Old 09-09-2020, 03:56 PM   #1
Shinchan
Default T5 swap on a 140 - can I use a 240 clutch cable?
Wrapping up a T5 swap in a 140 using the DeeWorks T5 adapter using the M45-style bellhousing. The bellhousing has the larger clutch cable adjustment hole than the M41 bellhousing. Can I just use a 240 clutch cable with the 140 or is there some other way to get the adjuster on the trans end to mount correctly in the larger adjustment hole?
Here's the original-type:
s-l1600
Here is the type of bell housing that I installed with the swap:
121375150-a-DVu1flp-P1080533
Shinchan is offline   Reply With Quote
Old 09-09-2020, 04:30 PM   #2
Shinchan
Or likewise, can I remove the adjustment bushing from the end of a 240 cable and use it on a 140 cable? My 140 cable is Volvo NOS and I'd like to use it if possible.
Old 09-09-2020, 11:47 PM   #3
Harry Tuttle
Your 140 cable is threaded with two nuts, right? Have you looked at the delrin bushing that STS sells? You may be able to put the cable end right through the I.D. of the bushing. Looks like it may be a little large on the inside, but it seems like a good start on filling that big hole.
Originally Posted by sbabbs
just gutless low compression k-junk
Old 09-10-2020, 10:51 AM   #4
Shinchan
Yes, it's the super-long thread with 2 adjustment nuts. I already have a Beck Arnley 240 cable on the way to see if I can make the bushing fit on the 140 cable end. If that doesn't work out, I'll definitely check out the delrin bushing.
Old 09-10-2020, 10:54 AM   #5
no
Old 09-10-2020, 12:02 PM   #6
AndrewNance
Amateur hour!
AndrewNance's Avatar
Can’t you just use your m40/41 bell housing so everything works?
Old 09-10-2020, 01:37 PM   #7
Shinchan
No, it won't work with the deeworks adapter. I can't remember which, but the M40/41 bellhousing is either slightly too long or too short.
Old 09-10-2020, 01:59 PM   #8
CJs 142E
CJs 142E's Avatar
B20 or B230FT..?
72 142 Turbo Project (In the works)
Join My Group > http://forums.turbobricks.com/group.php?groupid=97
72 142Turbo
73 145
06 V70R Sonic Blue
CJs 142E is offline   Reply With Quote
Old 09-10-2020, 03:16 PM   #9
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
Originally Posted by CJs 142E View Post
B20 or B230FT..?
Not to speak for the OP, but based in previous posts it's a B20.
I'm here because I want to see how this works out so I can do the same thing in my car.
Doing the wrong thing the right way.
Originally Posted by redblockpowered View Post
Will you do $14.99 shipped?
Originally Posted by IansPlatinum View Post
please no more prying things with screwdrivers and bashing things with hammers!
fatcatbestcat is offline   Reply With Quote
Old 09-10-2020, 03:42 PM   #10
The Librarian
I think the best solution would be to make an aluminum bushing to reduce the size of the hole so the 140 clutch cable can be used. It'll need to have a flange so it doesn't pull through the hole in the bell housing and it shouldn't be very thick as that will affect the amount of adjustment available.
Old 09-12-2020, 03:36 AM   #11
OttoB
Common trick for 120 and 140 is to modify with 240 clutch cable. You have to use washers at firewall and little grinding on that fork. This is for allowing clearance for full movement.
240 cable has less friction than 120/140 cables.
Old 09-12-2020, 04:48 AM   #12
TurboDutch
Where can I find the threat about this project?
TurboDutch is offline   Reply With Quote
Old 09-12-2020, 07:50 PM   #13
Shinchan
Locked somewhere in the bowels of my fevered brain...
Old 09-12-2020, 07:53 PM   #14
Shinchan
Mischief managed.
Obtained a 240 cable assembly, removed the rubber bushing and crappy plastic bushing insert, and put it on the 140 cable. The adjustment bolts are the same size but different threads. Fortunately, since the insert was crappy plastic, I just muscled through cutting new threads using the adjusting bolt. Worked like a charm!
IMG-7559
