Old 10-06-2017, 10:34 AM   #1
Fretka
Fretka's Avatar
Default B200FT base MAP for MS1
Hey guys!
Maybe someone could share base ignition and fuel map for B200FT engine, MS1 ecu? Seen only pair for B230FT. Bringing it to proper tuner of course, only it's a little easier with some base map. Car idles okay for now.
Working in TunerStudio
Mexipoku - custom low budget suspension solutions
Fretka is offline   Reply With Quote
Old 10-06-2017, 11:19 AM   #2
cwdodson88
Just use the table generator, and find a stock ignition curve then interpolate the missing values. Follow the manual for making a new table. It'll be about the same amount of time as cleaning up someone else's junk, but it makes you know and understand the necessary changes that need to be made and better suits your tune to the rest of your mods.
The Build Thread
SVEA - PUSHROD TURBO!
Old 10-07-2017, 08:20 AM   #3
doucheNozzle
doucheNozzle's Avatar
MS1? Really?
'95 850 T-5R - FailSedan
'04 V70 T5A - FailFamily
Old 10-07-2017, 11:11 AM   #4
cwdodson88
Originally Posted by doucheNozzle View Post
MS1? Really?
It works so I don't see any problem using it. Sure ms2 would be better, but not necessary for every application. Plus the manuals and write ups are easier for a newb to decipher and get the basics under control.
Old 10-11-2017, 11:29 PM   #5
doucheNozzle
I'd rather LH2.4 than MS1
Old 10-16-2017, 10:22 AM   #6
turbotankshane
Out of curiosity, why?
turbotankshane is offline   Reply With Quote
