Old 07-11-2016, 09:33 AM   #276
t8fanning
8v are still cool, right?
t8fanning's Avatar
Microsquirt only has two fuel channels. You can't add more. I misspoke above. You can however add two additional spark channels. Each injector needs its own channel for sequential from what I understand and microsquirt only has two. So if you convert two spare outputs to spark channels the best you can do is sequential spark and batch fire fuel.
Cometic itself sells the gaskets. I got mine from their website.
1982 242 Turbo.
Old 07-11-2016, 10:45 AM   #277
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
cometic sells it, yoshifab sells it, there are a couple of places to get the gaskets.
Megasquirt Tuning!
Old 07-11-2016, 11:36 AM   #278
cwdodson88
summit has cometic gaskets also
The Build Thread
SVEA - PUSHROD TURBO!
Old 07-11-2016, 02:17 PM   #279
haltechsupra
haltechsupra's Avatar
Thanks for the information T8fanning, Linuxman51, and cwdodson88.
haltechsupra is offline   Reply With Quote
Old 07-11-2016, 06:21 PM   #280
haltechsupra
Did the retorque, went to 120 ft/lbs, and everyone of the head nuts went a full turn and a half at minimum, so it was definitely time. Seven hundred miles on engine now.
Down to head studs.
Cam box, upside down.
Buckets in order.
Filter and valve cover.
Camshafts.
Thin layer of gasket maker around outer edge of cam box.
Back on the head.
Buckets back in .
Cams back in.
All back together. Wait a few hours for gasket maker to dry.
Old 07-20-2016, 11:25 PM   #281
haltechsupra
Got this running spectacle in trade for a vortech 350 i had and a rebuilt 700r4. Should be a great parts donor. That valve cover is pristine, i think mine is getting a facelift.
Old 07-25-2016, 05:32 PM   #282
haltechsupra
Zachary daniel Tucker did this for me,On my fb page, turbo world-where all are invited. Will it spool?
Old 07-25-2016, 07:40 PM   #283
haltechsupra
Uh , is it supposed to sound like rod knock? https://www.facebook.com/kris.d.weld...6274778939937/
Old 07-25-2016, 11:37 PM   #284
haltechsupra
https://www.facebook.com/kris.d.weld...6275322753532/
Old 07-26-2016, 06:14 PM   #285
haltechsupra
Flexplate is broken/ bolts loose or broken. I used loctite. Will have pics tonight or tomorrow when i have time, right now this baby girl is being needy, ;) .
Old 07-27-2016, 02:36 AM   #286
BillyMaysHere
BillyMaysHere's Avatar
Kenny had to deal with pesky flex plate bolts. I forget his final solution
Old 07-27-2016, 08:40 AM   #287
linuxman51
linuxman51's Avatar
mine was a missing dowel pin on the block, but it was only an issue after the gm trans swap
Old 07-27-2016, 01:50 PM   #288
haltechsupra
I will see about dowel pin, if i remember correctly mine was missing too, smh.. Didn't even cross my mind till now. What was the final solution Kenny?
Old 07-27-2016, 07:10 PM   #289
Texas240
Prius Owner
Texas240's Avatar
put it back in
93 245 LS Engine Swap Project
Old 07-28-2016, 04:12 PM   #290
haltechsupra
Old flexplate pulled out.All bolts were hand loose, i made mistake of going all impact on it. So i used flexplate off of parts 16 valve, and bolts from the parts 16 valve as well as i stretched the bolts on the old one. Torqued to 50ft Lb and relock- tite , it with blue threadlocker. I also installed the bright HID kit(with ballast) from a 1998 supra, into the fog lights. To say it's bright, just isn't doing it justice.
New fog lights.
video.
https://www.facebook.com/kris.d.weld...6293974259808/
Old 07-28-2016, 04:20 PM   #291
linuxman51
linuxman51's Avatar
Originally Posted by Texas240 View Post
put it back in
this.
Old 07-28-2016, 04:25 PM   #292
haltechsupra
No dowels missing, all stock stuff there. for some reason i thought there may have been a dowel on the crank, but there's not.
Old 07-28-2016, 04:41 PM   #293
linuxman51
linuxman51's Avatar
nah. I also switched to arp hardware on the gold car's flexplate. and it was loc-tite'd
Old 07-29-2016, 03:52 PM   #294
haltechsupra
ARP hardware, damn, not a bad idea there.. But it was my own fault for using impact. If it happens again, then its arp hardware for sure. I think the trans will give out before the bolts get loose again.
Old 07-29-2016, 04:54 PM   #295
adomz
Volvo 486 owner :D
adomz's Avatar
Yeah, think something like that would get impounded and crushed and you'd get a really nasty ban plus penalty as soon as someone saw you on the road, here in the UK :D
Errr.... 242... No engine no cringdingding...
=->Adam's Joint Creations<-=
adomz is offline   Reply With Quote
Old 07-30-2016, 01:08 PM   #296
haltechsupra
Really, with the lights ? Or turbo out of the hood?
Old 07-30-2016, 06:07 PM   #297
adomz
Volvo 486 owner :D
adomz's Avatar
Lights are fine, just the snail sticking out and that d-pipe etc... Would just get crushed and so on :D
Old 07-31-2016, 01:07 PM   #298
haltechsupra
Yeah some places would not allow it, the police around here think it's fantastic. They stop and chat to me about it, usually beginning and ending with laughter. It surprising how many smiles per mile i get with this car, in all seriousness.
Old 08-08-2016, 01:58 PM   #299
haltechsupra
Cleaned up some wiring relocated some relays. Then found this, well dayum.
Passenger side engine mount.
And.. I did this.
Old 08-08-2016, 01:59 PM   #300
haltechsupra
1000 miles yesterday, self tuned (with help from Kenny and others online *THANKS*), self built with help on welding, and self gratifying. I need to upgrade injectors next hopefully, change tire and wheel combo, and add another 450lph pump. Pretty pleased, will be adding 70mm when injectors get upgraded, then spray or compressed air to aide spooling, on an already tragic lag wagon. Full boost in at 5100rpm, in first. It doesn't feel near as laggy as it sounds, it makes some power at 3800rpm and builds from there. Just doesn't make the psi.
