Old 12-30-2019, 04:41 PM   #101
2manyturbos
Originally Posted by Tfrasca View Post
He probably means the 60 ft time, no?
It looks like he has an open diff. Some sort of limited slip and stickier tires and he should be in the 13s.
Old 12-30-2019, 05:03 PM   #102
volvoracer82
volvoracer82's Avatar
he was on street tires with a G80, and this was his first time attempting a 1/4 mile. I think he is very capable of getting in the 13's. unfortunately, the track got shut down for an hour because of a mechanical failure that dumped coolant down 2/3 of the track and exit lane right when he got there, then only a chance for 1 run before the track got shut down completely when a 1500HP CTS-V went into the wall 10 min before the track closed.
1983 242ti-Rally machine. 19/16 sways, mvp endlinks, gt braces, 17x9 ESM 004R's, Truetrack, Rx7 brakes, momo steering wheel, corbeau gt2's, 1992 B230ft, b230 int. atp ultimate WG, 3" turbo back, ported 90+ mani, k cam, Garrett t3/t4
1982 245DL-DD
1984 242ti-?
volvoracer82 is offline   Reply With Quote
Old 12-30-2019, 05:57 PM   #103
klr142
Turbo, what?
klr142's Avatar
Yes, the 60' time.
Ouch! And cool, one run is better than none but a total bummer to only get one!
Ryan, have you had your car on the dyno with the current setup or similar, before?
Old 12-30-2019, 06:17 PM   #104
volvoracer82
Originally Posted by klr142 View Post
Yes, the 60' time.
last time the car was on a dyno was probably 10 years ago at Evil Genius (Davis weekend event) when it was on K-jet and could only safely run 9psi. it put down somewhere in the 140-150 HP range and 191 ftlbs. previous best 1/4 time was 14.1 @ 98mph up in PDX with you guys a few years back
we have an unofficial time frame for some dyno time in February or March to do some tuning, we'll get some new numbers then.
Old 12-30-2019, 06:34 PM   #105
klr142
Turbo, what?
klr142's Avatar
I look forward to it!
Old 12-30-2019, 07:35 PM   #106
cosbySweater
cosbySweater's Avatar
Where at???
1995 Porsche 993
2013 VW Passat TDI
Old 12-30-2019, 07:39 PM   #107
Man I miss going down to Sac to screw around with u guise
Old 12-30-2019, 08:53 PM   #108
volvoracer82
Then come down, I dont see the problem
Old 12-30-2019, 09:48 PM   #109
gsellstr
gsellstr's Avatar
I gotta say, Jimmy did pretty well for a roughly put together, not finished build, on street tires with a G80, never raced before, and grip on the track was far less than acceptable. Throwing down less power than I did at PIR last year, where I couldn't spin a tire if I tried, this weekend I couldn't get mine out of the hole without spinning, with one run, only one against Ryan, where I spun them clear thru 1st and halfway thru 2nd, after doing a solid warmup on them. Prep has never been a strong suit for Sac. I've never been able to get better than a 2.0 60' even on my 255/40 Advan's.
Having been in Ryan's car plenty, I'd put him at a solid 300, based on performance against mine when it was dyno'd at 275whp a few years back. I'm sure if he could get it out of the hole without bogging or spinning, it's got a 13.4 in it.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 12-30-2019, 10:09 PM   #110
James M
Bored member
James M's Avatar
My wagon was pretty cobbled together for the day, "finished" working on it about noon and then left. I found later my turbo inlet gasket blew the bottom half out on the way there and had to grab a stud from my buddy in the blue 244 that accompanied me.
Not to blame the car too much tho, I messed up the launch pretty bad spinning the tires in first for way too long. A combination of fixing the car and perfecting my launch I'm hoping to do better for next year.
Time to look into cheap used slicks, and or wire up the secondary rev limiter on the Buchka board. 53$ tires at 5000rpm don't really hold traction
13.4 would be great, only room for improvement from Saturday anyways. Lots of fun though
Old 12-31-2019, 01:39 PM   #111
cosbySweater
What does his car weigh?
