turbochimp
- Nov 2, 2011
Installed the following on my 1990 740 B230FT LH 2.4:
15g (from 13c)
012 AMM pre turbo - replaced stock air box with cone filter
48lb high Z injectors @ <3 bar (e85) - bypassed resistor pack
Now I get a rich spike when I let off throttle. AFRs read between <11-12 for a period of around 3 or more seconds. This does not only happen off boost - it will happen if I let off from ~0psi. Idle, cruise, accel and WOT all work great - just the prolonged rich spike when I let off.
I initially thought this was due to the stock cbv leaking. I have replaced the cbv with the forge piston style cbv and pressure checked the entire system - no leaks.
Any ideas? Halp!
15g (from 13c)
Any ideas? Halp!
