- Nov 19, 2002
- California
I always try to pull data before and after a repair instead of just throwing parts
I had a 96 Ford Explorer in the shop with an EGR code recently. Software pointed at the DPFE sensor as the likely cause. Voltage was only going to 2.5v with EGR flowing. Spec was 3.5. Installed a new one and tested it again and got 3.50v! I could confidently ship the car knowing we can charge him and not get an angry comeback.
I had a 2002 Toyota Echo in front of me with a p0420 cat efficiency code. I used the scan tool, wish I used the scope; faster data, to graph both the front and rear o2 sensor. The rear sesnor was oscillating WITH the front sensor=bad cat. Once the new cat is on I will repeat my tests to verify the repair.
On obd 2 cars I can look at ECT sensor data. I found one last summer reporting Temps as if we were in a Siberian winter.
TBRICKERS love to throw out part suggestions but really you need to get off the phone and do tests before and after.
Learn to do tests with the proper tools!!!
