Old 12-31-2017, 01:06 AM   #226
Atom D&D
Atom D&D's Avatar
Originally Posted by NONHOG View Post
Curious as to what you used to cut up the console? Doing some interior plastic changes on a OT project.
Regular cutoff wheel. You loose an eighth or so to kerf, but it’s easy to make straight cuts and when rejoining pieces, as long as you comp for the kerf it winds up ok.
Atom D&D is offline   Reply With Quote
Old 12-31-2017, 09:08 AM   #227
M.H. Yount
M.H. Yount's Avatar
Slower going because of the smaller wheel - but I've used a very thin cutoff wheel on a Dremel before to minimize that 'kerf'....
Old 01-02-2018, 02:29 PM   #228
NONHOG
equal opportunity car guy
NONHOG's Avatar
I used one (Dremel) on my GM dash piece and no matter how I tried (speed) it seemed to melt back together.
Hacksaw blade worked well.
Old 01-02-2018, 05:22 PM   #229
Atom D&D
Atom D&D's Avatar
The trick is clearing out the material while it’s hot (or not getting it hot) which in my experience means big cutoff wheel (4”+) so that the plastic is relatively cool by the time it comes back around, or large teeth w/slow speed (like wood cutting jig saw blade on the lowest speed the saw will run), large cut sweep. The cutoff wheel usually makes straighter cuts, but the saw needs less cleanup.
Old 01-02-2018, 05:31 PM   #230
Atom D&D
Atom D&D's Avatar
Out with the old...
Boring, I know. I’ve just got several things at 80% completion and I need to wrap stuff up. I want to focus on getting the engine bay wrapped up which means finishing sheet metal work, which means relocating the battery, oh and while I have the ECU out, I may as well do the Motronic 1.0 to 1.3 swap.
I think I’m going to paint the bay to match the cardinal interior. Might only be temporary, but for now at least. Like this....
(except not bright red)
Funnily enough, I was looking through an old photo album my parents had and turns out my dad had his “project car” parked in the same place mine is and they were kind of similar colors.
Old 01-07-2018, 11:07 PM   #231
Atom D&D
Atom D&D's Avatar
No pics of this weekend’s work. More boring stuff.
-Converted from 1.0 to 1.3 (that was actually more complicated than I thought)
-Relocated battery to hatch (Haven’t bolted it down just yet. Need to verify location)
-Converted to late model headlight switch (only for availability purposes)
-Thinned out the front harness and put Amazon ends on stuff so I can get the front lighting working.
Old 01-08-2018, 09:38 PM   #232
Atom D&D
Atom D&D's Avatar
I know all this doesn’t mean much to you guys, but what it means is that my car has a 9.7:1 compression M20B25 w/6500 redline and 174hp stock. I’m pretty sure that’s the highest HP E30 engine that wasn’t a homologation car (don’t quote me though)
It also means someone got rowdy with the RTV at some point. lol
Old 01-08-2018, 10:22 PM   #233
Atom D&D
Atom D&D's Avatar
Since I was on a fact finding mission. Open diff 3.64 ratio:
Old 01-09-2018, 11:39 AM   #234
Stiggy Pop
Stiggy Pop's Avatar
If a little is good...
'79 242
943 pickup
Stiggy Pop is online now   Reply With Quote
Old 01-15-2018, 10:12 AM   #235
Atom D&D
Atom D&D's Avatar
Times like these when it’s tough to have a project car and no garage. Ugh.
Old 01-15-2018, 03:25 PM   #236
M.H. Yount
M.H. Yount's Avatar
Because Seattle.
Old 01-16-2018, 12:22 AM   #237
77volvo245
77volvo245's Avatar
Because Seattle.
because winter, rains 7 months of the year, and short breaks of sunshine.
STSmachining
Old 01-16-2018, 01:51 AM   #238
amerbritcan
Hnnnnnng
amerbritcan's Avatar
Better than -27, which I had to deal with today
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 01-16-2018, 10:43 AM   #239
Atom D&D
Atom D&D's Avatar
Well, yeah. I don’t like the constant grey most of the year, but in the PNW when it IS nice out, it sure is beautiful. I just set up the pop up tent and try to get something accomplished each day.
Old 01-16-2018, 05:38 PM   #240
M.H. Yount
M.H. Yount's Avatar
Unlike the sky for much of the year out your way, it is CRYSTAL CLEAR that you continue to excel in the accomplishment area. ;)
Old 01-19-2018, 11:45 AM   #241
amerbritcan
Hnnnnnng
*groan*
Old 01-20-2018, 08:43 PM   #242
Atom D&D
Atom D&D's Avatar
Setup my heater and got some stuff done today. There’s always one thing leads to another with this project. Had to make a new fuse box mount. Got the drivers side of the bay painted (it’s not dry yet cause of the temps....brrrrrrrr, so I didn’t take final pics).
I also decided to cut new grille plates. Just finished deburring them. Need to bend the tops and paint them black. I wanted something just a bit different than stock.
Old 01-20-2018, 09:19 PM   #243
NONHOG
NONHOG's Avatar
That is cool, and likely marketable.
Old 01-21-2018, 12:45 AM   #244
Vol242vo
Vol242vo's Avatar
Yeah...I'd expect some requests soon. Can't wait to see it after you paint it black.
Derek - 1980 242
Vol242vo is online now   Reply With Quote
Old 01-21-2018, 01:47 AM   #245
Atom D&D
Atom D&D's Avatar
Well, you’d still need 62-64 grilles. This just replaces the rectangular “mesh” that was stock.
Old 01-21-2018, 03:10 AM   #246
Tuff240
240 Ninja
Tuff240's Avatar
I love the process of how you create things pics.
-Patrick
Old 01-21-2018, 06:58 PM   #247
Atom D&D
Atom D&D's Avatar
Well, that wasn’t the weather issue I expected to have. It was just too windy to get anything done. I had to take the “workshop” down so it wouldn’t blow away or tear. All I could get done was get the driver’s side put back together. I’m leaving the fender unbolted for now cause I’ll need to pull them to finish the cowl sheet metal.
Old 01-21-2018, 07:45 PM   #248
Vol242vo
Vol242vo's Avatar
What a difference, engine bay looks so good!
Old 01-21-2018, 08:32 PM   #249
Atom D&D
Atom D&D's Avatar
It’s a a good 10 footer. I just wanna get the car on the road. Then I can buzz it to my buddy’s shop one weekend, drop the subframe drivetrain and all, and smooth/final paint the bay. Then I can clean up the ancillary stuff too (booster, rack, etc).
Old 01-21-2018, 08:34 PM   #250
Atom D&D
Atom D&D's Avatar
Somewhere in the next batch of stuff, I wanna sort out a better radiator situation. This has a weird small radiator that the latemodel E30s don’t have.
