Old 07-25-2019, 09:28 PM   #1
xactorocker
xactorocker's Avatar
Exclamation A/C stopped working just as temp gauge started being pinned at top
Hey I have a 1985 volvo 245 with the m46 transmission. I am trying to figure out two problems with the car. one is that the temperature gauge has been going up with engine rpms and now is pegged at the top when the car is on. second pretty much as soon as this thing with the temperature happened my A/C stopped blowing cold air. the clutch is still engaging and disengaging but the air does not seem cool if anything it seems warmer. I tried to disconnect the sensor for the gauge and test it like the Bentley manual says but the gauge stayed up. any ideas on these problems thank you. the A/C was also charged and some wiring was fixed in the last month by a volvo repair shop. thank you any ideas are appreciated.
Edit- also I just thought about it and the A/C used to make the car change Idle and now it doesn't seem to do so it makes a different sound than. before and the idle doesn't change. just incase that's an important detail
xactorocker is offline   Reply With Quote
Old 07-26-2019, 09:55 PM   #2
c1800
Take it back to whoever charged it and fixed the wiring.
Old 07-27-2019, 03:45 PM   #3
xactorocker
Yeah that's what ended up happening. I took it over there they said the wiring must be burnt up somewhere in the harness. I gave into paying for it and not doing it myself its alot of work to find those things. I'll write back if they find what was wrong. thank you
