Old 02-08-2019, 06:55 PM   #1
xactorocker
xactorocker's Avatar
Default seat grid
Just picket up a new seat grid for my 240. does anyone know how many springs go on it. I have 3 short and then also 2 new long ones then picked up 2 more long just incase. Thank you
--- update
Looked at other seat has two of each but I cant seem goet the springs on anyone know a good way.
xactorocker is offline   Reply With Quote
Old 02-08-2019, 08:53 PM   #2
TestPoint
TestPoint's Avatar
Those springs have the tension approaching that of valve springs.
Don't hurt yourself!
I was not able to stretch only one side's springs to hook the seat pad. I had to stretch both sides at the same time to get enough spread of the springs using 2x4's as leavers.
Ford V8 Conversion Manual -
Old 02-08-2019, 09:36 PM   #3
xactorocker
Dang that's crazy so you just stuck the 2x4 in and turned it? Also whats the coat hanger wire for. Thanks.
Old 02-08-2019, 10:00 PM   #4
bobxyz
bobxyz's Avatar
From the looks of it, a couple big C-clamps, or beefy woodworking bar clamps, would help pre-tension one side of the frame. To get the final springs in place, I'd use a big round-shaft screwdriver through the spring end and against the frame to wedge+slide the spring in place. You'd need to have the spring end facing down to do this.
Old 02-09-2019, 05:55 AM   #5
cleanflametrap
cleanflametrap's Avatar
Brake spring pliers plus a bit of bent-up SS antenna rod were a big help to me. Safety makes it worth thinking this through. If I remember right, the eight springs go long ones toward the front of the seat.
(The scrap of carpet in the pic above was a common suggestion to stiffen old foam -- back 20 years.)
-Art
Old 02-09-2019, 08:23 AM   #6
TestPoint
TestPoint's Avatar
The coat hanger connected the spring on the other side to the second 2x4 lever.
Old 02-09-2019, 10:03 AM   #7
xactorocker
I ended up getting my 4 springs in like my other seat using a c clamp and a screwdriver to full the spring the last bit. thank you all
Only worked because i had two people
Old 02-09-2019, 07:04 PM   #8
carver
Redblock for life.
carver's Avatar
Tore the ligaments in my right elbow doing this job, wish this post popped up months ago. Still hasn't fully healed.
carver is offline   Reply With Quote
Old 02-11-2019, 02:57 PM   #9
xactorocker
Dang that's crazy, well maybe this will help the next person avoid hurting themselves.
