Old 06-22-2015, 04:26 PM   #226
80/20 speed parts club
Hey now, I don't go tearing engines out because the TC bolts come loose
Old 06-22-2015, 04:36 PM   #227
propav8r
F*ck Edgar
propav8r's Avatar
Hey, I WANTED to be without my nice 240 for 3 weeks. Psh.
nipple farts
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 07-09-2015, 12:31 AM   #228
Alignment is off, suddenly. Weird.
Old 07-09-2015, 01:04 AM   #229
propav8r
F*ck Edgar
propav8r's Avatar
Old 07-09-2015, 01:11 AM   #230
Old 07-09-2015, 01:12 AM   #231
Harald's wife: ""
Old 07-10-2015, 03:18 PM   #232
Drove the stupid thing to work on the highway. It just loves accelerating above 40 mph. It also loves it when it's not freaking 95 degrees outside.
Old 07-10-2015, 04:27 PM   #233
Jack
junkman
Jack's Avatar
where did you find the intake tube ? (air filter to turbo)
Old 07-10-2015, 04:47 PM   #234
I made it. 3" 45° bend from Columbia River Mandrel Bending cut to size with a 1" weld-on nipple from ATP turbo for the CBV. Haven't bothered with a PCV nipple because my current solution is ****.
Old 07-11-2015, 10:58 PM   #235
Set the wastegate actuator rod to zero preload and took out the MBC. Still goes to 10 psi at the top of first and 12 psi at the top of 2nd. Ugh. Hope I can pick up some midrange with the MBC While keeping creep at bay. So far it's kind of laggy...
Old 07-12-2015, 04:05 PM   #236
Tuff240
240 Ninja
Tuff240's Avatar
It's probably laggy because at zero preload you are bleeding off exhaust out the wastegate before full boost hits.
-Patrick
Old 07-12-2015, 04:33 PM   #237
Oh yes definitely. At the same time I'm still experiencing some creep. I was expecting this wastegate to be much better at controlling boost I'll tighten it back up and see how I like it.
Old 07-12-2015, 05:52 PM   #238
Tuff240
240 Ninja
Tuff240's Avatar
Where are you tapping in to get boost signal for your manual boost controller? The longer the hose, the more creep you will see usually.
Old 07-12-2015, 06:10 PM   #239
It's right above the coupling at the outlet of the turbo now. Made it as short as possible.
Old 07-13-2015, 11:54 PM   #240
Duder
Comes with a free Frogurt
Duder's Avatar
I think this is a sign that you need to recalibrate for 12 psi. If you don't want to do that, you can start porting the wastegate housing.
All of the symptoms and behavior you mentioned indicate that the wastegate is choking with the setup you have. If it's opening early then the creep is due to the wastegate port not being able to flow enough exhaust gas to regulate turbo speed below the 12 psi level.
Old 07-14-2015, 12:56 AM   #241
Figured that may be the case...been avoiding thinking about it as Currently the primary reason to keep boost down is engine management. May not be an issue soon enough. At any rate, if ai find downtime and an excuse I may just do that.
Old 07-23-2015, 01:05 PM   #242
Found the sweet spot some more. Cranked down the MBC a little more and the turbo now feels nice and responsive. Car as a whole seems much less happy when the ambient temperature climbs past 85 degrees and it's sitting in traffic a whole bunch, which is fair enough.
Now I'm turning my attention to the PCV system. I have found that my Greddy catch can is not doing all that great of a job at separating oil and air and is just acting as a canister of sorts that accumulates a bunch of milkshake ( it worked much better with the valve cover port but that's not really realistic anymore. Currently I have it venting to atmosphere which has several advantages in terms of keeping the engine from detonating but I'm polluting much more as a result. The challenge with this early style block is that I only have a single 1" nipple coming out of where the oil separator box would rest in a later model block.
Toby Edelman suggests running an exhaust venturi port to have my crank case run as a negative pressure system. I like that idea, just don't know how effective it is.
What say you, TB? I want to convert to a negative crankcase ventilation system. How can I go about it?
Old 08-04-2015, 11:30 PM   #243
Ordering a pro-vent and adding a nipple to the valve cover.
Parents are out of town for a month so I'm making use of the offending A4 as my runabout while the 242 squats in their garage on stands, leaking oil.
Taking the opportunity to do some work. Putting it here to refer to later
-passenger side poly engine mount with oil shield
-extension hose and adapter for oil pressure sender plus extra bit of wiring
-ported wastegate hole ~1mm and deshrouded a whole bunch (now that Inlook at it, I'm not surprised that creep was an issue. Looks way better now)
-tightening up rear suspension. There is something clunky out back
-240T oil cooler and Summit Racing filter relocation kit with a gigantic Royal Purple filter. Cooler itself does not fit the stock location so it will probably end up residing under the radiator support
-FRONT MUDFLAPS ARE GOING IN!!!
-fix horn wire
Old 08-05-2015, 07:54 AM   #244
AndrewNance
Amateur hour!
AndrewNance's Avatar
Make sure you wreck the Audi and then deny all accusations.
'71 142
Feedback
AndrewNance is online now   Reply With Quote
Old 08-05-2015, 02:19 PM   #245
Duder
Duder's Avatar
Good deal. Hope that works out for you. Keep in mind: the boost pressure you want to run with a particular turbo setup is inversely proportional to the wastegate flow capacity needed. Lower boost --> larger wastegate, since you are bypassing more flow around the turbine to reduce turbo speed. Might seem a bit counterintuitive at first, and easy to forget that particular relationship when you're playing with tuning.
Old 08-05-2015, 03:25 PM   #246
For sure. I focused more on smoothing the path for the exhaust to flow into the wastegate. Before 1/3 was covered, forcing a lot of the gases to do a couple 90 degree turns. Should be good for moderate flow.
On the other hand I found some light foreign object damage on the leading edge of some of the leading edges of the compressor wheel vanes. No idea as to how they may have gotten there...unsure as to whether I should put a new compressor wheel in there or not...
What say you, o His Duderness? Is it safe to run or do I keep the thing off the road for another week while I get a new wheel installed?
Old 08-05-2015, 03:38 PM   #247
cosbySweater
cosbySweater's Avatar
Leave it
1974 AMC Gremlin, 401 v8, 727, 8.8
1974 BMW Bavaria, m30, dcoes, getrag 265
1995 Porsche 993
2013 VW Passat TDI
Old 08-07-2015, 01:52 PM   #248
Duder
Duder's Avatar
Wheel damage looks pretty minor. You could clean it up with a sharpening stone or emery cloth or other very fine abrasive. I'd leave it for now, but make absolutely sure you determine the cause. If your air filter is dirty or coming apart, or there's some junk in the intake tube, you need to rectify that before it happens again.
Where would you get a replacement compressor wheel, and who would VSR balance the CHRA?
Old 08-07-2015, 01:53 PM   #249
Duder
Duder's Avatar
Also, those are blades
Old 08-07-2015, 01:57 PM   #250
Replacement wheel from ATP and the rebalance would be done at Diesel Fuel Injection Service, around the corner from ex-RSI. I'll leave it until I get a replacement DD/a need for a rebuild becomes apparent, whichever comes first.
I'll just clean it up and run it.
I did see that there were one or two tiny chips left over from when the intake tube was put together. I'll make damn sure that it's squeaky clean (Thought it was already, but I digress).
