Old 01-24-2017, 12:13 AM   #176
TIPSP
Got Boost?
TIPSP's Avatar
Time for some more happy items to come into the thread.
Small update. More like a list of things to do or need to order.
Engine related:
First on the list. The crank pulley is in the que at the machinist. I might have it by mid February. Just guessing. He was busy, but he is clearing his list.
Second on the list. Big bore B20 block with street performance in mind. Nothing crazy. Engine is in the que, but it will be done depending on parts arrival times... etc.
Third on the list. Fuel system research. Mostly me looking around for parts to compliment the addition of a few psi.
Forth on the list: complete supercharger bracket and tensioner design. Order pulley belt.
Fifth on the list: fabricate the intake piping and brackets, as well as, the supercharger bypass valve wiring and electronic control setup.
Suspension and brakes Related:
Sixth on the list: Rear R brake setup to compliment the front R brakes. The car is way too front bias even with the proportionate valve removed. Slotted rotors all around and some ferodo pads should be a blast. I have all the parts needed to swap the rear brake, except the rotors, and pads.
Interior and miscellaneous stuff
Seventh on the list: Finish the interior wiring.
That's it. Then this project will be completed.
Old 02-01-2017, 08:27 PM   #177
Homer
OEMplus++
Homer's Avatar
Not sure why I hadn't see this car yet. You've done everything just right! Props dude. What width wheels are those?
-Jacob:
2006 A4 - Comfy DD
Old 02-03-2017, 04:05 AM   #178
TIPSP
Got Boost?
TIPSP's Avatar
Thank Homer!
245s 40s on 17x8
Old 04-27-2017, 10:02 PM   #179
TIPSP
Got Boost?
TIPSP's Avatar
This car is like a stubborn little kid.
It decided to say **** you. I'm not leaving your street.
Lower alternator bolt sheared off. The oil is coming out breather box thing.
The engine is making a new sound now. This engine is coming out of the car. And sitting in the drive way until the new one comes in.
I'm so pissed. This engine was apart for a year and it wasn't rebuilt then. Nothing more I hate than wasting time.
No Davis this year...again.
Old 04-27-2017, 10:47 PM   #180
Texas240
Prius Owner
Texas240's Avatar
Are you or were you getting front brake squeal when braking at really slow speeds?
93 245 LS Engine Swap Project
Old 04-27-2017, 11:49 PM   #181
TIPSP
Got Boost?
TIPSP's Avatar
These pads and rotors are the junk that came in the IPD kit. They don't squeal. Only sometimes, like once in a month.
Alternator fixed. Gonna look at the engine Saturday. Might still make the trip... we will see.
Old 07-04-2017, 07:18 PM   #182
TIPSP
Got Boost?
TIPSP's Avatar
Exclamation
Just noticed pb stopped hosting 3rd party.
I'll have to delete my account with them.
Not sure when I'll update the images links.
Images should be updated soon... for the time being, you can view the story here: https://www.projectmoro.com/1975-242
Old 10-15-2017, 11:37 PM   #183
TIPSP
Got Boost?
TIPSP's Avatar
Testing image sizes
Pulley machined by 77volvo245: http://forums.turbobricks.com/member.php?u=15875
Engine by Ian and Eric @ hiperformanceauto.
B20 now 2.1L
9.1cr (if I remember correctly)
M-rods
Rotating assembly balanced
D Cam
Double valve springs
High Rev Lifter setup.
46mm intake valves.
38mm exhaust valves.
Ported head (gasket matched also)
Images are a little large.... hmmm. I might have to host on another site.
Old 10-16-2017, 04:51 PM   #184
77volvo245
77volvo245's Avatar
You can change the photo size on flickr
STSmachining
Old 10-17-2017, 03:34 PM   #185
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
Or on Imgur.
