Old 06-13-2019, 09:46 AM   #1
1978Muffy245DL
Default Can a Volvo 245 be converted TO Nivomats?
I have a '78 245 that has came equipped with the towing rear end, and I tend to move lots of heavy things. (Antiques, old appliances, etc) I know they were available on 740s and 940s, but I can't find any data that indicates their availability on 240s, and what would be required to convert them. From what I can tell, it's just a different set of (softer) springs, and the Nivomat shocks. Is that correct, and how would one select the correct components?
Wes
1978Muffy245DL is offline   Reply With Quote
Old 06-13-2019, 10:19 AM   #2
240wagonguy
You could just spend $100 on a set of Airlift 1000 rear bags, they are designed for this type of thing
240wagonguy is online now   Reply With Quote
Old 06-13-2019, 01:05 PM   #3
They were avaiable for 260 series if I recall correctly. Although I've never seen a set for a 260 ever.
Probably best to go with the air shock or helper spring choices. I used to have a set of rear shocks with helper springs on them. That might work well for you. They didn't do much until the car was loaded.
Have you tried a set of rear overload coil springs? They work well and are usually rated for about 300lb more loading capacity.
Old 06-13-2019, 01:45 PM   #4
240wagonguy
Moog does sell a cargo coil set, lookup CC217.
Old 06-13-2019, 01:48 PM   #5
I dont see why you couldn't convert a set of nivos.
if you can get a set from a solid axle 700 series car, you would just have to drill out the upper pin from 12mm to 1/2" and figure out some spacing adapters at the bottom.
big potential issue would be clearance to the wheel and chassis with the larger nivomat body.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 06-13-2019, 01:58 PM   #6
Nivomats were an option for 240's as were air shocks.
Old 06-13-2019, 02:00 PM   #7
Buy some old school IPD overloads and call it a day.
Old 06-13-2019, 03:45 PM   #8
122power
dude
122power's Avatar
I run the overloads on a wagon and they work pretty good. A little rough empty but depends on the road.
Old 06-13-2019, 07:05 PM   #9
classicswede
Volvo upgrades
Nivo's were common on 240's. I have taken a lot off and converted to normal rear suspension
A good set of cargo springs is your best bet for heavy loads
Old 06-13-2019, 07:32 PM   #10
240240
Cocaina space cowboy
240240's Avatar
Dont be a wimp, run mercedes or jeep springs on the rear.
Shoot the poop!
240240 is online now   Reply With Quote
Old 06-18-2019, 03:20 PM   #11
JohnLane
Lol! That will shake the fillings loose!
