Old 05-04-2011, 10:03 PM   #1
volvo940tuner
volvo940tuner's Avatar
Question msd 6a on 744 tic
Ok, so finally got ANOTHER MSD coil and its time to hook up the 6A box at last.
so for the wiring, it seems pretty straight forward..but i have a question.
the heavy black and heavy red wires are accounted for, same with the orange and black (those go to the coil).
this leaves the white wire and the red wire off the 6A box itself.
MSD's website says to put the red wire to a switched 12v source, and that the white wire is only for another MSD accessory? it also says if i DON'T use the white wire, i have to use the violet and green magnetic pickup connector? this is where i am confused!
So is the magnetic pickup connector (violet and green wires) an optional thing, as well as the white wire?
Lastly, what do I do with the original positive and negative wires that are currently connected to my stock coil?
OR, to answer all my questions..can I just put the red wire (12v switched) to my original positive coil wire, and the white wire to my original negative coil wire?
'93 944-SOLD
'91 745 TIC- PARTED OUT
'97 854 R- SOLD
'96 854T Platinum- SOLD
'98 S70 GLT- SOLD
'98 V70R-SOLD
'95 854 T5-R--teh yellow
'90 744 TIC SE
'96 854R-winter car
'88 BMW E30 325IS
volvo940tuner is offline   Reply With Quote
Old 05-04-2011, 10:07 PM   #2
boosted12a
weapon of mass detonation
boosted12a's Avatar
red to old coil + white to old coil -. did you get a tach adapter? if not you can use an old coil. just wire it in like the directions say to wire in the tach adapter
91 940 SE, 119K, GOLD
03 540i M sport 6 gears of go! 200k, White
05 S80 2.5T, RED
09 XC70 3.2L, BLUE
10 335xi, (fun has a price), black
17 expedition El, (short bus), black
85 RX-7 GSL SE(efi'ed), BLACK
76 Suzuki RE5, BLACK
boosted12a is offline   Reply With Quote
Old 05-04-2011, 10:18 PM   #3
volvo940tuner
what is this about the tach adapter? i am going to be using this with the MSD Blaster 2 coil.
Old 05-04-2011, 10:23 PM   #4
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
It puts a load on the trigger system so the factory stuff thinks its doing something. The white wire trigger takes the high current pulse, but puts no load on the sytem. other wise your car may not run proper.
962j 815/692@27psi
SHEETMETAL INTAKEhttp://forums.turbobricks.com/showth...etmetal+intake
THIS IS FORSALE V
nathaninwa is offline   Reply With Quote
Old 05-05-2011, 05:44 AM   #5
volvo940tuner
Okay, that makes sense. So do I need to buy something else then? I was told to put the white wire to the old coil negative lead.
Old 05-05-2011, 06:20 AM   #6
Krisverde
Krisverde's Avatar
You don't need the adapter. My car has run fine w/o it for the last 8k.
White wire goes to the power stage. I believe it's blue.
1989 Ford f150 5.0
1991 Ford f150
2013 Ford Focus ST
Krisverde is offline   Reply With Quote
Old 05-05-2011, 08:01 AM   #7
boosted12a
boosted12a's Avatar
dose your tach work? so you bypass the ignighter. never thought of that. since you are going that rout, i wonder if you could use the purple/green wires that would normally go directly to the dizz pick up?
Old 05-05-2011, 08:10 AM   #8
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
white wire goes to ignition amplifier output.
red is switched 12.
DNAsEqUeNcE is online now   Reply With Quote
Old 05-05-2011, 09:10 AM   #9
vivalavolvo
vivalavolvo's Avatar
after reading the manuals (i want to try MSD my self) it looks like yuc an hook the white to the old negative (-) for the coil, and the red to the old positive (+) of the coil.
1978 242DL - 1995 855 T5 ARD Green - 1992 Volvo 745
vivalavolvo is offline   Reply With Quote
Old 05-05-2011, 06:48 PM   #10
volvo940tuner
That is what I've heard, but since posting this thread I have heard 4 different people tell me 4 different ways to install it.
So whats the consensus?
White wire to the old negative for the coil?
Whire wire to the ignition power stage?
White wire to the ignition amplifier output?
No idea what the ignition amplifier output is, or WHAT wire you are saying to put the white wire to on the ignition power stage.
Old 05-05-2011, 07:09 PM   #11
meeki007
Ive done it with a Street fire Box from MSD its the old school version of the msd6a. Same wire setup.