'88 245DL Uncle Sven|'95 945T Darth Haul|'82 242GLT B23E Lumpy the Angry Viking (sold)|'77 244DL, red/sold.|'90 744T C3P-LOL, gold/sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 11-02-2017, 02:16 AM   #186
TIPSP
Got Boost?
TIPSP's Avatar
Finally fixed most of the images in the thread.
Update....
Have been prepping the bay for the new engine. Cleaning all the oil and coolant spray from the old engine and radiator.
Finding a belt to fit.... This is the easiest way to route the belt for now.
Test fitting the intercooler.
punching some holes
Almost ready to drop in the new engine and break it in! Gonna run it NA for a bit. Then Ill add the supercharger. But I am finishing all the stuff I can without the engine in the car for now.
Old 11-02-2017, 01:01 PM   #187
Duder
His Dudeness, El Duderino
Duder's Avatar
Great to see it's moving along. Thanks for fixing the pics!
With 9:1 compression and 2.1L, what do you expect in terms of NA power from this engine - maybe 125hp? I am no expert in pushrod Volvo performance tuning but I'm always interested to see what can be done with these. My green '75 wagon still has a B20F which might be fun to boost at some point.
Old 11-02-2017, 11:50 PM   #188
TIPSP
Got Boost?
TIPSP's Avatar
Thank Duder! Yeah, same here... no expert... Probably somewhere around 130. maybe I will baseline the engine na. then see what everything else adds.
The stock cr is like 8.7 with kjet is around 110 hp no cat factory. which would be fun to boost. I'm playing with the idea of compound charging it at some point... Still have the stock exhaust manifold I will probably get ready to add a turbo
Old 11-03-2017, 10:56 AM   #189
amerbritcan
Hnnnnnng
amerbritcan's Avatar
That would be very, very cool.
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 11-11-2017, 08:58 AM   #190
churd9
churd9's Avatar
What kind of car cover is that you have looks nice
78 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=339008
churd9 is offline   Reply With Quote
Old 11-12-2017, 03:02 AM   #191
TIPSP
Got Boost?
TIPSP's Avatar
Here is the company: https://www.calcarcover.com/custom-fit-car-truck-covers
Almost done with everything I can get done with the engine out... ready to drop the engine next weekend probably and break it in.
Old 11-12-2017, 05:43 AM   #192
80/20 speed parts club
*supercharging intensifies*
Old 11-12-2017, 09:33 AM   #193
AndrewNance
Amateur hour!
AndrewNance's Avatar
Bad ass.
'71 142
Feedback
Old 11-12-2017, 12:09 PM   #194
Dirty Rick
Dirty Rick's Avatar
Update....
Putting an idler in the tension side of the belt is not going to work in the long run (especially with a small diameter pulley/roller). The small diameter idler is not compatible with a VRib belt that is a gilmer belt idler and it will not hold up on the tension side (loadwise) (the VRib belt will not like being bent backwards sharply either) and due to the run length of the belt will likely jump off the roller.
You need to run the belt like this with the larger diameter idler (with side ribs to keep belt centered on the pulley due to the run length) on the slack side
I realize you will need to rotate that intake elbow 90° (looks like it needs to be moved either way) but that is the best solution.
The belt setup you pictured will not last, I expect it won't make it out of the driveway.
In my design the idler pulley position may need to be moved closer to the small pulley to provide more belt wrap to help with belt slippage.
If the idler is located close to another pulley it won't need side rails.
Minimum idler diameter on the back side would be 3" with less than 45° wrap.
More wrap than 45°, the idler diameter should be increased.
Old 12-17-2017, 08:13 PM   #195
TIPSP
Got Boost?
TIPSP's Avatar
I was only looking at the belt path. That was not how I was doing the tensioner. Already finished the belt stuff for this version. I am probably going to make my own tensioner also once I install. Thank you for the concern.
Old 12-17-2017, 08:14 PM   #196
TIPSP
Got Boost?
