Stiggy Pop
In the cool kids club
- Feb 27, 2011
- Granville, MA
I have a persistent rpm specific lean swing from ~2,900-3,200 rpm on my car that I've been unable to work out, would love some other thoughts on what could be causing it.
The first year I ran the car on MS2, stock fuel system, stock intake, stock ignition and didn't have any problems. Last year I put in a Nathan intake, DW300 pump and -6 lines, and a microsquirt V3 driving LS2 coils paired in wasted spark with a stock VR crank sensor. The lean swing has been around to some degree since. This year I put in a freshly built bottom end, RSI st2 head and st3 cam and am still working on this exact same rpm range.
I have been trying to fuel it out, and can knock a point or two off the peak but I still end up with the same shape to the curve (and usually a rich condition coming out of it). I've had Kenny look at it as well, and thinking is that there must be an underlying mechanical cause.
Things I've tried:
Fuel pressure is verified good
Fuel pressure reg is brand new/functioning properly
Fuel flow is good
Injectors cleaned and balanced - good
System pressurized and air leaks addressed
Coils, wires and plugs all swapped - good
swapped to a BMW crank sensor
The car was wired with the micro harness with IGN1 and IGN2 split to drive the coils in wasted spark pairs. I get a good rpm signal from the VR crank sensor and am not seeing any sync loss during the condition.
We're starting to think it could be some kind of odd ignition problem, since we've ruled out fuel. The fact that it is rpm specific is interesting. We had thought about some kind of oddity surrounding the Nathan intake but the fact that it happens at different manifold pressures makes that seem unlikely. I might spend the time this week putting a stock intake manifold back on to rule this out.
Would love any ideas from people here on things I could look into. I'm kind of getting down to my harness or the micro, but not sure what I'd be looking for.
These should lead to download links, let me know if they aren't live:
MSQ
https://drive.google.com/file/d/0B_LBSR-F6k0yME9DNkczMHQyWHM/view?usp=sharing
LOG
https://drive.google.com/file/d/0B_LBSR-F6k0ySEZNbTNJcmZUeGc/view?usp=sharing
Things I've tried:
Fuel flow is good
MSQ
LOG
