Old 08-09-2019, 04:10 PM   #1
BILLBARD
Default Faulty Alternator
The Alternator on my 940 died. I have spares but I thought I'd try to repair this one. I have all the screws out of the frame but it won't come apart. I've tried to force screw driver between the halves of the frame but it doesn't want to come apart. Has anyone in the group taken 100 Amp Volvo alternator apart. If you have how did you get the frame to come apart?
BillBard
BILLBARD is offline   Reply With Quote
Old 08-09-2019, 06:12 PM   #2
What 100 amp alternator is it? There are three stock types. Two bosch styles and a Nippon denso version. I like the Denso ones. they all use diffgerent parts like regulators, brushes, etc.
Some forceful hammering with a brass punch may help. Be very careful of the windings. You can also use some penetrating oil and let it soak for a while before trying to take it apart.
Old 08-10-2019, 05:02 PM   #3
BILLBARD
Default 940 Faulty Alternator
The Alternator in my 940 is the Bosch type.
The label on the cover of the alternatorit says 100 Bosch underneath that are the numbers 0 123 213 007 under that it says NC 14V 55-100A then MADE IN GERMANY next it says VOLVO I M P and on the very bottom are the numbers 91 302 08
That's all I've got as far as identification is concerend.
Old 08-10-2019, 06:29 PM   #4
I don't know the numbers. But there are two bosch versions. The older style which looks similar to the all the alternators 240s used. Then there is the late bosch style which looks like a larger version of the ND alternators. The later bosch style has a large black plastic cover over the back of it. The earlier one has the regulator mounted on the back and no cover.
Old 08-10-2019, 07:48 PM   #5
lummert
lummert's Avatar
This is a rather expensive alternator.
https://www.fcpeuro.com/products/vol...40-940-al0750x
Old 08-10-2019, 11:33 PM   #6
That is the late style bosch in the link.
