Another productive session with the car. Fuel system buttoned up and successfully leak tested, VEMS sensor crap is fixed, sealed the compressor housing, plumbed the back pressure gauge, fixed the dash cluster, installed the headlight adjusters, hooked up the tach, re-wired the washer pump, fixed the oil pressure sensor mount, fixed a small steering rack clearance issue, made a TDC indicator needle, and pulled the radiator and IC in preparation for pre-oiling the engine.
Couldn't find the cover for the fuel tank access port, so Alex made a new one.
Headlight adjusters are in and working perfectly.
We needed an accurate way to find TDC for marking the crank pulley, so we made a cylinder stop out of a bolt and a gutted spark plug. You just rotate the crank until it bottoms out against the stop, mark the pulley, then rotate it in the opposite direction until it bottoms out. The center of your two marks is TDC.
Here's the TDC mark and the pointer needle Alex made. Should do the job.
The list of stuff-that-needs-to-get-done-before-startup is getting dangerously short: pre-oil the engine, fill the transmission, terminate the e-fan power wire, engine electrical checkout, and hook up the headlights.
