Friday night for some weekend fun.
Old 09-01-2019, 08:59 PM   #49
iHateVolvoPeople
Tell the to the old timers that pulled up to the 'white pump' at Standard with their hot rods back in the day for some 110 to fill up on Friday night for some weekend fun.
What’s your point? You can still get consistent ethanol free 100+ octane.
But it’s ****ing expensive
Old 09-01-2019, 09:32 PM   #50
Modern pump gas is cut with ethanol low octane crap gas.