TIPSP's Avatar
Update:
Engine was dropped in, cam broken in, and engine was broken in. I have been driving it now for a couple weeks putting some miles on it.
Cam Break in
Ready for boost!
Also, added the missing part from the lower bumper I never put on...
We noticed there was oil leaking.
Stupid me forgot to let Ian and Eric know that the old pan (reused on this engine) had oil leaking through the bolt holes.
We solved that issue (made a gasket and added more silicone at each pan bolt).
Brand New Injectors:
After 2 weeks of driving. Video not embedding...
https://youtu.be/tglxyqVILVI
I am going to redo the exhaust system in the new year.
After driving for another week, the transmission leak got really bad. I towed it Home. Super awesome guy and company!
That's all for now.
Ordered parts to fix the transmission leak and change the speedo gear. New engine has about 300 miles now.
More to come in the New Year!
Old 12-31-2017, 02:45 AM   #197
Vol242vo
Vol242vo's Avatar
Stunning.
Derek - 1980 242
Old 03-03-2019, 09:02 PM   #198
TIPSP
Got Boost?
TIPSP's Avatar
Update 03/03/2019:
Wow. It's been a while... The car runs and drives fine. I don't like the brand new injectors that are installed right now. I will probably go back to the injectors that were in the car before.
Anyways, I have been daily driving the car up to 09/08/2018 as I bought a new car to daily drive. I bought the other car, as it was a decent deal for all the work done to it, and now I have a car i can use when I decide to finish the projects on the Blue 75.
I have everything to finish the rear brake kit install (minus new rear spacers from BNE to work with the extra rotor hat). I will also order Ferodo DS2500 Club Race and stoptech slotted rotors for all four corners. We have this setup on the V70r and it is pretty crazy for street and some track duty.
Some misc images from the year.
I had Roger go thru the rsport unit and install the LEDs. So nice!
I added a magnetic phone holder for gps/ speedo/ track data modes.
More images on the website I think.
Not much work has been done. I was tired of the seat belt arrangement, so i put in some blue sparco belts with a cheap harness bar.
new office chair mode:
I wanted to try and enjoy more of the soundsystem in the car, so I swapped to a magnaflow muffler. It is a lot quieter now. I swapped out the JBL digital amps (as the multi channel amp was having issues) to alpine digital amps. The alpines are lighter, and a lot more powerful than the JBL, but the mids and highs do not sound as good.
Out with the old...
New units. I am running the multi channel amp bridged so it is 300watts per channel now to each 6.5" deck speaker. The 1200 watt sub amp still cant keep up with the level of the components. This sub needs like 3000 watts to have enough gain. hahah
Decide it was cheaper to buy a remanufactured unit than buy a press at this point in time...
First test fit run of the belt... Ignore the potato rotation status of the video.
Should be quieter once the intercooler and intake pipes are all hooked up.
As for fueling. I decide to tryout the additional injector controller from split second. It's a nice unit with easy to software. I am going to add one 1200cc injector (should be more than enough head room with this single unit). We'll test this out and see how it works. If it doesn't work well, I do have a few backup options (kjet turbo adjustable fuel distributors, CPRs...etc).
The car will not be done in time for Davis or IPD this year. We have lots of house projects to do, and I can't remove the daily driver option from the Blue 75 just yet. We will need the extra car soon as my brother is putting his car in the shop to have some work done to it, and I will need to put a new clutch in the new car.
As you can see, some of the engine parts need to come off to be cleaned, and painted. Hope to do that one day
That's all for now. I hope to finish this car this year.
-Jeff
Old 03-03-2019, 09:26 PM   #199
My 75 survivor
Beautiful car and nice work
My 75 survivor is offline   Reply With Quote
Old 03-04-2019, 02:41 AM   #200
TIPSP
Got Boost?
TIPSP's Avatar
Originally Posted by Vol242vo View Post
Stunning.
Thanks Derik!
Thanks!
