Old 02-13-2019, 01:46 AM   #1
89_740Turbo
89_740Turbo's Avatar
Default What battery can be used instead of the Group 47 ?
Just incase I can't find anywhere that has a group 47 battery in stock, what other battery can be used that will still work?
I know the terminal sizes have different diameters, so just want to know! Thanks
1989 744Ti
1988 744Ti
1986 744GLE (RIP)
My Feedback Thread - http://forums.turbobricks.com/showthread.php?t=342247
Old 02-13-2019, 10:54 AM   #2
Mark G
STARTTLS
Mark G's Avatar
Group 47 is fairly common with a lot of different models from different mfgs using that size. I think you'll be fine with the sheer number of auto parts stores that are likely within a 10 minute drive of anywhere in the central Jersey area.
For your reference, http://www.batteryweb.com/bci.cfm
From past threads, it seems that people used group 24F, 48, 58R for a few examples of other sizes.
-Mark
Sold: 1981 242 DL
Parted and crushed: 1990 245 DL
1993 245 DL
Feedback thread
Instagram
Mark G is offline   Reply With Quote
Old 02-13-2019, 12:13 PM   #3
oifish
I'm feeling extra zazzzy
oifish's Avatar
I can't remember off the top of my head, but I got some type of truck battery with a higher cold cranking amp from O'Riley. When I'm home from work I'll look it up.
1990 Volvo 744T M46 - Daily Driver - ( ͡° ͜ʖ ͡°)
1996 Chevy C1500
__________________________________________
Buy/Sell Feedback
oifish is offline   Reply With Quote
Old 02-13-2019, 02:09 PM   #4
turbochimp
I think this was a group 48 - I have the same
turbochimp is offline   Reply With Quote
Old 02-13-2019, 02:15 PM   #5
89_740Turbo
The only reason I ask is because where the car is stored, it's in a fairly remote location and the closest store with batteries is Walmart lol I went to 2 up there and neither had group 47
Old 02-13-2019, 03:29 PM   #6
sbabbs
sbabbs's Avatar
Yeah normal 24 always works for me, get the one with the positive on the side you need might be 24F as stated above.
Old 02-13-2019, 05:50 PM   #7
89_740Turbo
Awesome, thank you so much!
Old 02-13-2019, 07:01 PM   #8
xactorocker
xactorocker's Avatar
i found just get a battery with the same amount of cold cranking amps they dont make the stock battery anymore.
xactorocker is offline   Reply With Quote
Old 02-13-2019, 11:41 PM   #9
89_740Turbo
the problem is with the terminal sizes. some are 1/18 others are 2/18. there aren't many places with group 47 and for purpose of convince, going to Walmart and buying a battery from there is the easiest thing for me to do right now.
the car is stored in a garage up in the mountains of NY, so its quite literally in the middle of nowhere hahaha that's why I made this thread because a Walmart is the best thing they have within a hours drive to get a battery.
and speaking of, I don't think I've seen more classic cars anywhere else, not even in central NJ. when I'm up there to visit my girlfriend, I always without fail will find tons of different classic cars parked in driveways or sitting in soemones backyard. all kinds! 50's caddys, 60's cars, Buick's, old land rovers, old jeeps, 50's pick-up trucks, whatever. they are all over the place in the upper ny mountain areas
Old 02-13-2019, 11:46 PM   #10
Wren
Porkchop Sandwiches
Wren's Avatar
The larger 960 batteries will work.
Old 02-14-2019, 10:37 AM   #11
Mark G
STARTTLS
Mark G's Avatar
I'd call around to the closest stores and check who has what stock before you go. A half hour each way isn't so bad if you know the right part is waiting on the other end.
Or, buy one near you and bring it up next time you visit.
Or order the correct, NOS, OEM battery from here for ~$40 shipped? https://www.volvopartswebstore.com/p...7/9128531.html
Who knows how long it will last, but it's a dealership battery for cheap.
Old 02-14-2019, 03:56 PM   #12
sbabbs
sbabbs's Avatar
Most any car battery will work if it fits in the hole and the positive side terminal is on the correct side. Man O man.. Like I said group 24 the most common car battery ever made..
As far as amps, I've started volvo's with a lawn traktor battery before..
Old 02-14-2019, 05:09 PM   #13
adamdrives
You can get an oem battery for that cheap? There must be a caveat.
Feedback thread
78 242 DL 189k
83 245T+IC 136k
99 V70R 163k lazer blue
05 S60R 161k sapphire/nordkap
08 S80 V8 109k
adamdrives is offline   Reply With Quote
Old 02-14-2019, 05:11 PM   #14
When I looked at the listing for the extremely affordable volvo battery. It read no shipping local pickup. So, that is probably the caveat to get you in the door and then not have one in stock. But they do have this other battery in stock that will work. Lol.
Old 02-16-2019, 05:35 PM   #15
lummert
lummert's Avatar
Group 40-R battery meant for a Ford in my 88 765. 11 inch long battery without end mounting lugs or carrying handle.
Volvo battery has reversed terminals (the R in 40R), same as Ford.
Old 02-18-2019, 04:14 AM   #16
Otto Mattik
Chief Bottle Washer
Otto Mattik's Avatar
48a fits perfect in my 1992 240
* the catalog listed 47 for my car (which they didn't have but did have 48a)
** forgot to note the OE batt clamp is missing
Old 02-18-2019, 01:59 PM   #17
oifish
oifish's Avatar
Yup, mines a group 48. Fits perfectly.
Old 02-20-2019, 12:10 AM   #18
8587turbo
24F
8587turbo is offline   Reply With Quote
Old 02-20-2019, 12:18 AM   #19
Cwazywazy
Single jingle
Cwazywazy's Avatar
Group 65 fits but you won't be able to use the hold down. I used a ratchet strap.
I don't know what I have
Cwazywazy is online now   Reply With Quote
Old 02-26-2019, 03:29 AM   #20
arsenix
Is this legit? Maybe they are crap because they are NOS and been sitting around? That is a steal if real...
88' 740 GLE Wagon - B230FT, T5 Trans, MSII-extra, G80, 3" T->T Exhaust
- - > Project Thread < - -
My new project - 1990 740 SE Wagon
arsenix is offline   Reply With Quote