Off of the power stage you have two red white wires coming off port 1.
One is thin and goes to the Tachometer.
One is thick and goes to the neg post of the volvo coil.
Remove the thick one to the coil. This thick red-white wire now goes to the MSD white trigger wire.
Why this way?
You have lh2.4 , LH2.4 is triggered by the crank position sensor. The computer than sends this signal to the Power-stage via the gray wire that goes to pin 3 and 5 of the power-stage.
The green and violet wires are not used. If you had a distributor with a hall sensor then they would get used.
Proof mine was setup this way before i went to Megasquert.
http://forums.turbobricks.com/showthread.php?t=196369
Do it. I know you want to.
meeki007 is offline   Reply With Quote
Old 05-05-2011, 07:21 PM   #12
nathaninwa
nathaninwa's Avatar
Or just keep it simple, use the exiting coil - and coil positive.....this way you can diagnose any ignition problems by bypassing the msd box and running the coil like normal. Try it without the tack adapter...it will either run or wont. Then install one if you need.
Old 05-05-2011, 07:24 PM   #13
Tfest
Hipsters ruin everything™
Tfest's Avatar
im using a kjet diz on lh2.2 with a msd6btm.
i have a random miss that i never had before...
never ran a tach adapter, plugged the tach wire directly into the signal wire thing, whatever it was, dont remember, i have a tach though, and it tells me the rpms
Tfest is online now   Reply With Quote
Old 05-05-2011, 07:36 PM   #14
thelostartof
unbalanced chemical
thelostartof's Avatar
thelostartof is offline   Reply With Quote
Old 05-05-2011, 08:14 PM   #15
wolf_walker
LOL
man that was so very t-bricks.
One more Radar Lover gone..
82 VW Caddy AAZ, 400K
wolf_walker is offline   Reply With Quote
Old 05-06-2011, 12:49 AM   #16
gsellstr
Vintage anti-ricer
gsellstr's Avatar
I'm with you Mike.
Take the simple and keep it simple. White wire to the red/white at the coil, red wire to the blue wire at the coil. Leaves you a 100% functioning backup plan if the MSD dies, simple to wire.
As for the tach adapter, save yourself some cash.
http://forums.turbobricks.com/showthread.php?t=99420
Been working solidly since I did that writeup.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 05-06-2011, 07:42 AM   #17
2fast4u
2fast4u's Avatar
Originally Posted by thelostartof View Post
holy crap people .. .. how can you take something so simple and make it so damn complicated.
It takes less than 5 mins to hook up an MSD 6a box to a 90+ LH 2.4 car.
The First direction sheet that MSD has is all you need. Here let me circle the KEY words for you here.
IF you can not figure it out from there then please put down the tools and go do something that requires less brain power like playing with yourself.
Yes I am having a bad day but holy hell guys come on, there are few things easier than this.
stole the words from my mouth
1993 940T
2005 RSX Type S
Originally Posted by badvlvo View Post
Sounds like you are afraid of the horse cock Kenny.
I will freely admit that yes, yes I am. and I'm not ashamed of that fact.
Originally Posted by MrBill View Post
im skeptical... i hope this isnt your last post. famous last words, rite? "anyone JB welded this?"
2fast4u is offline   Reply With Quote
Old 05-06-2011, 11:28 AM   #18
boosted12a
boosted12a's Avatar
Why this way?
i see what you did there. same thing, just in a differnt spot. has any one been confused yet?
Old 05-06-2011, 11:51 AM   #19
Originally Posted by gsellstr View Post
I'm with you Mike.
Eggggs-actly.
I'm running an MSD6 box on my car (MS, 16VT) and just unplugged the wires on the coil and hooked them to the msd input, and ran the MSD output to the coil, and hooked up the heavy wires. Easy to put in, easy to bypass if need be (just unplug the msd input and return those wires to the coil terminals).
Makes it easy to run it back to back and compare to see what difference the MSD box makes.
Old 05-06-2011, 02:28 PM   #20
dreamer1uk
Lolvo
dreamer1uk's Avatar
LOL, i got new sig material from this thread :D
RIP TrickMick :(
1989 Volvo 740 GL
dreamer1uk is offline   Reply With Quote
Old 05-30-2011, 07:00 PM   #21
volvo940tuner
Hooked this up today and the car loves it. However, now the tach doesn't work. How do I hook up the tach adapter?
Old 05-30-2011, 08:19 PM   #22
gsellstr
Vintage anti-ricer
gsellstr's Avatar
This.