Old 12-31-2019, 03:41 PM   #112
volvoracer82
If you are asking about mine, I don't know. estimating between 3,200-3,400 with me in it and a full tank.
Old 12-31-2019, 03:46 PM   #113
Tfrasca
Tfrasca's Avatar
1/4 mile calculators put you around 270 flywheel HP at 3200 lbs. If you trust that to be somewhat accurate, and you also trust injector calculators, than you should probably get some bigger injectors.
Old 12-31-2019, 04:21 PM   #114
volvoracer82
oh, yeah, I know these little guys are maxed out. I have the 60lb injectors and a 3" MAF on the shelf to put in after we get some good numbers with the boost turned down (as to not max out the injectors) for a good base on the current parts
Old 12-31-2019, 04:29 PM   #115
gsellstr
gsellstr's Avatar
Trust me Tyler, Ryan and I have discussed the 'how the hell is your car this quick on those tiny injectors' situation several times. lol
James' car is a full street trim 245, so what, 3300 plus driver and stuff?
Old 01-03-2020, 10:54 AM   #116
gsellstr
gsellstr's Avatar
Looks like we still need Jimmy's, Erik's, and my times added to the roster.
Old 01-03-2020, 12:30 PM   #117
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
ken's dealing with some family stuff I believe, but he hasn't updated it in a bit.
Megasquirt Tuning!
Old 01-03-2020, 12:39 PM   #118
gsellstr
gsellstr's Avatar
Gotcha. I saw Ryan's time from last weekend but not the rest. Thanks for the heads up Kenny.
Old 01-03-2020, 12:53 PM   #119
gsellstr
gsellstr's Avatar
Timeslip for StevE85 (left lane)...
Old 01-11-2020, 05:37 PM   #120
qwkswede
faster than you think
WOWSERS! You guys were busy between christmas and new years. I'm catching up here. But there are lots of
really interesting exciting timesplips pouring in. Stay tuned... I'll tally the winner!
-Ken
1967 Volvo 122S
1992 Volvo 745 driver
Old 01-11-2020, 06:04 PM   #121
qwkswede
Damn Volbros! I wasn't sure anyone was playing Volvos this year. But you guys came out in force to close out the year. I think I have everyone added. If I misssed a timeslip, drop a note and I'll track it down.
I have to say it is always a pleasure to curate these timeslips. I get a chance to see first hand what kind of wicked B.S.O.s (box shaped objects) people are assembling. It is inspiring and I'm proud to be part of this community.
Some highlights for 2019
Total participants: 16
Turbo Winners: WEST -- by a small margin!
NA Winners: WEST -- 1 NA racer. Good one klr142
Hybrid Winners: EAST -- Close one here too.
Overall: WEST -- by 50 points.
Fastest ET: Roger Dee --10.33@128mph
Old 01-11-2020, 10:06 PM   #122
gsellstr
gsellstr's Avatar
Another best coast win, awesome!
Now to fix the bottom end that's hurt, get the nice head fixed, get a proper tune, and break it in time for 2020. lol
Old 01-12-2020, 03:20 AM   #123
klr142
Turbo, what?
klr142's Avatar
Wahoo! Thanks, sir! I'm glad I helped make the best coast win this year. It's been a while since I contributed much and I look forward to doing it again next year. I probably won't race the S60 anymore though, so I should probably put some effort into making the 240 at least a little bit faster again. Maybe the big valve head will go back on with a nastier camshaft.
Old 01-15-2020, 04:02 PM   #124
poulrais
poulrais's Avatar
You needed almost twice the entries than the East Coast submitted to win.
I hope I'll be able to contribute this year!
1990, Volvo 740 16v +T
Old 01-16-2020, 12:17 AM   #125
gsellstr
gsellstr's Avatar
We also don't have a guy with a dyno is his back yard to tune other people's stuff.
